I need help please, don't turn on my Xiaomi Mi A3!!!
  • 4 Antworten
karma09
karma09
Hi.
1.Try
Overnight charging/not working
2.Try
charge the phone and at the same time press and hold the power button/not working
3.Try
Fastboot and Recovery Mode do not work do not enter them:cry:
P.S. I couldn't turn on my phone after I installed ROM's Evolution X and + the notification light comes on but it doesn't vibrate and nothing is heard and it can't be seen I tried with a flashlight to see if anything can be seen on the display but nothing and when I tried to install Evolution X I had Error 21 and that's it
Hi. This is a German Forum, so pleask speak German or let Google translate it fot you. Thanks:)
Otherwise: Have you tried to check XDA for the ROMs thread? For my it sounds like you bricked the A3 ...
Reaktionen: karma09
thx, btw fow i can un bricked my a3?
WickJohn
WickJohn
WickJohn
Poenni
Dayworker
