Masta_Gee81
Enthusiast
- 5.404
☆☆☆☆☆[THEME]ICS Blue Mod V4 100% Compatible with ICS & Jelly Bean
I want to share my theme, is created with some PNG's from other roms, and all the rest is created or moded and resized by me.
What's themed?
-Contacts
-Gallery
-Phone
-SystemUI (Stock and Lidroid)
-Music app & widget
-Job Manager
-My files
-Browser (Only launch icon)
-Camera (Only launch icon)
-Lock screen (Blue clock and removed accuwheather text from weather information)
-Downloads
-Settings
-Calculator
-Clockpackage
-Framework (all is themed: blue progress bar, TW menus, popups, icons, ICS tittle bars..)
PREVIEW:
ADVISE
This is an universal theme, works on any Rom, and ONLY change PNG's files. Some users have reported problems with the battery icon. If you want to fix this error donwload the MOD.zip attached below, and flash through the recovery. You have two fixes, with blue clock, and with blue centered clock.
MOD BATTERY ICON AND ADD BLUE CLOCK ARE ONLY FOR FIRMWARES FROM XXBLFB TO XXBLG9 ROMS
MOD WITH BLUE CLOCK
Multiupload.nl - upload your files to multiple file hosting sites!
MIRROR
BLUE BATTERY FIX SystemUI.zip
Note: If you can't see the blue icons on notification bar after installation of fix, reinstall the Blue theme.zip again.
MOD WITH BLUE CENTERED CLOCK
MIRROR
Blue-Center-Clock.zip
PREVIEW OF V4
Changelog:
-Added the missing themed parts in the new JB Roms.
-Fully compatible with JB and ICS in the same package.
-Now the theme is compatible with Turkbey Rom and Dragon Rom(Settings and big weather icons)
-New weather icons in lock screen.
-Everything is optimized for more speed and free RAM.
-And more I forgot.
*DONWLOAD ICS BLUE MOD THEME V4*
EXTRAS:
ADD BLUE SUBTEXT MENUS AND BLUE PROGRESS BARS (UNIVERSAL WORK ON ICS & JB)
DONWLOAD:
ICS BLUE subtexts Mod.zip
MIRROR:
INSTALLATION
1-Put the downloaded .zip on your internal o external memory (depending on your recovery)
2-Reebot in to Recovery
3-Select Install zip from SD card
4-Select my theme, and press install
5-Reboot and enjoy!
---------------OLD DONWLOADS---------------
ICS BLUE MOD V3
MIRROR
Galaxy SIII ICS Blue Mod V3.zip
ICS BLUE MOD V2
MIRROR
ICS Blue Mod Theme V2.zip
ICS BLUE MOD THEME V1
THANKS TO:
Lexulde, Kalagas,Dragon and Turkbey for your parts of theme.
XDA THREAD
