[THEME][XXKI4] Ice Cream Sandwich Theme v2.1
  • 57 Antworten
elfeins111
elfeins111
ICE CREAM SANDWICH THEME 5.0
by BigBangHD
Funktionen/Informationen
  • Work on all XXKI4, XWKJ2, XWKJ3 DEODEXED Firmware
  • ICS Transition Animation
  • New Phone.apk (Redesigned by ME)
  • New Mms.apk
  • Sonysketch & Roboto font preinstalled
  • White text on dark background
  • New Trasparent Lockscreen: 3 different Icons
  • All Apps Modded
  • Original ICS Statusbar Icons
  • From Ice Cream Sandwich and Galaxy Nexus:
    - Ice Cream Sandwich Launcher 2.4 (Redesigned by ME) *
    - ICS Analog Clock *
    - Wallpapers *
    - Sound: Notifications, Ringtones, Alarms, UI *
    - Bootanimation *
    - Music App *
    - Settings Icon (Added by ME: Call, Motions and Privacy icon)
    - Statusbar Icon (Modded by ME)
    - New Battery percentage icon (Designed by ME)
    - Application Icon (Calculator, Email, Camera (HW button and improve audio & video), Gallery, Talk (with video), Settings, Browser (with User Agent), Messaging (Muveszur's mod), Phone (call rec + no autorotating), Contacts, Videos)
  • Folder Icon like ICS (Designed by ME)
  • Aosp Lockscreen from Black Android (thanks to Nitroz and Pele)
  • Modded Notification Bar: Galaxy Nexus style
  • Full support for Jkay v12.1
  • New ICS Dialer by ME
  • Overscroll Blue
  • Dark APM
  • Modded Advanced Power Menù icons
  • Dark pop-up
  • ICS Blue Progress Bar
TESTED ON:
  • CheckROM RevolutionHD 2.0.0
  • CheckROM RevolutionHD 3.0.0
  • CheckROM RevolutionHD 3.1.1
  • Batista70 FoxHound Edition 2.4
  • Batista70 FoxHound Edition 2.5
  • Batista70 FoxHound Edition 2.6
Screenshots
Download
**DOWNLOAD CENTER**
Theme version:
XXKI4 - v5.0
XWKJ2 - v5.0
XWKJ3 - v5.0
ICS Addons:
Mods:
- ICS Icons
- Nexus Prime Bootanimation
- Sound Restore
Launchers:
- Ice Creamed ADW Launcher
- Ice Creamed GOLauncher EX
- Ice Creamed TW4.5
Apps:
- ICS Clock Package
- ICS Search Box
Animations:
- FlyIn
- Flip
- Bounce
- Rudolf
- Stock
Installation
- Download the .ZIP file (don't unzip)
- Copy the .ZIP file to your SD Card (INTERNAL)
- Boot your phone into CWM (hold Vol Up, Home & Power Button)
- Clear cache and dalvik cache
- Select 'Install ZIP from SD Card'
- Select 'Choose Zip from SD Card'
- Select the .ZIP file you downloaded\
- Reboot
- Enjoy
Changelogs
17.11.2011 / v5.0
- The package install the apps: Calculator, Email, Camera (HW button and improve audio & video), Gallery, Talk (with video), Settings, Browser (with User Agent), Messaging (Muveszur's mod), Phone (call rec + no autorotating), Contacts, Videos
- New Phone.apk
- Many bug resolved
- FULL: only Lock Screen Addons in your SDcard
- LITE: Lock Screen and Launcher Addons in your SDcard
- Other grafic improvements
15.11.2011 / v4.0
- The package doesn't install any app, change only images
- All ICS Addons are in SDcard
- ICS Transition Animation: ICS Transition Animations For CyanogenMod 7 Galaxy S - YouTube
- New Phone.apk (Redesigned by ME)
- New Mms.apk
- Sonysketch & Roboto font preinstalled
- White text on dark background
- New Trasparent Lockscreen: 3 different Icons
- All Apps Modded
