Masta_Gee81
Enthusiast
- 5.404
Hello everybody!
Here are my modded versions of the KPA/LP2/LP6 SystemUI.apk to remove some of the Gingerbread icons reinserted by Samsung.
Quelle: [MOD] ICS styled SystemUI for KPA/LP2/LP6 - xda-developers
Changes:
- Removed 100% charge notification
- ICS battery
- ICS quickpanel icons
- ICS fully connected wifi/signal icons
- Blue data icons
Hope this is enough to bridge the gap untill Jkay releases his excellent theme!
XXKPA:
ICS_for_XXKPA.zip
XXLP2:
ICS_for_XXLP2.zip
XXLP2 dark:
ICS_for_XXLP2_dark.zip
XXLP6:
KNOWN BUG: quick setting divider is transparent
ICS_for_XXLP6.zip
XXLP6 v2:
Bit darker so the transparent dividers are less obvious
ICS_for_XXLP6_v2.zip
Stock:
RestoreSystemUI.zip
For a version with 1% increments have a look at this thread: 1%Batterie mod for Ics XXLP2 Works fine!!
