Masta_Gee81
Enthusiast
- 5.396
Mit diesem Theme holt ihr alles aus eurem S-Amoled + Display !!!
Ich habe es mir über die Omega Black Blue (was auch dieses Theme nutzt)gezogen ... Und es ist einfach nur WOW!!! Check it Out !!! Greetz M@sta
Glass Icons Thread by Dully Check it Out : [Skin] AOSP ic_menu icons *Universal Theme* - xda-developers
Veränderungen gegenüber der "normalen Omega black Blue" sind:
1. Statusleiste
2. Dialer
3. Tw Rechner
3. Fm
4. Icons
und vieles mehr .....
1. Statusleiste
2. Dialer
3. Tw Rechner
3. Fm
4. Icons
[Universal Theme][FOR ALL TW ROMS] Phone Candy v3-Colour Burst
Before i start:
You are more than welcome to use any of MY images from this theme. However if you do use any of MY images please don't be a pirate, show some consideration and respect for the people who spend their spare time on various projects and ask, or at least give credit
I can even provide psd's if necessary.
FAILIURE TO FOLLOW THE RULES(#12) AND YOU WILL BECOME THE VICTIM OF TEA-BAGGING!!
***DON'T KNOW WHAT TEABAGGING IS
CLICK ME TO FIND OUT
Intro:
Basically i wanted a big, bright, colourful theme to get the most out of my SAMOLED screen. What is the point using a theme containing just 2 colours, black and white, when the screen has 16Million colours!!!. Sure you might get slightly better battery life but that's what chargers are for. You don't get a dog and bark yourself, or eat a tea bag and drink the hot water. Same as you dont buy a supercar and drive everywhere at 30mph, so why not maximise your screen display and let the beast off the leash.
Whilst trying to create widgets to tie in with the theme i ended up creating something similar to esk02k's from his clear glass theme here, except his look much better,
Also as this theme is nearing completion ive decided to change the WIP name from john doe to Phone Candy, hope you like it and thanks to the people who suggested names.
Contents:
Post 1 Info and Screenshots
Post 2 Universal Theme, MetaMorph Theme and links
Post 3 Add ons
READ THIS
What Theme works on what Rom:
Morph:
ALL TW based GB Roms
Universal Theme:
**The universal theme is highly recommended**ALL TW based GB Roms
There will be some images i've missed or forgotten!!. If you find any bugs let me know (prefably with a screenshot) and i'll try fix it ASAP.
I've tried to theme "everyday apps", so far the following has been edited/modified:
- Theme support for Jkay Mod (JKay Mod NOT INCLUDED!!!.)
- AxT9IME.apk (android keyboard).
- Browser.apk.
- Calendar.apk (AOSP) it's the same as TW Calender.apk!!.
- ClockPackage.apk
- Contacts.apk.
- Email.apk
- Gallery3D.apk (AOSP).
- Gmail.apk
- framework-res.apk.
- GoogleQuickSearchBox.apk
- LatinIME.apk (AOSP android keyboard).
- MediaProvider.apk
- Mms.apk
- Music.apk (AOSP).
- MusicPlayer.apk
- Phone.apk.
- Settings.apk
- SystemUI.apk.
- TouchWizCalculator.apk
- TouchWizCalendar.apk
- TwCalendarAppWidget.apk
- Vending.apk
- twframework-res.apk(APPLY EVEN IF NOT USED AS IT CONTROLS SOME IMAGES)
- Youtube.apk
- Fonts (replaces "DroidSans.ttf and DroidSans-Bold.ttf) Only included in Metamorph theme, Attached to bottom of post 3
ScreenShots:
MORE SCREENSHOTS
To apply the metamorph theme follow the instructions below:
1. Install metamorph (link in second post)
2. Install BusyBox if required (link in second post)
3. Download the morph file
4. Run metamorph
5. Choose "extract new theme" and navigate to the saved destination and click john doe**
6. After it finishes unzipping Choose "pick existing theme",
click john doe**/john doe.xml
7. Apply options ONE AT A TIME in case of random reboot, if you get a force close, reboot and carry on where you left off
8. Reboot
9. Enjoy.
You can also just apply the things you like, for example if you only like the "dialer" then just apply "Contacts" and "Phone"
Finally:
Always try to apply themes on a fresh Rom install.
Most importantly.......... Enjoy.
And
BACKUP!! BACKUP!! BACKUP!! BACKUP!! BACKUP!!
DONT SAY YOU WASNT WARNED.
Universal Theme engine presents Phone Candy.
What does the "Universal Theme" mean??,
It should work on all TW roms!!. It's basically a flashable metamorph theme.
How to install:
*Hit thanks.
*Download.
*Boot into recovery
*Choose install zip
*Locate and flash.
Please note that it can take some time to install depending on the number of items.
It will also create a log and backup in sdcard/universal themes/ which can be flashed via CWM recovery to restore previous setup.
If you download my work hit thanks or rate the thread. If your generous, both. Thank you
Links:
v4
If you already have v3.1 flash the increment update below over it:
v4 Add-On
BELOW IS THE LINK TO THE 1300 IMAGES I HAVE PERSONALLY CREATED.
ALTHOUGH I HAVE IN SOME WAY MODIFIED 95% OF THE OTHER 1800 IMAGES WITHIN PHONE CANDY, I CANNOT TAKE CREDIT FOR THE CREATION, SO I HAVE LEFT THEM OUT.
*Images i created contained within Phone Candy
How to install:
Simply download, place on your SD Card and flash from CWM recovery.
Does not contain features like CRT off or circle battery
Special thanks again to JRsoft and Intronauta over
HERE for the universal theme zip and Alexullde for making me aware of the theme zip.
v3
Links and older zip's:
I recommend the inverted Gmail app created by ecsnead69 here
also a blue market which can be found here
Here is how to gain a new battery using UOT kitchen:
How to install:
*Hit thanks.
*Download.
*Boot into recovery
*Choose install zip
*Locate and flash.
Links:
v4
v4 Add-On
How to install:
v3
- metamorph
- busybox
- John Doe v1.5 MORPH
- Phone Candy v1 MORPH
- Phone Candy v1 Universal Theme Zip
With progress_horizontal.xml
Phone Candy v2 Universal Theme Zip
Without progress_horizontal.xml - Villain Rom v2.4.2 John Doe v1.5 based CWM flashable theme (inc crt + circle battery)
- Get your "framework-res.apk", there are many methods to do this, i'll let you pick one.
- Go HERE and click the "file upload" tab, select "system files" and upload your framework-res.apk. To avoid problems please us a CLEAN framework-res.apk
- Now click the "battery" tab, check "use this mod", click "Custom battery", any of these styles will modify your framework to give you 100 charging and 100 discharging images.
- Scroll down to the bottom and select a charging animation style, I would reccomend hybrid.
- Click the "summary" tab and "submit work to kitchen"
- Wait for the kitchen to cook your files then flash your new framework from CWM
- Once flashed you can then flash the Universal theme on top.
- Enjoy esk's battery mod
Here is a link for a esk02k's CWM flashable glass orb battery mod zip, it will theme all the relevant battery images gained from above method:
esk02k battery orb mod
Preview
And here is a link for my Power Battery mod:
Phone Candy Power Battery
Preview
Both links are in universal theme format.
Quelle : [Universal Theme][FOR ALL TW ROMS] Phone Candy v3-Colour Burst - xda-developers
P.S. Danke drücken kostet nix
