teddy3
Dauer-User
- 283
Download der verschiedenen Versionen im Thread bei xda: [MOD+GUIDE][V3][10.06]Modified TouchWiz Home&App Drawer - xda-developersModified TouchWiz by Toss3Features:
- Wallpaper Scrolling: On/Off
- Home Screen in all sizes: 4x5, 4x6, 5x5, 5x6
- App Drawer in all sizes: 4x5, 5x5, 5x6
- Custom Combinations to suit everyone
Requirements:
- Root
- Deodexed ROM
ScreenShots:HomeScreens:
4x5, 4x6, 5x5
5x6
App Drawer:
4x5, 5x5, 5x6
Install Instructions:
- Choose combination of []x[]Home[]x[]AppDrawer[SCR]Wallpaper Scrolling On or Off .apk
- Backup SecLauncher2.apk in /system/app
- Rename the downloaded SecLauncher2xxxxx.apk to SecLauncher2.apk
- Move the renamed .apk to /system/app and replace the old SecLauncher2.apk(make sure the name is exactly the same, otherwise you will have two different versions)
- Reboot
Thanks To:*GUIDE* Available HERE
(sind einfach zu viel, die möchte ich nicht alle hier anhängen)
Der ursprüngliche Beitrag von 14:09 Uhr wurde um 14:11 Uhr ergänzt:
Known Issues:
- Widget Scaling problems (should work okay with 4x6 Home Screen)
- Microstuttering (Stutter is worse with 5x6 than with 4x6, as well as with Wallpaper Scrolling On rather than Off)
- Recommended Version: SecLauncher2_4x6-5x6_SCR-off.apk
Modified Framework:
Features:
- Disable Scrolling Cache(not recommended in ICS)
Voraussetzungen:
- Root
- Deodexed ROM (Stockrom geht nicht, da odexed)
