XMasterNinni
ich würde burstlam's RC04 verwenden läuft flüssiger und hat multitouch
Barry schrieb:Gibts eigentlich schon einen Fix um die erhaltenen gmail Emails lesen zu können?
START {act=android.intent.action.VIEW flg=0x20020000 cmp=com.google.android.calendar/com.android.calendar.selectcalendars.SelectSyncedCalendarsMultiAccountActivity} from pid 2843
I/AudioHardwareMSM72XX( 102): set device to SND_DEVICE_SPEAKER device_id=0
I/AudioHardwareMSM72XX( 102): Enabling post proc features with mask 0x0000
D/dalvikvm( 174): GC_FOR_ALLOC freed 228K, 14% free 15476K/17991K, paused 126ms
D/AndroidRuntime( 2843): Shutting down VM
W/dalvikvm( 2843): threadid=1: thread exiting with uncaught exception (group=0x40a021f8)
E/ActivityThread( 2843): Failed to find provider info for com.android.calendar
E/AndroidRuntime( 2843): FATAL EXCEPTION: main
E/AndroidRuntime( 2843): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.google.android.calendar/com.android.calendar.selectcalendars.SelectSyncedCalendarsMultiAccountActivity}: java.lang.NullPointerException
E/AndroidRuntime( 2843): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1956)
E/AndroidRuntime( 2843): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1981)
E/AndroidRuntime( 2843): at android.app.ActivityThread.access$600(ActivityThread.java:123)
E/AndroidRuntime( 2843): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1147)
E/AndroidRuntime( 2843): at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 2843): at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 2843): at android.app.ActivityThread.main(ActivityThread.java:4424)
E/AndroidRuntime( 2843): at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2843): at java.lang.reflect.Method.invoke(Method.java:511)
E/AndroidRuntime( 2843): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
E/AndroidRuntime( 2843): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
E/AndroidRuntime( 2843): at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 2843): Caused by: java.lang.NullPointerException
E/AndroidRuntime( 2843): at com.android.calendar.Utils.matrixCursorFromCursor(Utils.java:279)
E/AndroidRuntime( 2843): at com.android.calendar.selectcalendars.SelectSyncedCalendarsMultiAccountActivity.onCreate(SelectSyncedCalendarsMultiAccountActivity.java:62)
E/AndroidRuntime( 2843): at android.app.Activity.performCreate(Activity.java:4465)
E/AndroidRuntime( 2843): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1049)
E/AndroidRuntime( 2843): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1920)
E/AndroidRuntime( 2843): ... 11 more
W/ActivityManager( 174): Force finishing activity com.google.android.calendar/com.android.calendar.selectcalendars.SelectSyncedCalendarsMultiAccountActivity
W/ActivityManager( 174): Force finishing activity com.google.android.calendar/com.android.calendar.selectcalendars.SelectVisibleCalendarsActivity
XMasterNinni schrieb:einfach lange die power taste drücken -> Screenshot!
mitchde schrieb:Kommt da nicht das Auschaltmenue? ( auschalten, reboot, recovery,...) ?
ManZen schrieb:Hi,
gibt es irgendwo einen DOwnloadlink der Alphas oder wenigstens einen Hinweis darauf.
Habe hier im Thread keinen gefunden.
Danke und Grüße
XMasterNinni schrieb:CM9 Alpha 5.1
Hier der link zum Modaco Thread für CM9 alpha 5.1:
[ROM] Cyanogenmod 9 (Android 4.0.3) - Android @ MoDaCo - Page 24
Hier der DL link für die alpha 5.1:
UploadKing.com - free file storage & hosting
CM9 Alpha 5 mit Multitouch
Habe auch eine Multitouch version gefunden..laggt aber noch ziemlich..
hier der DL link:
cm9-alpha5-multitiouch-signed.zip
Die normale Facebook App funktioniert nur wenn man den Browser - Patch installiert hat. Durch ihn funktionieren auch Gmail oder Google Reader.
Hier der Browser Patch: (einfach in CWM flashen)
browser_tempfix.zip - File Shared from Box - Free Online File Storage
Ansonsten kann man auch Black Facebook installieren (Facebook mit schwarzem Design), dass sollte auch ohne Patch funktionieren...
Hier der DL - Link zu Black Facebook:
Black.Facebook.apk (1,92 MB) - uploaded.to
___________________________
If nothing goes right, go left!
