Datenbank - THEMES für AOSP JB & ICS Roms
  • 126 Antworten
Sense 4 Multitasking! (Update 8.5)(Added BlackIce Package!)(Added B33) by locomain / xda
Sense 4 Multitasking! (Update 8.5)(Added BlackIce Package!)(Added B33) hi!
i start moding the normal AOKP SystemUI to look like sense 4 multitasking
this was a WIP but i think its save to say it close to the real thing
here is the mod with transparent background!
this is for GSM AOKP 32 and 33
but may work on other 4.0.4 roms confirmed to work on
-Foxhound ROM
-LTE CDMA AOKP Roms
-older 4.0.4 aokp roms
it works great and looks good
al though its not as smooth as i wanted it to be but i will be working on that
there are 2 CWM-zips files below
1 for the mod and the other one to go back to stock AOKP
if someone wants to help the systemui is in the attachment zip
this needs to be done:
-translate Recent app string for other languages, currently english greek german and dutch are working
CHANGELOG
-app labels are now centered
-disabled blue glow when touching the recent app
-added framework for better images!
-a view other little improvements
-softkey issue fixed!
-fixed the the No Recent App problem
-the images are now angled!
-fixed german
-changed the height of the app thumbnail so it looks more like the real thing
-added transparent
-added b33
-added greak
DOWNLOADS (AOKP 32)
Sense 4 Mod
http://dl.dropbox.com/u/63404537/Loc...e4-5%20B32.zip
Sense 4 Mod Transparent
http://dl.dropbox.com/u/63404537/Loc...32%20trans.zip
Back 2 Stock b32
http://dl.dropbox.com/u/63404537/LocoZipStock b32.zip
DOWNLOADS (AOKP 33)
Sense 4 Mod
http://dl.dropbox.com/u/63404537/Loc...e4-6%20b33.zip
http://dl.dropbox.com/u/63404537/Loc...33%20Trans.zip
Back 2 Stock
http://dl.dropbox.com/u/63404537/LocoZipStock b33.zip
DOWNLOADS BlackICE b33(untested)
Sense 4
http://dl.dropbox.com/u/63404537/blackice b33.zip
Sense 4 Transparent
http://dl.dropbox.com/u/63404537/bla...33%20trans.zip
enjoy!
if u like my work and want to support it
you can always do a little donation
Reaktionen: magic288, SGS-Ultra und FCB-Fan
|AOKP B34||The Holo-Series| Red, Holo-Green, Mega-Blue, Mint, Yellow, Cyan, Stock| by http://rootzwiki.com
***Platinumandroid and Qasimzia512 proudly present to you "The Holo-Series".
Post 1: Downloads
Post 2: Screenshots
Post 3: Hex values, Wallpapers, System App Icons(Coming Soon)
What is Holo-Series?
Our goal here is to give the communinty as many different flavors as possible. We both think that google did a pretty damn good job with ICS with the images(Except the gray backgrounds and stock blue), its clean and simple and we would like to keep it clean and simple, we did change the status bar icons to give it a cleaner/different look but the rest would stay the same (just with different colors). These themes are pretty much complete but we will be working on them in future to add/improve stuff. Thanks and Enjoy!!!
***Downloads***
***All New***Holo-Mega-Blue***
http://www.mediafire...1y1omly7r3gzc2h
Holo-Red
http://www.mediafire...b7suzo1cm4dxwb7
Holo-Blue-Bright |Cyan|
http://www.mediafire...4g6aec3c5z5508l
Holo-Green-Light
http://www.mediafire...25kya66ap4huge2
Holo-Mint-Green
http://www.mediafire...mmyoq3wm5w9rdc9
Holo-Neon-Yellow
http://www.mediafire...cmidl2ocpdlxy5i
Holo-Stock-Blue
http://www.mediafire...4b80047dd6hpd73
***Disclaimer: I'm not responsible for anything that you do to your phone, flash at your own risk. Always make a backup before flashing anything.***
***Note: Platinumandroid and I have spent countless hours on these themes to make them original (Making sure that they are different from the other themes out there), so please be kind and DO NOT COPY ANYTHING from here without asking either one of us. There are so many colors out there so do something original, dont be a copy cat
What is themed in all?
