ZTE Blade L3 - Stock Rom 5.0.2
  • 147 Antworten
@tigran0705
Hey bro, what kind of simlock do you mean?
Do you have dl910?
Did you try the method?
Ya.I tried walton Rom for Dl910 and couldnt unlock it..
Olso tryed lenovo rom for l3 and easy unlock with default china phons unlock code..
Hey,
@tigran0705
Did you try my CM Port?
Thanks
@No3ight
No.I only comment Walton and maybe Aurora Dl910 Roms are simlocked!!!
The dl910 and l3 are same devices and it should works for both...
What happend when u try to unlock in engineer mode?
Password failure?
@blant7000
firstly.there are 2 models l3 for EU two band (5.0.2) 2016 and three band(5.0) 2015.CLARO Dl910 OS is LP 5.0. DL910 has 1 sim card(second is blocked via software) and prelocked from network CLARO provider.free unlock is too dificult...
I flash on my three band l3 with WALTON ROM and couldnt unlock it trough 12345678 code...
@tigran0705
Hmm ok.
But 1 sim is unlocked?
U can call?
@blant7000
no.second slot wont to recognize.first only after valid code!!!
tigran0705 schrieb:
@blant7000
hey i had the same problem with a older DL910 rom on my phone, with locked sim, but i installed "Aurora DL910" via twrp 2.7 and this time there is no sim lock everything works nice with aurora rom
Root works but xposed is not properly installed, just flash the xposed zip again with TWRP :Index of /framework/sdk21/arm/
take sdk21-v86 for Arm.
thx blant7000 aurora rom is good one
Reaktionen: blant7000
hmm... ich bin zwar selbst inzwischen aufn anderes Fon umgestiegen, aber ich hab das meiner freundin nun zerschossen. Gerootetes L3, Werksreset->Bootloop. und ich bin zu doof es wieder hinzukriegen. mit SP hauts nicht hin, der Download startet erst gar nicht. könnt ihr die Info aus diesem thread nochmal dummymäßig und wasserdicht aufarbeiten, dass auch dussel rincee das auf die reihe kriegt? Oder schubst mich einfach mal in die richtige Richtung, wenns das schon gibt.
@Rinceei
if download dont started and open some window,firstly try to format memory.you can find this button next reight from download button
@tigran0705, ill give it a shot....
@Rincee
You wont to reinstall stock Rom?
still nothing.
wiped all, even the calibration data. keeps nagging me with missing files. i try to solve the following issue: Me Girlie has performed a factory reset on a rooted l3, and it got stuck in a bootloop. Right now, after several tries, the phone doesnt even start, and SMFT keeps nagging me with missing files. i just want to reset the phone to stock.
@Rincee
you mean bootloader.bin?
@tigran0705, have no idea... i simply want it to run again
[doublepost=1484395364,1484395312][/doublepost]aint there any way to just blow all the needed data into the phone via usb, and get it running?
try to flash via other version of spflash tool..
any stock rom available?
which Rom You have?
pheew... german version of the l3, no idea
V
  • VerzweifleAmBladeL3
VerzweifleAmBladeL3
V
crazyballheads
Teo5584
