Icon Morph Pack´s for all Roms
  • 90 Antworten
BananenAffe
BananenAffe
Enthusiast
2.337
Please make a Backup with CWM before install my themes !
Works with any Official Rom and any version of Custom Rom.
You need to be Root (Having flashed a kernel that has CWM).
This is not a Theme.It will only change the icons on your Apps.
All icons are in the size 72 x 72.
These applications have new icons after install the Icon Morph Pack´s :
Browser
Camera
ClockPackage
Contacts
Email
FmRadio
Gallery3D
Gmail
Maps
Memo
Mms
MusicPlayer
MyFiles
PhotoRetouching
PolarisOffice
Talk
TouchWiz30Launcher
TouchWizCalculator
TouchWizCalendar
VideoPlayer
VoiceRecorder
VoiceSearch
Tested in Galaxy S2 with Blue Monkey Theme,CheckROM RevolutionHD V2.0.0 and Siyah 1.8 Kernel (CWM 4).
How to install what you find here:
Copie Zip File in the root directory of the Internal SD to your mobile phone.
Go into recovery mode (High Volume + Home Button + Power On Button) or press on the Power menu to recovery.
Install zip from sdcard
choose zip from sdcard (not aplly /sdcard/update.zip)
Search the Zip File
Then Yes - Install Theme.zip
How to install the Extra Icons :
To change the icons install the apk Bettercut.v3.0 :
Download
Extract the Bettercut.v3.0.zip on your PC and copie the apk on your SD Card.Then install the apk.
Instructions for Better Cut
Extract the Extra Icons Zip and copy the Extra Icons folder on your SD Card.
1. Press long of the Homescreen.
2. Select "Shortcuts".
3. Select "Better Cut".
4. Select "Installed Applications".
5. Select a App of the list.
6. Select "Change Icon".
7. Select "Pick Picture".
8. Select a Icon from the Icon Pack.
9. Select "Create".
Athena HD Icons Morph Pack
Thanks and credits to "Raadius" !
[ICONS] Athena HD | Download Link OP | Requested Icons PG27 | MIUI Theme PG37
Screenshots :
Download
Athena HD extra icons screenshot (97 pieces) :
Download Athena HD Extra Icons
Black and Blue Neon Icons Morph Pack
Thanks and credits to ?
Screenshots :
Download
Black and Blue Neon extra icons screenshot (141 pieces) :
Download Black and Blue Neon Extra Icons
Cube Icons Morph Pack
Screenshots :
Download
Cube extra icons screenshot (320 pieces) :
Download Cube Extra Icons
Electro Green Icons Morph Pack
Screenshots :
Download
Electro Green extra icons screenshot (469 pieces) :
Download Electro Green Extra Icons
Glass Icons Morph Pack
Screenshots :
Download
Glass extra icons screenshot (293 pieces) :
Download Glass Extra Icons
iPhone Icons Morph Pack
Screenshots :
Download
iPhone extra icons screenshot (708 pieces) :
Download iPhone Extra Icons
My thanks and some credits goes to:
Sakashi for the Morph Script !
All developer for the nice icons !
If you like my work buy my a Banana
Reaktionen: DarkwingV8, Satarius und Masta_Gee81
YouEye Icons Morph Pack
Thanks and credits to "foreveryone".
[ICON PACK][MIUI] Zorsha Design - YouEye
Screenshots :
Download
100 New Icon ! YouEye extra icons screenshot (619 pieces) :
Download YouEye Extra Icons
100 New Icon ! YouEye extra icons in orginal size :
Download
IQ Icons Morph Pack
Screenshots :
Download
IQ extra icons screenshot (466 pieces) :
Download IQ Extra Icons
Placid Icons Morph Pack
Screenshots :
Download
Placid extra icons screenshot (464 pieces) :
Download Placid Extra Icons
Reaktionen: Wingtsun, Satarius, vauchSTA und 4 andere
Reserviert 1
Reserviert 2
Reserviert 3
Reserviert 4
Reserviert 5
Reserviert 6
Reserviert 7
Reserviert 8
Reserviert 9
Reserviert 10
Hey, super Arbeit! Danke für deine Mühe!
Allerdings werden bei mir die wenigsten Icons übernommen...kA ob es am ROM oder am Launcher (GoLauncher) liegt.
Ist aber nicht weiter schlimm, ich änder die für die Homescreens auch per Hand. Nur fehlt mir ein wichtiges icon. Und zwar das "WhatsApp" icon aus dem You Eye Icon Pack. Hast du das zufällig schon gesehen in einem Pack ?
lg enami
Das wird denke ich mal am Launcher liegen.Mit TouchWiz sind alle Icons aus der Liste mit neuen icons nach installieren der Morph Packs.
WhatsApp ist mit drin.Suche mal nach com.whatsapp.
Reaktionen: enami
Danach hatte ich schon gesucht. Ich finde das Icon unter der Bezeichnung ja auch, aber es ist nicht daß das man in der preview für iconpack 7 sieht (grün / weiß). Bei mir sieht es so aus :
Sent from my GT-I9100 using Tapatalk
Das ist halt so in dem Icon Pack.Und ich sehe da kein Grün/Weiss WhatsApp Icon in der Preview.Was du da siehst ist bestimmt : com.xiaomi.channel
Hab mal schnell was gemacht...
Edit :
Ich nehm alles zurück ;) Habe da wohl ein Icon Pack übersehen.Bin nicht drauf gekommen das man diesen riesen Download Button drücken kann :D
Werde die ganzen icons später noch mal komplett neu bündeln und hochladen.
Aber hier das Icon für dich...
Reaktionen: enami und mrdjtb
Super!
Vielen dank. Jetzt ist alles perfekt :D
YouEye extra icons screenshot (476 pieces) in 72x72 und in Orginal grösse in Post Nr.2 ergänzt.
Jetzt sollten alle Icons drin sein ;)
Das Icon Pack ist einfach Hammer.Sieht Geil aus und so gut wie jede App als Icon dabei.
Hey Super Arbeit..
Mir gefällt das orangene und ich habe es auch schon drauf, hast du dazu noch orangene Launcher Buttons ?? Das wäre perfekt, danke
LG
Das schreit doch nach einem Video Äffchen ^_^
Masta_Gee81
stephan1977
stephan1977
X
xXWeresXx
X
Masta_Gee81
Saizew