SystemUI.Apk
Framework-res.apk
Browser.Apk
Camera.Apk
DeskClock.Apk
GalleryGoogle.Apk
GoogleQuickSearchBox.Apk
GennieWidget.Apk
LatinIME.Apk
Launcher2.Apk
MMS.Apk
Phone.Apk
Settings.Apk
ApexLauncher.apk
Inverted Gapps (Travp624)
Credits and thanks:
My partner in crime "platinumandroid" for his amazing work with the themes
"Romanbb" for the rom and help with battery text color change
"Travp624" for all the inverted gapps
"Sonnysekhon" for some help with FW
"Schoat333" for some help with contacts.apk
"ProTekk" for his amazing tutorial on how to sync the source
"Pinkthesink" for some great advices
[MINI-MOD] Fonts for Galaxy S (ICS based roms only)
INSTRUCTIONS:
Download file.
Copy to internal SD.
Reboot in recovery.
Flash file.
Reboot.
CREDITS:
DaXmax - I got inspired by his fonts thread and he let me use his zips as a base (I only changed the installer script and the font files).
Make sure you visit his thread and thank him.
Keep in mind that once you flash this there is no way to go back to the font you previously had unless you re-flash your rom or theme, but you can always flash Roboto to keep a "stock" look.
I plan to update this thread as often as I can, and if you want a certain font to be included let me know.
DOWNLOAD: Free Cloud Storage - MediaFire
Bougan Black SSi Bold
Malcom Expert
Mendoza Roman
P22 Eaglefeather
Roboto
Avalon Two
Odyssey
Arial
Katrina
SansationRegular
Moin habe ein problem und zwar habe ich aokp build 34 drauf mit dem infowars theme 3.5 von zeitgeist aber die battery anzeige stimmt nicht mit der in systemeinstellungen überein entweder steht da 100 % oder 81% aber nie genau das was der akku eigendlich hat habe schon full wipe angewandt und alles noch mal frisch geflasht aber keine änderung ist das vielleicht schon bekannt
Anyone interested in a themed AOKP M5? It has init.d scripts fixed as well. Link is here
Auf was muss ich achten wenn ich die Theme von Zeitgeist181 Infowars 3.5zip flashen will?
Sorry für die vlt. blöde Frage habe Mileston 5 drauf.
Muss ich nur über CWM flashen wie bei einer Rom?:confused:
Ich hab die Noble Black 3.5 aber gilt auch Infowars:
Flashen via CWM, danach die black Gapps und dann fix permissions und Neustart
Gesendet von Galaxy S mit AOKP 4.0.4
Reaktionen: megaburschi
Werde es so machen. Vielen Dank!
Sent from my GT-I9000 using Tapatalk 2
Und hat's geklappt mit Infowars??
Habe es noch nicht installiert. Wenn es Probleme geben sollte melde ich mich. Danke für die Nachfrage.
[THEME][AOKP] Holo-Mega-Blue (Infinitum)
by tomiho.d / xda
Using original Holo themes was causing USB problems and FC´s. So I took Blue Infinitum theme and Holo Mega Blue and created a mix. It has some bugs but the result is good I think.
Tested: Anarkia v.0.1.7 Rom (AOKP M5)
Hex code of Mega Blue is #ff0075ff
You need to set some things manual (clock color, lockscreen text color)
Bugs: Weather icon missing in notification bar.
Some parts are "stock ics" blue (contacts)
DOWNLOAD
Credits: qasimzia512 for Holo theme
Razer(x) for Blue Infinitum
(I´m using DPI 160 so my screens are looking weird)
Der ursprüngliche Beitrag von 07:55 Uhr wurde um 08:05 Uhr ergänzt:
[MOD][UPDATED 05-03-2012] Dark Knight 5.5 Battery Percentage Mod by GreatVortex / xda
Here is the battery percentage mod for Dark Knight 5.5
This mod will replace the standard battery indicator on the status bar.
Please always do a nandroid backup before flashing.
