Redmi Note 6 Pro Bricked? Testpoint EDL Failed to open SDCC
  • 0 Antworten
Diefaulequalle
Hallo, ich versuche gerade das Telefon meiner Freundin zu fixen und beisse mir die Zähne aus. Nach 3 Abenden Herumprobieren mit verschiedenen ROMs, MiFlashs etc... frage ich jetzt doch mal lieber euch. Ich hänge mal den LOG hier ran. Vielleicht weiß ja einer was da falsch läuft. Vielen Dank im Voraus!
Code:
[01:21:43  COM8]:MiFlash 2021.2.26.0
[01:21:43  COM8]:vboytest index:8
[01:21:43  COM8]:flash in thread name:COM8,id:24
[01:21:43  COM8]:sw in images
[01:21:43  COM8]:vboytest do open :
[01:21:43  COM8]: serial port COM8 opend successfully
[01:21:43  COM8]:[COM8]:start flash.
[01:21:44  COM8]:cannot receive hello packet,MiFlash is trying to reset status!
[01:21:45  COM8]:try to reset status.
[01:21:45  COM8]:清理端口数据,准备发送SAHARA_SWITCH_MODE_PACKET
[01:21:45  COM8]:Switch mode back
[01:21:45  COM8]:cannot receive hello packet,MiFlash is trying to reset status!
[01:21:45  COM8]:received hello packet
[01:21:45  COM8]:programmertype: 0
[01:21:45  COM8]:vboytest:C:\rom\images
[01:21:45  COM8]:download programmer file: C:\rom\images\prog_emmc_firehose_Sdm660_ddr.elf
[01:21:45  COM8]:download programmer C:\rom\images\prog_emmc_firehose_Sdm660_ddr.elf
[01:21:53  COM8]:Send done packet
[01:21:53  COM8]:file C:\rom\images\prog_emmc_firehose_Sdm660_ddr.elf transferred successfully
[01:21:55  COM8]:send nop command
[01:21:55  COM8]:send command:<?xml version="1.0" ?><data><nop verbose="0"  value="ping"/></data>
[01:21:55  COM8]:get response from target
[01:21:55  COM8]:resdump:<?xml version="1.0" encoding="UTF-8" ?>
<data>
<log value="Binary build date: Aug  2 2018 @ 22:27:53"/>
</data><?xml version="1.0" encoding="UTF-8" ?>
<data>
<log value="Chip serial num: 4294967295 (0xffffffff)"/>
<data>
<log value="Supported Functions: program configure nop sig firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase "/>
<data>
<data>
<log value="fh.attrs.Verbose is set to 0"/>
<data>
</data>
[01:21:55  COM8]:Chip serial num: Chip serial num: 4294967295 (0xffffffff)
<data>
<data>
<response value="ACK" />
</data>
[01:21:55  COM8]:send configure command
[01:21:55  COM8]:send command:<?xml version="1.0" ?><data><configure verbose="0" AlwaysValidate="0"  ZlpAwareHost="1"  MaxPayloadSizeToTargetInBytes="131072" MemoryName="emmc" SkipStorageInit="0"/></data>
<data>
<log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/>
<data>
<response value="ACK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="131072" MaxPayloadSizeToTargetInBytesSupported="131072" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Aug  2 2018 - 22:27:53" />
</data>
[01:21:55  COM8]:max buffer sector is 256
[01:21:55  COM8]:open program file C:\rom\images\rawprogram0.xml
[01:21:55  COM8]:Write file C:\rom\images\storsec.mbn to partition[storsec] sector 512
<data>
<log value="ERROR: Failed to open the SDCC Device slot 0 partition 0"/>
<data>
<log value="ERROR: Failed to open the device 1 slot 0 partition 0"/>
<data>
<log value="INFO: Device type 1, slot 0, partition 0, error 0"/>
<data>
<log value="WARN: Get Info failed to open 1 slot 0, partition 0, error 0"/>
<data>
<log value="storage_device_get_num_partition_sectors FAILED!"/>
<data>
<log value="parseSectorValue could not handle start_sector value"/>
<data>
<response value="NAK" />
<data>
<log value="ERROR: XML not formed correctly. Expected a &lt; character at loc 0"/>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<log value="ERROR: XML not formed correctly. Expected a &lt; character at loc 1"/>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
<data>
</data>
<data>
<data>
<data>
<data>
</data>
[01:21:56  COM8]:no Binary dump
[01:21:57  COM8]:no Binary dump
[01:21:58  COM8]:no Binary dump
[01:21:59  COM8]:no Binary dump
[01:21:59  COM8]:flashSuccess False
[01:21:59  COM8]:isFactory False CheckCPUID False
[01:21:59  COM8]:before:flashSuccess is False set IsUpdate:True set IsDone True
[01:21:59  COM8]:after:flashSuccess is False set IsUpdate:false set IsDone true
[01:22:00  COM8]:no Binary dump
[01:22:01  COM8]:no Binary dump
[01:22:01  COM8]:System.Exception
   bei XiaoMiFlash.code.bl.SerialPortDevice.WriteFilesToDevice(String portName, String swPath, String rawFilePath)
   bei XiaoMiFlash.code.bl.SerialPortDevice.FirehoseDownloadImg(String swPath)
   bei XiaoMiFlash.code.bl.SerialPortDevice.XiaomiFlashNew()     bei XiaoMiFlash.code.bl.SerialPortDevice.WriteFilesToDevice(String portName, String swPath, String rawFilePath)
Klaus986
ProfNuke
ProfNuke
ProfNuke
little.fico
