• Wartungsarbeiten am Mittwoch (23.04.): Serverumzug ab 10 Uhr - Android Hilfe nur im Lesemodus verfügbar, alle Infos.
[MOD] 1% battery for your ROM
  • 4 Antworten
Cpt
Cpt
Dauer-User
1.252
1% Batterieanzeigen Mod für jede Rom oder auch Stock Firmwares z.B die Aktuelle XXALE8
torxx schrieb:
Here you will find some 1% battery mod's by Big_Balls and me! (look in the credits who contributed)
In the first post you will find the general information, in the second post all flashable files for the recovery by Big_Balls.
>>>>>>Download section<<<<<<
For everyone who wants to do it on his one or sees that his firmware is not supported a little how-to.
How-to port them yourself
  • Download one image file pack (look under the images) and extract the .rar
  • Take any modded SystemUI.apk
  • Get the SystemUI.apk of your ROM of /system/app (either with root explorer or with adb pull /system/app/SystemUI.apk)
  • Place your SystemUI.apk in place-apk-here-for-modding of your apktool/apkmanager folder
  • Use apktool/apkmanager to extract the images (no need to decompile/compile) with option 1
  • Look inprojects of your apktool/apkmanager folder for your SystemUI.apk
  • Go to /res/drawable-xhdpi and replace the images with your favorite battery icon files.
  • Zip the SystemUI.apk back with option 3 (as a system app)
  • In place-apk-here-for-modding you should find an unsignedSystemUI.apk
  • Rename it to SystemUI.apk and push it to /system/app (either with root explorer or with adb)
  • You also get a Flash Script for the Recovery, just place the SystemUI.apk in /system/app and delete the README.txt then
  • Then flash in recovery
How-to get back to stock
  • Grab the back to stock SystemUI.apk
  • Push it to /system/app with root explorer or adb
  • Or use the Flash Script
Battery image's
Image files (Android)
Image files (bubble)
Image files (circle AOSP)
Image files (honeycomb)
Image files (sensestock)
Image files (senseblue)
Image files (digits)
Image files (gauge)
Image files (gaugeics)
Credits
  • jotha
  • he_stheone64
Please appreciate the work and push the thanks button if use this work!
more will follow for sure..
Auch als .zip über CWM für XXALE8/XXALF2 odexed und für Omega V4
Big_Balls schrieb:
Here are all versions as flashable zip file for XXALE8 to start.
The used firmware is always included in the filename.
I will also include everytime a back to stock zip to fully uninstall this mod.
This mod use 102 png´s for battery status (0-100%,status unknown)
and 102 png´s for the charge animation (0-100%, full) (all included in the packs of torxx)
For XXALE8 odexed:
downloads
For XXALF2 odexed
downloads
For Omega V4:
downloads
QUELLE
Reaktionen: Gene S und dickerkäfer
XXALF2 wird heute noch folgen:D
edit: XXALF2 ist nun online!
Reaktionen: Cpt
Tja. Mit dem HTC One s nicht aufgepasst. Die verschiedenen Flash Dateien heruntergeladen. Eins nach m anderen im One s geflasht und jedes mal die Meldung Installation aborted bekommen.
Mir gedacht dann im gleichen durchlauf auch die back to stock Version durchlaufen lassen und bei der kam dann im bootloader Flash Bereich Bein installieren von der de Karte dass die Installation erfolgreich war und reboot System ausgewählt!
Nun geht das One s s4 weder an noch in den bootloader! :-(
Hat jemand je Ahnung wie ich an mein Handy wieder rankomme?
hhspeed, wer soll aus dem grammatikbefreiten Buchstabenbrei schlau werden? Hast du nun ein S4 oder in One S?
Verfasse den Beitrag in ordentlicher Rechtschreibung und Grammatik, damit deine Frage auch verstehen kann. Andernfalls kannst du keine Antwort bekommen.
Er hat ein One s mit dem s4 Prozessor -.-
Gesendet von meinem ST21i mit der Android-Hilfe.de App
supergrobi94
supergrobi94
supergrobi94
Marvis
Masta_Gee81
Odin666
Odin666
