linuxnutzer
Enthusiast
- 179
Das Foto wurde innen mit Standort Energiesparmodus mit OpenCamera gemacht, Breite und Länge geändert, Höhe war wirklich 0.
Crop-Faktor also 5,8
Brennweite 22mm (35mm Äqu.)
Code:
[ExifTool] - ExifTool Version Number : 10.55
[File] - File Name : IMG_20170830_220119.jpg
[File] - Directory : .
[File] - File Size : 3.4 MB
[File] - File Modification Date/Time : 2017:08:31 13:28:11+02:00
[File] - File Access Date/Time : 2017:08:31 13:34:47+02:00
[File] - File Inode Change Date/Time : 2017:08:31 13:34:47+02:00
[File] - File Permissions : rwxr-xr-x
[File] - File Type : JPEG
[File] - File Type Extension : jpg
[File] - MIME Type : image/jpeg
[File] - Exif Byte Order : Big-endian (Motorola, MM)
[File] - Image Width : 3000
[File] - Image Height : 4000
[File] - Encoding Process : Baseline DCT, Huffman coding
[File] - Bits Per Sample : 8
[File] - Color Components : 3
[File] - Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
[EXIF] 0x0110 Camera Model Name : MI MAX 2
[EXIF] 0x0100 Image Width : 3000
[EXIF] 0x0202 Other Image Length : 3499
[EXIF] 0x011b Y Resolution : 72
[EXIF] 0x010f Make : Xiaomi
[EXIF] 0x0112 Orientation : Unknown (0)
[EXIF] 0x0011 GPS Img Direction : 190.46
[EXIF] 0x0007 GPS Time Stamp : 20:01:09
[EXIF] 0x0005 GPS Altitude Ref : Above Sea Level
[EXIF] 0x0010 GPS Img Direction Ref : Magnetic North
[EXIF] 0x0002 GPS Latitude : 1 deg 1' 1"
[EXIF] 0x001b GPS Processing Method : ASCII
[EXIF] 0x0006 GPS Altitude : 0 m
[EXIF] 0x001d GPS Date Stamp : 2017:08:30
[EXIF] 0x0004 GPS Longitude : 2 deg 2' 2"
[EXIF] 0x0001 GPS Latitude Ref : North
[EXIF] 0x0003 GPS Longitude Ref : East
[EXIF] 0x0131 Software : oxygen-user 7.1.1 NMF26F V8.5.5.0.NDDMIED release-keys
[EXIF] 0x011a X Resolution : 72
[EXIF] 0x829a Exposure Time : 1/63
[EXIF] 0x8822 Exposure Program : Not Defined
[EXIF] 0x9101 Components Configuration : Y, Cb, Cr, -
[EXIF] 0x829d F Number : 2.2
[EXIF] 0xa403 White Balance : Auto
[EXIF] 0xa002 Exif Image Width : 3000
[EXIF] 0x9004 Create Date : 2017:08:30 22:01:19
[EXIF] 0x9290 Sub Sec Time : 505734
[EXIF] 0x9292 Sub Sec Time Digitized : 505734
[EXIF] 0xa402 Exposure Mode : Auto
[EXIF] 0xa405 Focal Length In 35mm Format : 22 mm
[EXIF] 0x9003 Date/Time Original : 2017:08:30 22:01:19
[EXIF] 0xa001 Color Space : sRGB
[EXIF] 0x9291 Sub Sec Time Original : 505734
[EXIF] 0xa003 Exif Image Height : 4000
[EXIF] 0x9203 Brightness Value : 0
[EXIF] 0xa000 Flashpix Version : 0100
[EXIF] 0x9201 Shutter Speed Value : 1/63
[EXIF] 0x9209 Flash : Off, Did not fire
[EXIF] 0xa301 Scene Type : Directly photographed
[EXIF] 0x9202 Aperture Value : 2.2
[EXIF] 0x8827 ISO : 200
[EXIF] 0x0001 Interoperability Index : R98 - DCF basic file (sRGB)
[EXIF] 0x920a Focal Length : 3.8 mm
[EXIF] 0x9208 Light Source : Unknown
[EXIF] 0x9000 Exif Version : 0220
[EXIF] 0xa406 Scene Capture Type : Standard
[EXIF] 0x9207 Metering Mode : Average
[EXIF] 0xa217 Sensing Method : One-chip color area
[EXIF] 0x0101 Image Height : 4000
[EXIF] 0x0132 Modify Date : 2017:08:30 22:01:19
[EXIF] 0x0128 Resolution Unit : inches
[EXIF] 0x0201 Other Image Start : 1117
[EXIF] 0x0213 Y Cb Cr Positioning : Centered
[EXIF] 0x0103 Compression : JPEG (old-style)
[EXIF] - Other Image : (Binary data 3499 bytes, use -b option to extract)
[Composite] - Aperture : 2.2
[Composite] - GPS Altitude : 0 m Above Sea Level
[Composite] - GPS Date/Time : 2017:08:30 20:01:09Z
[Composite] - GPS Latitude : 1 deg 1' 1" N
[Composite] - GPS Longitude : 2 deg 2' 2" E
[Composite] - GPS Position : 1 deg 1' 1" N, 2 deg 2' 2" E
[Composite] - Image Size : 3000x4000
[Composite] - Megapixels : 12.0
[Composite] - Scale Factor To 35 mm Equivalent: 5.8
[Composite] - Shutter Speed : 1/63
[Composite] - Create Date : 2017:08:30 22:01:19.505734
[Composite] - Date/Time Original : 2017:08:30 22:01:19.505734
[Composite] - Modify Date : 2017:08:30 22:01:19.505734
[Composite] - Circle Of Confusion : 0.005 mm
[Composite] - Field Of View : 78.6 deg
[Composite] - Focal Length : 3.8 mm (35 mm equivalent: 22.0 mm)
[Composite] - Hyperfocal Distance : 1.27 m
[Composite] - Light Value : 7.3
