krapfl
Hallo
ich habe hier ein s2 mit nem speziellen Pulldown Background.
Möchte den auf nem anderen s2 installieren nur wo befindet der sich,in welchem verzeichniss/ordner?
sdcard/vrtheme hab ich nicht mehr auf sd
der Pulldown Background ist ja noch vorhanden,also muss der doch irgentwo hinterlegt sein?
benutzte das
[Theme][AROMA] TurkbeyTheme V6 [Goatrip 7.0][XWLSN][4.1.2]
müsste hier sein laut installationsdatei
ui_print("..............................................");
ui_print("............ VillainTheme Flasher ............");
ui_print(". Modified by Hyperdroid Team .");
ui_print(". For more info etc, head to .");
ui_print(". xxx.villainrom.co.uk .");
ui_print(" ");
show_progress(1, 15);
ui_print(" Mounting partitions ");
ui_print(" ");
run_program("/sbin/mount", "/dev/block/mmcblk0p9", "/system");
run_program("/sbin/mount", "/dev/block/mmcblk0p10", "/data");
run_program("/sbin/mount", "/dev/block/mmcblk0p12", "/preload");
ui_print(" Copying files ");
ui_print(" ");
package_extract_dir("system", "/system");
package_extract_dir("data", "/data");
package_extract_dir("preload", "/preload");
set_perm_recursive(0, 0, 0755, 0644, "/preload/symlink/system/app");
ui_print(" Flashing theme ");
ui_print(" ");
package_extract_dir("vrtheme", "/sdcard/vrtheme");
set_perm(0, 0, 0755, "/sdcard/vrtheme/installtheme.sh");
set_perm(0, 0, 0755, "/sdcard/vrtheme/zip");
set_perm(0, 0, 0755, "/sdcard/vrtheme/cleanup.sh");
set_perm(0, 0, 0755, "/sdcard/vrtheme/zipalign");
run_program("/sdcard/vrtheme/installtheme.sh");
ui_print(" Cleaning up ");
ui_print(" ");
run_program("/sdcard/vrtheme/cleanup.sh");
run_program("/sbin/busybox", "umount", "/system");
run_program("/sbin/busybox", "umount", "/data");
run_program("/sbin/busybox", "umount", "/preload");
ui_print(" Thanks for using VillainTheme Flasher ");
ui_print(" ");
ui_print(" Please Reboot your device ");
benutzte das
ui_print(" ");
ui_print(" ");
ui_print(" ");
ui_print(" ");
ui_print(" ");
ui_print(" ");
