ZTE Blade L3 (How to update?)
  • 9 Antworten
AleksandarOlah
Hi, i have ZTE Blade L3 (single sim, work with all operators).my phone is not rooted now and i dont habe update to official 5.0.2 i have 4.4.2 kitkat on it.I need that official update or some better custom rom (work all options and play store) and tutorial how to install .
sorry for bad english
No , i have Classic L3. On link is a custom roms.Im from Europe too
Go to the zte support site and the country Greek then choose zte blade l3 then download the Greek ROM.
Yep, if you have normal L3 you can use the greek ROm
To be sure here are pics of opened L3 and L3 plus : SIM cards have different locations.
i have normall zte blade l3 and kitkat HR vip on it (croatia) i download the
Greece Blade L3 SD card upgrading instruction & software package(ZTE HELLAS Telecommunications S.A)-277880B0475DIS_EU_B128DL_P182A20V1.0.0
put on sd card (32gb,transcend 60ms/s uhsI) and then about phone/system update manager/storage card update. the phone rebote and start install rom and then againg rebot and nothing i have my old softvare with apps (its not rooted)
ROM on phone is
Croatia Blade L3 SD card upgrading instruction & software package(VIPNET)-277310B0395VIP_HR_QB128S_P182A20V1.0.0
google translate
Ich habe normall ZTE Blade l3 und kitkat HR vip darauf ( Kroatien) i die Download
Griechenland Blade- L3 -SD-Karte Upgrade Anweisung & Software-Paket ( ZTE HELLAS Telekommunikation S.A. ) -277880B0475DIS_EU_B128DL_P182A20V1.0.0
setzen auf SD-Karte ( 32gb , transzendieren 60ms / s uhsI ) und dann über Telefon / System -Update-Manager / Speicherkarte zu aktualisieren. das Telefon rebote und installieren starten ROM und dann rebot und nichts againg ich habe meine alte softvare mit Anwendungen ( es ist nicht verwurzelt )
ROM am Telefon ist
Kroatien Blade- L3 -SD-Karte Upgrade Anweisung & Software-Paket ( VIPNET ) -277310B0395VIP_HR_QB128S_P182A20V1.0.0
@AleksandarOlah
rolituba schrieb:
We are pleased to welcome you here in this forum, the world's most popular Internet platform of the German speaking Android community.
Therefore, according to our rules, all contributions have to be written in German language! Hence, if you are not able to write in German, please use a translator (e.g. such as those of Google and many others).
Thank you for your understanding.
Wir freuen uns Dich hier in diesem Forum, der weltweit beliebtesten Internet-Plattform der deutschsprachigen Android-Community, begrüßen zu dürfen.
Daher müssen entsprechend unseren Regeln alle Beiträge in deutscher Sprache geschrieben werden! Verwende daher bitte, wenn du der deutschen Sprache nicht mächtig bist, einen Übersetzer (wie z. B. jenen von Google und vielen anderen).
Danke für dein Verständnis.
i try bosnian rom and install it. but there is no update (only for language 5MB not for lollipop) the greek i cant install they start about 30% and restart
ich versuche bosnian ROM und installieren. aber es gibt kein Update (nur für Sprache 5MB nicht für Lutscher ) der griechischen i installieren sie kippen beginnen etwa 30% und Neustart
i try spain and wont install like greece
I found !!! thanks to all
Reaktionen: hagex
ROM on phone is
google translate
ROM am Telefon ist
I think both ROMS are the same version (1.0.0 = 5.0). So you cant see any changes.
There is no ROM to DL with 5.0.2 for my knowledge.
Only the 5.0.2 (1.0.2) Update OTA (WLAN).
I denke beide ROMS haben die gleiche Version 1.0.0 = 5.0.
Es gibt wohl keinen ROM Download mit Version 1.0.2 = 5.0.2
Das geht nur über das OTA Update (WLAN).
From which country are you?
