svenni1985
Stamm-User
- 213
Weekly ist eine Developer. Stable die ausgereifte dafür nicht ganz aktuelle.
System
Optimization - Background CPU processes caused performance issues (05-16)
Optimization - Delayed response for charger's notifications (05-19)
Fix - Wireless display caused reboots (05-19)
Fix - Read mode appeared more red than it should be (05-19)
Fix - Draining battery while using GPS in some cases (05-19)
Fix - Bluetooth turned on automatically with the device (05-19)
Settings
New - Introducing Shortcut menu. Check out the new MIUI 8 feature early. You can turn it on in Additional settings. (05-17)
Mi Cloud
New - Added "Back up now" feature for fast backups (05-19)
(Ido, libra, leo, aqua, kenzo, wt88047, wt86047 delayed)
Added Touch Assistant from MIUI 8 to all devices
CHANGELOG
Gallery
New - Deleting synced photos from internal storage without deleting from Mi Cloud (05-25)
Cleaner
Optimization - Accessibility support (05-24)
Fix - FC issues (05-24)
Added toggle for Cast (6.0 devices)
We released Redmi 2 4.4 roms for those who cant update to 5.1 or dont want to...
We will not update stables MIUI 7 anymore and will focus on MIUI 8 weekly/stables only...
This is last MIUI 7 version..!
May.27th - 6.5.26 will be our last update for MIUI 7 Weekly ROM
June.1st - MIUI 8 China Alpha/ Experimental ROM Release
June.3rd to Jun.16th - MIUI 7 ROM weekly update will be suspended
June.17th - MIUI 8 Weekly ROM will be officially released.
Supported devices:
Mi 2/ Mi 2S/ Mi 3/ Mi 4/ Mi 4C/ Mi 4S/ Mi 5/ Mi Max/ Redmi series/ Redmi Note series/ Mi Note series
Du bist auf Global stable? Dachte du bist bei eu.rom. AktivMuhamed schrieb:Stable gibt es keine Regel. Hab bis jetzt alle drauf gehabt und nutze die von mitte Mai. Läuft sehr sehr gut!
TWRP ist immer neuste Version (official)
Bei xiaomi.eu gibt es nicht nur dev roms ^^yarali schrieb:Du bist auf Global stable? Dachte du bist bei eu.rom. Aktiv
Our system is being updated and we will be back soon guys
