Ics themed dialer for turkbey rom! NUR FÜR GB !!!!
  • 15 Antworten
Masta_Gee81
Masta_Gee81
Enthusiast
5.419
Ics themed dialers & other MODS for turkbey rom!
Since there was lot of request regarding the ICS themed dialer with video call icon, I modified the contacts.apk with ICS themed retaining the theme of TURKBEY!
Instructions
Flash using CMW. Incase if you loose phone or contacts icon, then search in app drawer and it will be available there!
no need for coffee or Beer, Just Thanks
if feel helped!
I am working on other dialers...soon will update
DOWNLOAD INSTRUCTIONS
Select flashupdate.zip in CWM and apply the file which you downloaded
MODIFIED MIUI MUSIC [NEW]
Changelog:
Modified the ICON set to match with Turkbey Theme
Modified the background colour to blue gradient (looks cool)
Screenshots attached at the bottom of the POST!
Link: Multiupload.com - upload your files to multiple file hosting sites!
1. Turkbey Original Stock Dialer (Flashable Using CWM) - Multiupload.com - upload your files to multiple file hosting sites!
2. ICS Themed Dialer Flashbale Using CWM - Multiupload.com - upload your files to multiple file hosting sites!
3. Black+Blue Flashable Using CMW - Multiupload.com - upload your files to multiple file hosting sites!
4. 3D Dialer flashable using CWM - Multiupload.com - upload your files to multiple file hosting sites!
5. ICS Theme Dialer with Transparent - Multiupload.com - upload your files to multiple file hosting sites!
6.4seasons_Winter_Dialer - Multiupload.com - upload your files to multiple file hosting sites!
7. New Dialer and Phone from TURKBEY - Creator of this Dialer & Phone - Turkbeydialpad.zip
8. Modified phone - Multiupload.com - upload your files to multiple file hosting sites! (Only bug is , you cant end the call with button, instead to be done with end call text. will be rectified soon. Others things are working)
9. ICS themed dialer with big blue numbers and icon changed along with dropdown menu transparent- Multiupload.com - upload your files to multiple file hosting sites! _ works on XWKK5 and never tested on others but should work. Please report bugs
10. Sensation Dialer-Creator of dialer is Crysis21(Thanks to Him) and i have just added top bar with turkbey theme, changed icons in the call logs and also made top bar transparent in call logs along with dialer panel with transparency - Multiupload.com - upload your files to multiple file hosting sites!
MMS Mod with 5 themes
1. I have just modified the 5 themes of MMS.apk with the turkbey theme. Flash it using CWM. Once installed go to message->settings->message skin and select any option out of the 5 themes. Please make a backup of mms.apk in system/app in case if you want to revert back
FOR ADD MODS, PLEASE VISIT TO "WELCOME TO THE SPACE ALIEN ULTIMATE COLLECTION" AT http://forum.xda-developers.com/show...47711&page=181
[NEW]-BLUE DROID EYE BOOT ANIMATION FOR TURKBEY - Multiupload.com - upload your files to multiple file hosting sites!
Credits:
****TURKBEY**** For making such a beautiful ROM
Thanks to all those who created beautiful icons and i have modded to suit with TURKBEY!
Thanks to 4 seasons ROM developers for making winter & Autumn dialer icons!
Thanks to sileashnair for his Gyan
Thanks to crysis21 for mms.apk with 5 themes along with sensation dialer
Thanks to spacealien for making other mods to TURKBEY ROM!
Turkbey Jkay Icons Check it Out : File-Upload.net - JKAY-ICONS.zip
Greetz M@sta
Reaktionen: indianer1966 und sensor99
Hab die Dialer auch mal mit der Omega getestet ...
Alles einwandfrei !!! Viel Spass damit ... gruss M@sta
Neue Dialer hunzugefügt ... Check it OuT .... Greetz M@sta
Guten Morgen,
ich muss jetzt mal ganz blöd fragen - haben diese Dialer alle die Fullscreen Anzeige?
Suche nämlich vergeblich nach einem Dialer ohne diese Fullscreen Anzeige, möchte aber nach Möglichkeit das Turkbeytheme nicht großartig abändern - der Rest gefällt mir nämlich sehr gut.
Danke & Gruß
Frank
Wilder_Wein schrieb:
Guten Morgen,
Danke & Gruß
Frank
soweit ich weiss nicht ... also ich hab mal alles getestet , hatte kein grosses Bild beim keinem der Dialer ...
Musst halt mal Testen , kann ja nix schief gehen ... gruss
Reaktionen: Wilder_Wein
Danke für die Info, dann werde ich heute Abend einfach mal eine ziehen und testen
So, habe jetzt einige Dialer installiert und musste leider feststellen, dass die Fullscreen Anzeige weiterhin vorhanden ist - scheint also nichts mit der Contacts.apk zu tun zu haben.
Bleibt also weiterhin ein leidiges Thema...... :mad:
@Masta_Gee81
ich nehme an, Du hast bei dir eine andere Rom istalliert und hast deswegen auch keine Fullscreen Anzeige, oder?
weiterhin macht der ICS Themed Dialer Flashbale Using CWM bei mir Probleme, wenn ich ihn flashe, kann ich meine Kontakte nicht mehr öffnen - leider auch nicht über den App Drawer - ich bekomme immer eine Fehlermeldung.
@Masta_Gee81
Bin momentan auf Omega V9.1 ... und du auf Turkbey nehm ich an ?!
Da ist der Big Caller nämlich drin ... jetzt ist ja dann auch klar warum das bei dir so ist :cool2:
Kleiner Tip : Zieh dir mal über die Turkbey die BlackBlue drüber dann sollte es wegsein , und es sieht noch geil aus ... hier der link zum Thread : https://www.android-hilfe.de/forum/...-universaltheme-fuer-alle-tw-roms.159664.html
greetz M@sta
richtig, ich habe, bzw. hatte die Turkbeyrom drauf - deswegen muss ich mich auch mit dem Fullscreen Dialer herumschlagen.
Das Theme im Link ist zwar schön, aber ich hatte mir die Turkbeyrom hauptsächlich wegen der zum Teil wirklich sehr schicken Icons, des Dialers etc. geflasht. Wenn ich jetzt Dein Theme nehme, ist alles weg.
egal, habe mir jetzt gestern Abend die Check Rom gezogen ein anderes Theme drübergebügelt und gut isses.
das sind sehr schöne Dialers, muss man echt einmal sagen.
Doch da hab ich eine Frage. Könntest du eventuell ein Dialer rausbringen bei dem die Noise Reduction dauerhaft aus ist? Ich hab nähmlich die Noise Reduction Mod aus der Kitchenapp (Checkrom) und wenn ich diese nach deinen Dialers drüber bügel, hab ich wieder den alten Dialer. :bored:
Wäre echt nett. :)
Danke im Vorraus.
Nein diese sind nur für Gingebread .... werde es gleich mal noch im Titel dazu schreiben ...
Gruss M@sta
Reaktionen: pgazzameen
wo bekomme ich den Sensation Dialer-Creator of dialer is Crysis21 her, leider führt der Link ins Leere!
Arguss
Die Links sind schon zu alt ... wenn´du ne Ics ROm drauf hast , kannst du den Dialer aus der Aktuellen sensation rom ziehen ...
Diesen kannst du dann per rootexplorer ersetzen ...reboot ..fertig ...
Dei Dialer aus der erstem Post sind sowieso nur für Gingerbread ...
Oder hat jemand noch Gb drauf ;) glaub nicht :confused2:
