[DEV][ROM] CyanogenMod 10.1 (Android 4.2.1)
  • 24 Antworten
Q
QuesT
It is unofficial and unsupported by the CyanogenMod team. This ROM is mainly for developers/testers/advanced users - people who are aware that this ROM is incomplete. I'm really not interested in hearing whining about non-working things (and questions when they will be fixed), actually I couldn't care less if you have issues with this ROM.
There's instructions/sources in the third post to build CM10.1 yourself. If you must have something fixed right now - you better do it yourself.
You'll need at least 160mb system partition for the ROM and gapps to fit. Both gen1->gen2 and G2 TPTs are available at Amphoras' TPT Helper.
Working:
  • Wifi
  • RIL (mobile network & data)
  • GPS
  • Audio (playback/input/routing/headphones/etc)
  • Camera (photos, camcorder & panorama)
  • Hardware acceleration and OpenGL rendering
  • Hardware video decoding & encoding
  • SD card
  • USB-storage & adb
  • USB-tethering
  • Browser
  • Touchscreen/multi-touch
  • Sensors
  • LEDs
Partially working:
  • Project Butter - no vsync
Not working:
Sources:
  • CyanogenMod team & everyone who's been working on CM10.1
_____________
Link: [DEV][ROM][1.1.] CyanogenMod 10.1 (Android 4.2.1) - ZTE Blade / Libra ROMs & ROM customisation - MoDaCo
_____________
Changelog
29.3.2013 changelog:
  • updated Effem and other FM related updates (thanks to daemond)
  • possible fix for texture corruption on some rare occasions (thanks to daemond)
  • increase PIE controls trigger area and allow PIE controls without enabling expanded desktop
  • change default cpu governor to smartassv2
  • more Ad-Hoc changes (1,2,3)
  • compiled using AOSP gcc 4.7 toolchain
24.3.2013 changelog:
  • included daemond's Effem (FM Radio) app
  • fixed audio routing and FM Radio volume control issues (thanks to C3C0)
  • backported bluetooth UHID driver - added support for bluetooth input devices (thanks to plaguedbypenguins)
  • pie controls (1,2,3,4,5)
  • semi-working Ad-Hoc support (open networks) (1,2,3,4,5,6)
  • phone: Make going to call log after call optional (1)
  • am: Allow more hidden apps on devices with lots of RAM (1) + limit max background processes
  • Use jpegOptimized bootanimations (1)
  • new Apollo (merged)
6.3.2013 changelog:
  • FM radio with RDS support (thanks to daemond)
  • qcom-fm: audio: add support for FM feature (1,2,3)
  • FM Radio: avoid deadlock when disabling RDS (1)
  • update KGSL from CAF, fixes GPU out of memory issues (i.e. white textures, thanks to daemond)
  • disable camera hdr
  • disable hw acceleration on lockscreen
  • fix navbar height option
  • bring back Apollo music player
  • Apollo: Fetch album art from media provider if present (1)
  • new Superuser (merged)
20.2.2013 changelog:
  • framework: fix rotation of electron beam animation (1)
  • removed couple of non-standard/useless features (e.g. persistent notification when headphones are plugged in)
15​.2.2013 changelog:
  • Android 4.2.2
11​.2.2013 changelog:
  • reverted commits (1,2) that caused 'Process system isn't responding' issue on every reboot
10.2.2013 changelog:
  • included czech and portuguese (pt_PT) dictionaries
  • surface texture enhancements (thanks to daemond)
  • call statistics (merged)
29.1.2013 changelog:
  • hardware vsync events (thanks to daemond)
  • fixed some audio routing issues (thanks to daemond)
  • fixed messed up u/v plane alignment in some videos (thanks to daemond)
  • Custom lock screen background (1,2)
  • option to toggle dimming of the notification shade (1,2)
19.1.2013 changelog:
  • Fix restoring network mode preference on reboot (1)
  • Mms auto-retrieval (1,2,3)
  • Wifi tethering: disable wow and add wakelock (thanks to daemond)
15.1.2013 changelog:
  • build hwcomposer and fake vsync events
  • fixed native wifi tethering (thanks to daemond)
  • fixed squished pattern/sim unlock screen
12.1.2013 changelog:
  • fixed bluetooth (thanks to Ganster)
  • set correct permissions for boostpulse (now it actually works
  • enabled divx and wma hw decoding (thanks to Ganster)
  • Added flip and shake to snooze (1)
6.1.2013 changelog:
  • fixed charger mode detection
  • fixed missing videoplayer controls
  • fixed video playback in portrait mode
  • fixed messed up third party camera apps (Camera 360, Barcode scanner, etc)
  • SystemUI: always use transparent notification shade (1)
5.1.2013 changelog:
  • fixed hardware video decoding/encoding, e.g. YouTube HQ, HTML5 playback, Camcorder, etc (thanks to Ganster, psyke83 and everyone else involved)
  • fixed camera preview glitches (thanks to psyke83)
  • NavigationBar : Customization (1,2)
  • NavigationBar: Custom height (1,2)
  • Allow purging of asset bitmaps (1)
  • added option to disable bootanimation
1.1.2013:
  • backported USB gadget driver from msm-3.0 kernel (thanks to WaylandACE)
    • fixed native USB tethering
    • fixed issues with apps failing because of borked usb0 interface (e.g. network speedtest apps)
  • switched to wpa_supplicant_8
  • added power hal and boostpulse support to ondemand governor
  • Quick Settings: Swipe to switch (1)
  • Add persistent notification when headphones are plugged in (1)
  • CyanogenMod clock widget - Chronus (merged)
21.12.2012:
  • new world order
_____________
Download:
cm-10.1-20130329-KonstaKANG-blade.zip
http://www.mediafire...jibb4nlfaan9w44 (mirror)
md5:fe14bbd451e952abf881857d59d27b3f
gapps-jb42-20130307-KonstaKANG.zip
http://www.mediafire...ss5khtjf9a5v4s9
md5:8545baba12c25aab6c849595eb96827d
Reaktionen: Einstein67
Läuft ganz gut! ABER ohne Bluetooth und ohne "s2e" (für mich) leider nicht zu gebrauchen.
Schadeeeeeee ;)
Das CM10 (4.1.2) läuft schon länger prima! Für das BLADE reicht das auch schon dicke, da andere low end andriods meist mit 2.1 oder 2.2 "enden".
4.2 (und was noch kommt) wird sich nur für bessere (besserer ARM7 und 1 GB RAM) wirklich lohnen.
Sehr Guter Mod, nutze ich seit Weihnachten im Alltag... Wenn jemand auf Bluetooth verzichten kann, optimale Version... Sehr smooth, lädt schnell, guter akkuverbrauch...
kann ich nur empfehlen!
EDIT: Wie ich in der neusten Version sehe, wurde nun auch Bluetooth (dank Ganster) integriert! ;)
Schadeeeeeee ;)
Bluetooth geht ab der 12.01. CM10.1 Version.
Ich nutze Link2SD - geht astrein mit EXT SD Card partition.
Habe jetzt von CM10 auf CM10.1 "rübergemacht" :)
muss ich, wenn ich von cm7 auf diese rom wechsel, eine full wipe ausführen, oder schickt auch schon ein kleiner wipe?
Beim Wechsel von 2.3.7 auf 4.2.1 denke ist auf alle Fälle ein FullWipe nötig! Meine Apps (gesichert unter 2.3.7) hab ich danach mit TitaniumBackup wiederhergestellt und die laufen perfekt.
Seit gestern gibts übrigens wieder eine neue Version: mit nativen WiFi-Thetering :) Es läuft somit nun alles ausser UKW-Radio
ok, ich habe ein backup mit rom manger gemacht.
Daneben ist es noch wichtig, dass du genug Platz auf der Systempartition hast. 160 MB sind das absolute Minimum.
Wer per TPT (für CM7) da nur weniger System hat (dafür mehr DATA) muss das zuerst umparttionieren (mit nem 160MB+ TPT).
hab die sd karte komplett formatiert.
-Ich bekomme leider "Root all Data 2 sd" auf meinem frisch installierte ZTE CM 10.1 nicht zum laufen.
Obwohl die App eine Partition erstellt hat lässt sich diese nicht mounten. :crying:
Root all Data 2-App:
Mouten --> Receiving Information -->/storage/sdcard0/rallsd/storage
Size: 1,0KB od 512 MB Storadge is not mounted.
Klicke dann auf "Mount" --> Mount attempt wird angezeigt und das wars.:cursing: Alternative Einstellungen? Andere App? To do?
- Gibts eine Möglichkeit wie beim Paranoid-Mod von der cm7 den Prozessor intelligent zu Takten?
Danke :thumbup:
Gruss
Dafür kannst du die eingebauten Features verwenden, im CyanogenMod-Leistung Untermenü. Oder jede beliebige CPU-App, wie zB FrillCPU.
