[ROM][9.0][Dumpling] Android Ice Cold Project 14.0 [Official weekly]
  • 2 Antworten
dexxter88
dexxter88
Stamm-User
104
AICP
AICP is known by everyone as the "Ice Cold Project" that started on a Desire HD years ago (2012) and since then has evolved into a mature ROM with the BEST community that you can find!!!
Until Android Lollipop, the ROM has always been based on AOKP. Unfortunately, since AOKP stopped development (but made a comeback later), we changed our base to CM.
With the re-brand of CM to LineageOS (LOS) we became LineageOS based with some tweaks from AOSP and we are now based on the "Ground Zero Open Source Project" (GZOSP) for Android Pie.
If there are any bugs, either we will sort them out or the GZOSP team, if it concerns their code base. This ROM isn't GZOSP supported, so there is no need to report errors/bugs to them!!
Code:
#include <std_disclaimer.h>
* Your warranty is now void.
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications and if
* you point the finger at us for messing up your device, we will laugh at you. Hard & a lot.
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Ffeatures.png
Feature list (rough overview)
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fcredits.png
In the beginning we would like to thank:
GZOSP team
LineageOS & CM (R.I.P.) team
@maxwen and the rest of the OmniRom team
DU team
SlimRoms team
Resurrection Remix team
Community
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fteam.png
@Lord ClockaN
@zipsnet
@eyosen
@semdoc
@SpiritCroc
@wartomato
@eboye
plus the rest of the crazy bunch that we call "team"
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fdonations.png
We are paying for servers that build nightlies/weeklies and everything that comes with it, so EVERY DONATION will really be appreciated and be used to cover those expenses.
Thank you!!
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fdownloads.png
Latest Stable Release Version 14.0
Download link: AICP | Android Ice Cold Project
Please note that official builds will be deleted from our servers every month due to maintenance services.
We advise everyone to keep at least the latest or best working build on their device as a backup.
Maybe copy it to a cloud service or USB too.
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fchangelog.png
Full Changelog link: AICP | Android Ice Cold Project
(Just click the changelog button next to the download link in the list of builds available for your device)
Google Apps:
The Open GApps Project
(version: 9.0, ARM64, micro or nano)
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fissues.png
You tell... :p
FAQ:
Before using the ROM:
Q. Can I have an ETA for the next build?
A. Yes, just look in the OP to see if your device is built on a nightly or weekly schedule.
Q. Does this ROM support custom kernels officially?
A. No. You can still use them, but discussion should go in the thread of the respective kernel. We don't offer support for bugs you might encounter while using them!
Q. Why doesn't this ROM support Xposed?
A. Xposed is a hack that is geared towards AOSP. Custom ROMs modify the framework a lot, so Xposed can cause a ton of issues on custom ROMs. Now it might work for you, however it is not to be discussed in this thread, and you should refrain from posting bug reports.
Q. Alright, but I still want to flash Xposed, so which version do I need to install?
A. You will need to use the version arm64/arm/whatever for SDK 28.
Flashing the ROM:
Q. What do I need to know before flashing?
A. Check the install instructions in the first post...
Q. Can the builds be dirty flashed over each other?
A. Yes, however make a nandroid backup first as there is a chance of getting a bootloop or encountering bugs. Also bugs may only be reported on a clean flash.
Q. How do I 'dirty flash' builds?
A. Wipe the System, Cache and ART/Dalvik cache. Flash the ROM, GApps (only needed if you wipe the system), your preferred root solution and reboot. Or just use the OTA app to preform that task for you.
Q. How do I flash kernel builds?
A1. If it's a .img file, boot into TWRP and go to the install page in TWRP, in the bottom right corner select "install image", select the desired kernel, then select "boot" as the destination, then swipe to flash, then go back to the install screen and install your root method again, if you don't want to loose root and reboot.
A2. If it's a flashable ZIP, you can flash it together with a ROM update or separately. Go to the install page in TWRP, choose the kernel zip (or add it to the flash queue right after the ROM zip). Then add your root method to the queue if you don't want to loose root. Now swipe to flash and reboot afterwards.
Using the ROM:
Q. I installed a bad theme and now I'm getting a bootloop, how do I fix it?
A. In TWRP, flash the substratum rescue zip that's in the substratum folder on the internal storage.
Q. I'm having issues with WhatsApp, how do I fix it?
A. Read this
Q. Do I need to provide a logcat if I'm reporting a bug?
A. If you want it to be fixed faster (or at all) then yes, you should definitely provide a logcat. (Note: Please just link the logcat from your GDrive, Dropbox, etc. and do not post the content here. Thanks.)
Q. How do I get a logcat, what type should I get and more questions that can conveniently be answered by my pre-determined answer?
A1. Read this thoroughly. Also, here's a good app for getting logs: https://play.google.com/store/apps/d....tortel.syslog (Root needed).