- Original ICS Statusbar Icons
06.11.2011 / v3.0
- Dialer redesigned by ME
- Black Notification Bar
- Dark Advanced Power Menù
- Blue titlebar
- New menù pop-up
- New subtext color (most intense)
- New select icon
- New progressbar
- Blue APM icons
- Editing all ICS app
- New statusbar icon
- And other changes
31.10.2011 / v2.1
- Moved the ICS Launcher from /data/app to /system/app
31.10.2011
- Redesigned ICS Launcher
- Sonysketch font by default
- Folder Icon like ICS (Designed by ME)
- New ICS Dialer by ME
- Statusbar ICS Icon (Modded by ME)
- Dark pop-up
- Application Icon (Camera (HW button), Talk (with video), Browser (with User Agent), Messaging (Muveszur's mod))
- Modded Notification Bar
- Modded vibrate icon
- New ICS Percentage Battery
- And other changes
24.10.2011
- Initial Release (in Kitchen App)
Quelle: XDA
-Freigehalten-
Funktioniert das mit jeder Rom (in meinem Falle Villain Rom 3.0)? :)
Es wird mit der Villain Rom 3.0 nicht funktionieren, da dieses ROM noch auf XXKI3 basiert, wenn ich mich nicht irre.
Dieses Theme läuft nur auf XXKI4 2.3.5 ROMs.
Funktioniert des dann auf Cyanogen? Des ist bei mir nämlich auf ki4 allerdings mit der Version 2.3.7
Das Theme ist nicht Cyanogen kompatibel, da die modifizierten Applikationen (.apk) auf Android 2.3.5 basieren. Würdest du es installieren, dann wird es wahrscheinlich zu Problemen kommen. Du kannst unter Cyanogen doch den Theme Chooser verwenden, da gibt es noch genügend andere Themes :D
Mach ich sowieso, allerdings hab ich bisher noch nicht wirklich die Theme für mich gefunden die mir auch wirklich gefallen würde. :-/
Wenn Du nicht fündig wirst, probier doch mal dein eigenes Theme zu erstellen ;)
hmm, hab ich was verpasst? ich hab KI4 aber bin auf 2.3.4?!
Es gibt die KI4-2.3.4 und KI4-2.3.5 :)
Hi, hab das Thema mal geladen. Wie bekomme ich denn den
Ice Cream Sandwich Launcher 2.4 und z.B. die analog Uhr. Bei mir ist weiterhin Launcher Pro aktiv.
Launcher Pro beenden & "ICS_2.4_Launcher_2.apk" starten ;)
Funzt so nicht. Habe den Launcher Pro beendet und bin direkt über Taskmanager nach /data/app und hab die ICS Launcher installiert. Danach zurück auf den Homescreen und Laucher Pro wurde neugestartet.
Normalerweise müsste direkt nach Installation des neuen Launcher die Abfrage kommen welchen Launcher ich verwenden möchte. So kenn ich es zumindest von anderen Launchern.
PS: Hab gesehen in der Kitchen gibt es schon die V3 von diesem Theme. Gibts noch ein Changelog dazu :)?
Keiner eine Idee!?
Menü - einstellungen - anwendungen - anwendungen verwalten - launcher pro - standartwerte löschen
Gegebebenfalls ICS Launcher aus dem Market ziehen. Schau in den xda Thread, da gibt es ICS Themes für alle Launcher.
Thread wurde geupdatet, ist im Startpost zu finden!
moin...
ma ne frage...unter der xda-quelle sind ja die verschiedenen animationen. installiere ich die auch einfach über
"volume nach oben - homebutton-off" ??
sorry wenn's n bissel OT is..
gruss
Genau - einfach das SGS2 in den Recovery Modus bringen und flashen, sofern dort etwas mit "flash cwm" steht ;)
Heute Abend kommt ein Update.
Dauert es noch lange :)?