Die Entwickleroptionen zur aktivieren mit 7 mal klicken das muss man auch erstmal wissen.. und dann hatte ich auch das was ich wollte.
Gruss
LINK2SD (free) funzt prima - auch mit CM 10 , CM 10.1 (plus ext SD Partition) - zudem hast du damit die Kontrolle, was von den Apps auf den ext Speicher geht und was nicht.
@mitchde: Danke für deine Info.. das hat ich auch schon unter anderen Roms am laufen gehabt.. wollte aber das "Root all data" weil LINK2SD nicht wirklich alle Dateien auf die SD schiebt.
Der ursprüngliche Beitrag von 19:23 Uhr wurde um 19:33 Uhr ergänzt:
Ich habe noch zwei weitere Fehler..
Unter Facebook kommt stätig ein Banner mit.
"Netzwerkfehler" Weisse Schrift auf schwarzem Grund. Obwohl Facebook an sich funktioniert und alle Neuigkeiten heruntergeladen werden.
An meiner WLAN-Netzwerkonfiguartion am Router wurde nichts geändert.. es funktionoert eigentlich alles tadellos über WLAN beim ZTE
(Browsers, Mails u.s.w.)
Desweiteren wird der untere Teil der Uhr im Tasensperren-Screen abgeschnitten. Da ich die optische "Navigationbar" nutze.
Einstellungen -> System -> "Show navigation bar". Ist diese Funktion deaktiviert wird die Uhr richtig angezeigt.
Was habe ich schon probiert!?
Man kann ja theoretisch die Grösse des "Uhr-Widgtes" auf dem Tastensperre-Screen vergrössern es lässt sich dann aber nicht speichern wie ich später festellen musste.
Oder ich weiss nicht wie man das macht. Genauso ist es wenn ich z.B. das Widget "Uhr+Wetter" auf den Screen der Tastensperre ziehe.
Es wird mir angzeigt doch wenn ich später zur Tastensperre zurückkehre um zu entriegeln ist die "halbe Uhr" wieder da obwohl ich die Uhr mit dem Wetter dahingezogen hatte.
Danke für eure Hilfe
meine Freundin hat das Blade und ich hab's auf CM10.1 geupdated, allerdings
verliert sie sporadisch die 3g Verbindung und bekommt sie scheinbar erst wieder wenn sie das Handy neustartet. In der Statusleiste steht dann auch "keine Internetverbindung". Ich habe schon versucht das Internet nur auf 2G zu reduzieren, das hat aber auch nicht geholfen.
Installiert habe ich die Rom natürlich mit Fullwipe.
Hat da vielleicht jemand einen Tipp?
Könnte sein das die Kontaktflächen der Antennen nicht richtig anliegen.
Habe auch aktuell das CM10.1 (4.2.1) drauf . Läuft einwandfrei und schnell mit unserem Oldi :wubwub:.Habe bei meinem auch einen generell schlechten Empfang gehabt.Akkudeckel ab , alle Schrauben raus und vorsichtig mit einem Kunststoffkeil"ch"en aufhebeln. Gehäusedeckel entfernen. Jetzt siehst du unten und oben die Federkontakte der Antennen (GSM/WLAN). Vorsichtig und leicht nach oben "biegen" , nicht übertreiben.Jetzt wieder vorsichtig zusammenbauen. Seitdem ist der Empfang um Welten besser...
Reaktionen: Ranas
Bei mir auch alles OK mit dem Internet und Cm10.1
Mag auch sein, dass gerade mal der Provider nicht gut genug bei der Position war um eine stabile Verbindung fürs Internet herzustellen. DATA ist empfindlicher als das reine Telefonieren, was Signalstärke bzw. Störsignale anbelangt.
habe diese Rom vom 6.3.2013 drauf und wollte die Spracheingabe bei Nachrichten (Whatsapp) über das Mikrofon nutzen,
jedoch kommt unmittelbar nach Drücken der Mikrofontaste immer die Meldung: "Das wurde nicht erkannt. Bitte sprechen Sie erneut."
Das gleiche wird auch bei der Googlesuche über Mikrofon angezeigt.
Was mache ich hier falsch? Oder muss noch etwas nachträglich installiert werden?
Die Einstellungen unter Sprache und Eingabe bin ich auch schon durchgegangen, jedoch keine weiteren Einstellmöglichkeiten gefunden!?
arcsi
Nasemann
  • eckart.t
Auro
