(VRTHEME) Red Illusion for Samsung Jelly Bean Roms S3/Note2/Jkay
  • 17 Antworten
EdgA
EdgA
Enthusiast
1.332
[VRTHEME][JKAY][14/02]*Red Illusion*_For Samsung Jelly Bean [LLA/MR2]
"Red"]Everything is themed in any resolution! In any samsung rom 4.1.2! Approximately 5.000 images png's edited!
NOTICE
"""So guys, I am getting many request that my theme is ported to other roms, but it is difficult, is no small thing to do, are hours in front of a PC, editing details and details, and then flash, flash for testing.
** I will focus on this last rom (wanam XXEMR2), the rom seems more used, and honestly, it's easier for a user to update their device, what I have to do difrerentes versions of my theme.
** I'll leave here a theme also no "resouces", which makes it compatible with any rom (sammy) but without all themed, this because the file "color.xml" of secsettings and framework-res need to be edited, the theme is not complete without them .. (95%) ...
** Sorry to all who want to use my theme as a template, or use my images, moderators, I did not authorize it, I'll finish it, it is not complete yet, spend hours in front of my computer, for other people to take credit, that I I did. I'm sorry, I'm not being selfish (even because my icons "myfiles" are not mine, belong to "vertmus" a great Themer here on xda.
If someone wants to use the icons that are standard in android, okay, battery, signal, togles okay, but the styles of windows and buttons, I do not give permission, because that would be to me a copy, and that's not cool. .
** I may not be recognized as a Themer here, but be assured that I made this theme alone, and make others wait, I'm just getting started ... lol
** So my message is:
** "They can use my icons", which already help a lot, it's tiring having to convert multiple images to RBG -> gimp, then edit them -> photoshop, a process is boring and tiring, I know, because I had to do with all, but do not copy the style of the theme, please .. """""
DialerWidget.apk - full themed
FlashBarService.apk - full themed
MusicPlayer.apk - full themed
MyFiles.apk - full themed
SecContacts.apk - full themed
SecPhone.apk - full themed
SecSettings.apk - full themed
SimpleFavoritesWidget.apk - full themed
SystemUI.apk - full themed
Twframework-res.apk - full themed
Framework-res.apk
ClockPackage.apk
Quote:
Update 26/01
Dialler/Contacts themed
Added support Galaxy Note II
Quote:
Update 28/01
Full Jkay compatible
Quote:
Update 29/01a
H+ corrected
Dialler full themed
GT-I9300 universal version (Jkay & all Sammy 4.1.2 ) ...
Quote:
Update 29/01b
+ Framework-res.apk
+ Secsettings.apk
+ SecCalculator2.apk
+ DialerWidget.apk
+ SamsungWidget_FavoriteApp.apk
Quote:
Update 30/01a
Text notifications
Signal icons
More and more images in framework-res and systemUI ...
Quote:
Update 04/02a
Galery Samsung
Keyboard Samsung
others...
Quote:
Last Changes--08/02
Buttons Yes/no (black button, white text)
Edit xml's in several apps
SystemUI (finished)
SecSettings (finished)
Adjusted bar background apps (not more transparent, tinted now)
adjusted color tones icons in statusbar
mms.apk (finished)
Myfiles.apk(finished)
MusicPlayer.apk (control icons resized)
Updated package Jkay
Widgets Mono. Negative Colours, Turn off all Sounds, Assistive Light (Transparent now, better visual)
Red Ilusion Theme ***** updated in 14/02 (XXELLA)
Red Illusion Theme ***** updated in 14/02 (XXEMR2)
S3 Keyboard -cmw
Theme for Launcher Apex/Nova *****updated in 08/02
Red_Illusion_Galaxy_Note_II_JedyXP9-31a.zip --31a
Free Online Storage - MediaFire -- Theme For Launcher
Pulser, Lennyuk, and disclosed for making this efficient system theming, just downloaded the template and started doing the theme without any problem ..
oae08, for the great help on the details,
Reaktionen: valia16
sieht sehr schick aus!
gibts das auch ohne den on-screen buttons (unten) ?
Das ist nicht dabei, das kommt durch das jkay framework, ist ein/aus schaltbar, nennt sich Navigation bar
-> geTAPA'd vom S3 <-
Hallo ihr lieben wollte mal fragen: hab die Dateien runter geladen und wollte sie installieren. Nun wie soll ich den vorgehen? ich stelle es mir so vor dass ich die jeweiligen .apk's mit Root Explorer ersetze... wäre das ok oder geht es evtl. einfacher?
Danke in voraus für eure Hilfe!
Galaxy S3 mit JB 4.1.2 (original) und Root
Du musst das theme im recovery flashen, ich hoffe du hast root, und eine deodexed Rom drauf, und vorher ein nandroid backup machen, ist immer sicherer :)
Also gerootet ist es. Was ist eine deodexed Rom? Eine Nandroid hab ich aber vom Handy damals gemacht und gesichert bevor ich das erste mal überhaupt am Handy rum gefummelt habe.
Das in Recovery Modus geflasht werden soll? Meinste in diesen CWM rein und von dort die Zip datei installieren?
Bitte tut mir leid aber ich hab zwar was darüber gelesen ZU SEHR hab ich mich auch nicht damit beschäftig also bitte ein bissl Geduld haben....trotzdem danke!
hmmm... also wirst du ne Stock Rom drauf haben (Stock ist odexed)
du hast bestimmt nur root und nichts anderes oder? also keine custom rom?
die sind meistens deodexed, steht meistens im thread im ersten Post mit drin...
dann müsstest du entweder eine custom rom flashen oder es lieber sein lassen mit dem roten theme, weil sonst wird dein Handy mit großer Sicherheit in ner bootloop hängen :p
ansonsten lies dich ein bisschen in dem custom rom thread ein, ist alles nicht so schwer wie es aussieht :)
Wollts grade mal testen das theme,aber für die JKay 14.91.2 passt es wohl noch nicht :-D
doch für das aktuellste jkay 14.91.3 geht es, aber atm nur für sie ELLA fw, aber er updated jetzt auf EMR2 :)
Ahso , bin mit EMA2 unterwegs, dann ists kein Wunder dass es nicht ging.
gibt wohl bootloops mit der 14.92 Version
___________________
sent by
stockED-GAlaxy_Rom
+boeffla-kernel
dann wird das Grüne wohl auch nicht laufen, warten wir halt ein paar Tage mit dem flashen.
Jup, aber wird glaub ich nicht allzu lange dauern ;)
___________________
sent by
stockED-GAlaxy_Rom
+boeffla-kernel
leonardoaraujo schrieb:
Guys, I know I'm a time out, I'm on vacation, returning with several new features, colors, and more colors, white, yellow, green, blue, yellow, pink, wait!! A tip, aroma vrtheme + + illusion. ;)
___________________
sent by
stockED-GAlaxy_Rom
+boeffla-kernel