A2. If you are already rooted, you can use the built-in feature to make a logcat and provide that. Just look into the others section in the AICP Extras main page.
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Finstructions.png
The ROM should contain everything you need to enjoy Android Pie. You don't need to install any Add-on's, simply download the latest ROM, GApps, flash it and go!
If you want the device to run the ROM "rooted", you can flash a root solution of your choice after the ROM Zipfile.
It is STRONGLY recommended to fully wipe your device before flashing and please avoid restoring system apps and system data with Titanium Backup as this can cause stability issues that are very hard to debug.
If you believe you know what you're doing - then fine, go ahead, but please don't complain if you experience any strange behavior.
How to flash for the first time:
(Again: Don't do it if you don't know it!)
1. Download the ROM and GApps and transfer them to your device.
2. Boot to recovery (TWRP recommended).
3. Wipe the System, Cache, and Data (you might need to format the data partition!).
4. Flash the ROM Zipfile.
5. Flash the GApps (optional, needed for e.g. Google Playstore to work).
6. Reboot and set up your device, enable developer settings and in them OEM unlock/Advanced reboot/USB tethering.
7. Reboot back into TWRP recovery.
8. Flash the root solution of your choice (optional).
9. Reboot your device.
The procedure might vary from device to device and is a bit different on system updates!
The ROM has GApps persistence in between dirty flashes, so you only have to flash them once! This might differ on AvB Devices.
The root solution can be flashed together with every OTA update (= ROM Update).
Currently supported Root Solution:
Magisk stable
Magisk versions >= 17.2 for oreo and 18.1 for Pie don't usually require to be flashed on every dirty flash.
PREREQUISITE FOR OTA ("Over-The-Air" Updates):
To be able to flash using the built-in OTA app, TWRP recovery is needed.
Please be sure that you are on the latest TWRP recovery. Keep in mind that this could also be an unofficial version!
On encrypted devices you will have to enter your PIN/password in TWRP before the process starts.
If you want to contribute to the AICP or want see what is being worked on/merged, feel free to visit our Gerrit code review system. (Link is at the bottom!!!)
https%3A%2F%2Fraw.githubusercontent.com%2FAICP%2Fvendor_aicp%2Fp9.0%2Fxda_template%2Fsources.png
KERNEL:
Kernel
Device sources:
Dumpling
ROM & Additional links:
AICP's Homepage
AICP Gerrit Code Review
AICP sources on Github
AICP Download page for official builds and media content
AICP Discord Community
Contributors:
@csolanol
@wartomato
@nathanchance
@eyosen
@codeworkx
You want to see a "normal" night at the "DEV office", click here!!​
XDA:DevDB Information
AICP 14.0, ROM for the OnePlus 5T
Contributors
GreekDragon, eyosen, csolanol, wartomato
Source Code: AICP
ROM OS Version: 9.x Pie
ROM Kernel: Linux 4.x
ROM Firmware Required: Pie firmware
Based On: GZOSP
Version Information
Status:
Stable
Created 2018-01-19
Last Updated 2019-07-28
Quelle: [ROM][9.0][Dumpling] Android Ice Cold Project 14.0 [Official weekly]
Bitte als Stammgast sollte man die Regeln kennen 😐
Please read first / Bitte zuerst lesen – Informationen für neue User und Vorstellungen
Und wenn man schon Threads kopiert dann bitte nicht 1:1
dexxter88 schrieb:
Firmware OB2 Firmware : Download removed
Firmware OB3 Firmware : Download removed
Firmware OB4 Firmware : Download removed
Firmware OB6 Firmware : Download removed
Firmware 5.1 Release: Download removed
Firmware 5.1.1 Release: Download removed
Firmware 5.1.2 Release: Download removed
Firmware 5.1.4 Release: Download removed
Pie Firmware 9.0.4 Release: Download
Pie Firmware 9.0.5 Release: Download
Kannste die bitte alle Entfernen bringen ja einem nichts 😳
Auch hier deine anderen 2 Threads bitte Anpassen 🤔
[OP5T][LATEST 9.0.9] Collection of unbrick tools – Custom-ROMs für OnePlus 5T
[ROM][9.0][DUMPLING][OFFICIAL] Pixel Experience [PIE/PLUS][WEEB][2019/12/20][EOL] – Custom-ROMs für OnePlus 5T
Habe schon ewig nichts mehr gepostet. Und sonst waren die 1:1 Geschichten von XDA auch kein problem. Wollte etwas fahrt in unseren 5T bereich bringen. Ich arbeite die sachen jetzt weiter ab. Arbeit bze RL gehen aber vor. Ich bitte um etwas Nachsicht und Gedult.
Gruss
Reaktionen: Gabberlein
dexxter88
dexxter88
dexxter88
dexxter88
dexxter88
dexxter88
dexxter88
dexxter88
dexxter88
