[MOD] Nexus Navbar
  • 9 Antworten
NemesisRE
25
Auf Basis von graffixnyc and labbe-´s MOD
Ich habe ein universelles Paket für jedes Galaxy S3 (INT, D2ATT, D2TMO, D2VZW and D2SPR)
erstellt welches ursprünglich für CM10 war, nun sollte dieser MOD auf jedem AOSP basierten Android 4.x
Rom laufen, es werden nur Keybinding Änderungen und ein Eintrag in der build.prop gemacht.
Bei Fragen oder Problem bitte im Original Thread auf XDA melden
Please don´t forget, when you use this mod that it can (should not but can) change how your system works so before you report rom related bugs in the rom developer thread, you should use the remove package to make sure the issue is not caused by the mod!
Confirmed to work on:
  • CyanogenMod 10 Preview
  • SlimICS
  • Stock (with some glitches)
NAV_Only: none of the hardware keys are enabled (except Volume and Power)
NAV_HomeWake: Home button wakes device but has no other function
NAV_HomeCamera: Long press Home button opens Camera and takes Pictures but has no other function
NAV_StockKeys: Functions as normal but with on Screen Navbar
NAV_Remove: Removes the mod
DOWNLOAD
Install Instructions:
- Boot into recovery
- make a Backup
- flash with CWM
- reboot
This should work on any device with the same keybindings:
Code:
key 172	HOME
key 158	BACK
key 139	MENU
In the this files:
Code:
/system/usr/keylayout/sec_touchkey.kl
/system/usr/keylayout/gpio-keys.kl
/system/usr/keylayout/sec_keys.kl
Code:
#include <std_disclaimer.h>
 * Your warranty is now void.
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this Mod
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you. Hard. A lot.
Cheers
Steven
Reaktionen: p4nik, Mason2k10 und Meister Popper
Anzeige
  • Gerade eben
  • Neu
Läuft bei mir auch unter XXLG8 einwandfrei :D
Neue Version ist online.
Diese überlebt nun auch ein Rom update, d.h. CM Update benutzen ohne danach noch mal ins recovery zu müssen :biggrin:
Was genau bewirkt dieser Mod
Könnte einer Screenshots liefern ?
Gesendet von meinem mit Jelly Beans gefütterten Quad Core Monster
Kennst du das Galaxy Nexus? Das hat ja keine Hardware-Keys und keine Sensor-Tasten sondern auf dem Display diese NavBar, an der unteren Seite. Da ist halt so ein Zurück-, Home und Menü - Button. Diese hat man dann praktisch auch auf dem S3. Dann sind die anderen Tasten, Power und Lautstärke Tasten ausgeschlossen, ohne Funktion.
Grüße
Gesendet von meinem GT-I9300 mit Tapatalk
Reaktionen: jonathanj
Jedes mal wenn ich es ändere und das sgs3 neustarte bleibts beim alten.
Wenn du was änderst? Bleibt was beim alten ?
Sry.. Wenn ich die zip flashe.. Egal welche. Hab es auch schon mit manueller eingabe gemacht, war aber das gleiche Problem.
Welche Android Version nutzt du?
Wannamlitr 5.6
Hab den fehler gefunden, lag daran dass ich nur den free root Explorer benutzt habe. Die full gekauft und jetzt läufts
