MIUI Custom Roms für das Xiaomi 11T Pro
  • 52 Antworten
OK.
die bat dateien von dieser xiaomi.eu_multi_XM11TPro_V14.0.4.0.TKDMIXM_v14-13.zip Rom
windows_fastboot_first_install_with_data_format.bat
@echo
off
cd %~dp0
set fastboot=bin\windows\fastboot.exe
if not exist %fastboot% echo %fastboot% not found. & pause & exit /B 1
echo Waiting for device...
set device=unknown
for /f "tokens=2" %%D in ('%fastboot% getvar product 2^>^&1 ^| findstr /l /b /c:"product:"') do set device=%%D
if "%device%" neq "vili" echo Compatible devices: vili & echo Your device: %device% & pause & exit /B 1
echo You are going to wipe your data and internal storage.
echo It will delete all your files and photos stored on internal storage.
set /p choice=Do you agree? (Y/N)
if /i "%choice%" neq "y" exit /B 0
echo ##################################################################
echo Please wait. The device will reboot when installation is finished.
%fastboot% set_active a
%fastboot% flash abl_ab images\abl.img
%fastboot% flash aop_ab images\aop.img
%fastboot% flash bluetooth_ab images\bluetooth.img
%fastboot% flash cpucp_ab images\cpucp.img
%fastboot% flash devcfg_ab images\devcfg.img
%fastboot% flash dsp_ab images\dsp.img
%fastboot% flash dtbo_ab images\dtbo.img
%fastboot% flash featenabler_ab images\featenabler.img
%fastboot% flash hyp_ab images\hyp.img
%fastboot% flash imagefv_ab images\imagefv.img
%fastboot% flash keymaster_ab images\keymaster.img
%fastboot% flash modem_ab images\modem.img
%fastboot% flash qupfw_ab images\qupfw.img
%fastboot% flash shrm_ab images\shrm.img
%fastboot% flash tz_ab images\tz.img
%fastboot% flash uefisecapp_ab images\uefisecapp.img
%fastboot% flash vbmeta_ab images\vbmeta.img
%fastboot% flash vbmeta_system_ab images\vbmeta_system.img
%fastboot% flash xbl_ab images\xbl.img
%fastboot% flash xbl_config_ab images\xbl_config.img
%fastboot% flash boot_ab images\boot.img
%fastboot% flash vendor_boot_ab images\vendor_boot.img
%fastboot% flash cust images\cust.img.0
%fastboot% flash cust images\cust.img.1
%fastboot% flash super images\super.img.0
%fastboot% flash super images\super.img.1
%fastboot% flash super images\super.img.2
%fastboot% flash super images\super.img.3
%fastboot% flash super images\super.img.4
%fastboot% flash super images\super.img.5
%fastboot% flash super images\super.img.6
%fastboot% flash super images\super.img.7
%fastboot% flash super images\super.img.8
%fastboot% flash super images\super.img.9
%fastboot% flash super images\super.img.10
%fastboot% erase metadata
%fastboot% erase userdata
%fastboot% reboot
windows_fastboot_update_rom.bat
@echo off
cd %~dp0
set device=unknown
%fastboot% reboot
Bearbeitet von: Anz - Grund: Beitrag bearbeitet. Gruß Anz
Komisch bei mir öffnet sie gar nicht, nicht Mal das Admin Fenster kommt aber die noob Rom gefällt mir
Nutze den Total Commander damit geht es . Hast du die Noob 1.1 ? Gibt gerade sehr viel Auswahl zum Wechseln da kann man sich kaum entscheiden :D
Ja habe die 1.1 also die ganz neue
Noch eine neue MIUI FiveK Edition .
Changelog​
October 31, 2023
• Based on Eu Rom 14.0.4.0.
• Debloated.
• Rom Full R/W
• Default Kernel Is Perf.
• Added 5k Customization (check SS).
• Added Unlimited Gphotos By Default.
• Adedd Mi Account On Top In the Settings.
• Moded Launcher by Kashi v3.
• Aded Storage Tab as default instead of Recent In MIUI File Manager.
• Moded Themes, Security Center, File Manager, and Screen Recorder.
• Added 4 volume column.
• Paid widgets & Super Icons unlocked For Free.
• Added extra dim.
• Added Notification history.
• Added IOS Emojis.
• Added screenshot frame.
• Added Wallpapers By 5K.
• Added Paid Leica Camera With LAB Option.
• Added Harmon Kardon Audio.
• Unlock 60&90 Fps in Pubg and Many Games.
• Adedd Gaming Features SightGun & Combo And Gpu Tuner.
• Added China App Vault.
And Many More Things ...........
Nicht schlecht je mehr Roms es gibt desto besser aber da find ich die noob ui besser
Hab sie mal installiert Einstellungen ohne Ende allerdings teilweise in Englisch .
Läuft bisher ohne Probleme mal sehen wie es mit dem Akku aussieht . Da ich mein Handy als Hotspot nutze wa das bei der EvolutionX ein Problem nach 3-4 Std wa Schluss.
Sieht er aus wie eine Kopie von der Noob UI. Ja bis es komplett auf Deutsch erscheint dauert es und auf der Noob UI bitte ich manchmal auch so lange Hotspot und gar keine Probleme gehabt
So muss schreiben die Noob Rom 1.1 ist gut ABER sie startet manchmal das Gerät am Tag gefühlt 1-2 mal Neu und sobald man YouTube guckt startet er das Gerät immer nach 30min neu also mitten im Video friert das Gerät ein. Habe YT gelöscht und wieder installiert hat aber nichts geändert. Suche jetzt weiter nach dem diesen Problem aber falls sich nichts ändert muss ich leider die ROM wechseln vielleicht die MIUI SR weil die HyperOS Rom ja noch auf Englisch ist
Hab jetzt auch alle MIUI Roms durch nicht eine ist Fehlerfrei wechsel wieder Zur EvolutionX EOL Final Build . Heute kam eine Hyper OS Multilanguage für das Poco F5 Pro das lässt hoffen das wir auch bald in den genuss kommen ! Obwohl alles noch Beta . Werd also so bald nicht wechseln !
Bleib doch bei der Noob UI YouTube funktioniert wieder fehlerfrei. Natürlich gibt es den ein oder anderen Bug bzw Fehler das kann man leider nicht ändern, nicht desto trotz gibt es Roms für das 11T Pro. Kann man bei EVO den RAM erweitern? Finde es auf dem anderen Gerät nicht
Ram Erweiterung bei EVO geht meines Wissens nicht . Werde mal die Noob 1.2 testen .
Die 1.2 Version hat einen anderen Kernel
