TechPad - 7 Inch Android Tablet-Booting Problem
  • 3 Antworten
Seleme190
Ich habe bei meinem Tablet PC ein Problem aber ich weiß nocht was ich tuen soll... Es ist ein mal passiert und imma wieder das selbe Problem. NAchdem ich das Gerät einschalte, es bleibt immer hängen...was soll ich überhaupt machen?
Sie können das Problem beim video besser beobachten....
YouTube - SNB17926
Die Eigenenschaften von diesem Gerät;
Manufacturer Specifications
  • Primary Function: Android Internet Tablet
  • Screen: 7 Inch Touchscreen LCD
  • Screen Type: Resistive
  • Screen Resolution: 800*480
  • CPU Processor Speed: Samsung S3C6410(ARM11/800MHz)
  • Internal Memory/ROM: 1GB
  • External Memory: Micro SD Card up to 8GB (Not included)
  • USB Flash Drive Support: Yes, up to 16GB
  • Memory/RAM: 256MB DDR
  • Battery Type: Polymer Lithium-ion battery (7.4 V)
  • Battery Capacity: 1800 mAh (5-6 hour of constant use)
  • Speaker: Built-in 2W
  • Earphone Slot: Yes, 3.5mm
  • Mic: Built-in high sensitivity mic
  • Wireless Interface: WiFi 802.11b/g
  • Software
    Operating System:Android 1.6
    Google Marketplace: Yes
    Browser: Google Browser
    Pictures: JPG, BMP, PNG, GIF
    Audio: WWMA, MP3, WAV, AAC
    Video: 3GP, MPEG4, H.263, H.264 (Many more can be supported by third-party software!)
    Support: Office Word, Excel, PPT
    Reader: TXT
    Email: Gmail
    GPS: Google Maps (Internet-based GPS only)
    Languages: English, German, French, Italian, Japanese, Polish, Chinese (Traditional + Simplified), Russian, Korean
  • Dimensions(L*W*D):190mm * 120mm * 10.5mm
  • Manufacturer Ref: AND07TABLET
Product Notes
  • Download your favorite apps through the Android Marketplace!
  • TV out lets you view the TechPad Android Tablet on your large screen TV
  • Browse the internet for free with WiFi!
  • Why wait for the Samsung Tablet and iPad 7 inch version when you can get the TechPad now, and at an amazing wholesale price!
  • Note: The Android OS version on this device cannot be upgraded or flashed and any attempts to modify the default OS will void the warranty. As a wholesaler, Chinavasion provides no software support, advice, or training regarding the Android operating system and software.
Package Contents for CVGY-PC07
  • TechPad Android Tablet
  • Earphones
  • Mini USB Cable
  • Micro USB Cable
  • AV Cable
  • User Manual - English
  • Free Travel Adapter (for UK, AU, NA, SA customers)
Danke im Voraus...
Ins richtige Unterforum verschoben... :)
Vielen Dank....
Ich hoffe dass jemand mich auch zur Lösung führen kann....;)
mfG
Warum schreibt keine irgendeine Lösung....ich habe im Forum auch durchgesucht aber ich bin nicht auf die richtige Lösung gekommen....ich bitte um die Hilfe von den Experten....
büdde büdde....
lg
easonlee
Skyhigh
Skyhigh
  • fri-wollo
fri-wollo
ses
prx