Installation :
  • Download the zip file
  • Restart your device in recovery mode
  • Perform a nandroid backup (optional but recommended)
  • Install zip from sdcard
  • Reboot
  • Select CircleMOD from ROM Control (Dark Knight V3)
Screenshot:
Dark Knight v5.5: V1.
V5.5
Flash only on Dark Knight 5.5
You may hit the "Thanks" button if you like this mod.
Batería / Toogles bar ROM ELITEMOVIL [RC IMM76K] by cyberaprendiz
Estos mods son compatibles con la versión RC IMM76K de la rom de elitemovil. Los de baterías están elaborados con la nueva base de esta versión. los de toogles, son los mismos que en anteriores versiones puesto que elitemovil siempre ofrece el mismo fichero en todas las roms que ha ido sacando.
Tipos de mod:
  • Batería con %
  • Batería con % y barra de toogles personalizados.
INSTALACIÓN
El instalador del MOD utiliza la herramienta Universal Flasher Tool, integrada en el zip de la descarga. Tiene dos ventajas:
  • Realiza por si sola los 2 wipes necesarios (cache y dalvik cache)
  • Realiza automaticamente un backup de los archivos que se vayan a modificar, creando un zip instalable por recovery. Si no te gusta el mod, puedes volver al estado anterior de la ROM. El zip instalable lo encontrarás en la carpeta UniversalFlasher, en la sdcard.
Para instalarla:
  • Copiar el zip descargado en la SD interna
  • Reiniciar el teléfono en recovery
  • Seleccionar "install zip from sdcard"
  • Seleccionar "choose zip from sdcard"
  • Buscar y seleccionar el zip del theme descargado
El teléfono reiniciará por si sólo.
Para descargar pinchar en el enlace de cada bloque. Accederás a una carpeta con todos los mods, numerados tal y como aparecen en la relación y en las capturas.
MODELOS DE BATERÍAS - INCLUIDAS TAMBIÉN EN LOS TOOGLES
Todos los mods de baterías llevan incorporado el mod de aplicaciones recientes y apagar pantalla (ver imagen)
  1. Batería circular punteada con %
  2. Batería circular con %
  3. Batería honeycomb %
  4. Batería newborn %
  5. Batería estilo CM con %
  6. Batería stock ICS con %
  7. Batería solo números %
  8. Batería con número de % centrado sobre ella
  9. Batería circular punteada 2 con %
  10. Batería en forma de ola
  11. Batería pile
  12. Batería en forma de ola color ICS
  13. Batería estilo GAS
  14. Sin batería
  15. Para quien instale las TOOGLES BAR, batería stock ICS sin %
DESCARGAS DE BATERÍAS. Corregido pequeño bug
DESCARGA DE TOOGLES BAR PERSONALIZADOS + BATERÍAS
También llevan incorporado el mod de aplicaciones recientes y apagar pantalla (ver imagen)
Imágenes Adjuntas
mis toogles+toogles.png (26.3 KB, 31 visitas)
Post 1: Downloads
Post 2: Screenshots
Bist du sicher das die Themea fürs SGS sind??
Bei rootwikiz ist der Thread zwar im Bereich "AOKP" zu finden, aber die ROM gibts ja nicht nur fürs SGS.
Und der entsprechende xda Thread ist unter "Galaxy Nexus - Themes" gepostet.
gruss
Reaktionen: ChrisKey
Ja, die gehen, zumindest unter B34.
Aktuell nicht getestet!
habs mittlerweile getestet. ging ganz gut... dann sind die virtual buttons beim rumspielen abgeschmiert und nach reboot kamen haufenweise fcs (apex, tastatur, systemui, usw..)
schade.. :-(
Kann man das Uhr/Wetter Widget aus dem HTC Sense 4.0 Theme irgendwie einzeln bekommen?
Also da AOKP mit der B35 jetzt den t-mobile theme changer drin hat suche ich ein paar themes dafür, aber leider finde ich hier nur welche die man flashen muss und dann beistens nur für die M4. Muss ich anders suchen oder sind die gar wo anders gepostet oder sind die einfach so hir mit dazwischen gepostet?
Gruss Jobbe
