Datenbank MIUI GB & V4 (ICS) - Themes - Bootanimation - Lookscreens - Fonts
  • 208 Antworten
SlideScreen LS
Der erste Miui lockscreen mit Vorschau von SMS, verpassten Anrufen etc.!!!
Mehr Infos gibts hier: Here
Wenn gewünscht kann ich das bei Gelegenheit mal grob übersetzen ....
To use download the zip file to your computer and extract it (do not download straight to your phone and try to apply it).
Open the manifest file located in the lockscreen>advanced folder. Search for gmail.com and replace YOURNAME@gmail.com with your gmail account (2 instances).
Open the .mtz file in the base folder with 7zip. Move the lockscreen folder into the mtz.
Move the mtz to you sd card and apply. The theme manager will ask if you want to convert, click yes.
If the names for SMS are not working, you must delete your sms threads (long press each thread then delete) then go to your contacts app and press menu>settings>rebuild index data and OK. Then you just have to wait for a message.
Elegance UI LS
von hier
To use download the zip file to your computer and extract it (do not download straight to your phone and try to apply it). Open the manifest file located in the lockscreen>advanced folder. Search for gmail.com and replace dbilliter@gmail.com with your gmail account (2 instances). Open the .mtz file with 7zip. Replace the lockscreen folder already in the mtz. Move the mtz to you sd card and apply. The theme manager will ask if you want to convert, click yes. If the names for SMS are not working, you must delete your sms threads (long press each thread then delete) then go to your contacts app and press menu>settings>rebuild index data and OK. Then you just have to wait for a message.
tobiasth schrieb:
hab ah bissi gefummelt:
- 24hour version
- with removed AM/PM settings
- xx°C for weather
- smaler font (20 insteed of 24)
[URL="http://gadgetdesire.blogspot.com/2011/12/miui-theme-slidescreen-ls.html"]siehe hier (24h version!)[/URL]
preview:
tobiasth schrieb:
- 24h version
- Datum etwas umgefummelt
gleich bleibt die installation:
Reaktionen: Ulmi
mal ne frage, da bei mir die namen nicht angezeigt werden.
muss man bei googlemail irgendwas eintragen lassen damit es funktioniert? Bin zwar wegen dem market angemeldet, habe sie jedoch noch nie genutzt.
Außerdem wo befindet sich "rebuild index data and OK"? Kann es nicht finden
pfuu, weiß ich jetzt auch nicht, sorry
wo genau werden die namen nicht angezeigt, bei den SMS oder generell?
das findest in deinen kontakten > einstellungen > Index neuerstellen
generell, es kommt einfach nur missed call oder missed sms usw... ohne text und namen
welche Version hastn oben von miui? du brauchst mindestens 1.12.9 !
send from my SGS
oh ich habe boogies miui v7, die ist noch auf version 1.10.28
gut, das erklärt einiges^^
Bei mir klappt es leider gar nicht! Ich bekomme nur einen leeren Bildschirm bzw. mein einfachen Hintergrund ohne jeglichen Text etc.
Hab die Boogie V6
Hab die Boogie V6
wie bereits gepostet ... MIUI ab v1.12.9 wird benötigt!!!
Reaktionen: Taphor
Hm alles klar, komme mit den Versionsnr. nicht so ganz zu Recht und hab nicht dran gedacht, dass Boogies nicht mehr mit dem normalen MiUi übereinstimmt.
Schade naja dann halt nicht
What Do You Want To Do Today
Features:
- elegant notebook design
- unlock by tearing down the end of the paper
- music controls (open by double clicking clock)
- weather info provided by 9s-Weather (Advance) widget: double click on current weather icon brings up a 3-day forecast and then double-click on first icon brings up night forecasts
- calendar info: shows the next event if it happens within 24 hours
- compatible with all hdpi resolution phones (qHD compatible)
- needs miui 2.1.6 or higher needed plus 9s-Weather (Advance) widget
- now available in for languages: English, German, French and Hungarian
WICHTIG:
Um diesen Lockscreen zu verwendet wird zwingend miui 2.1.6 oder höher benötigt, ausserdem muß 9s-Weather (Advance) widget installiert werden.
Download widget hier oder vom Android Market
v2_fixed:
Celsius:
v2C_fixed: http://www.box.com/s/4xlud5431ixlfdyh5ld4
v2C_fixed_hungarian: http://www.box.com/s/ik05dfs9z0f9ljuivmeo
v2C_fixed_german: http://www.box.com/s/db9bvqcmfde39fb3kzyq
v2C_fixed_french: http://www.box.com/s/a3i9pozjg8tbh1s8yfcl
Fahrenheit:
v2F_fixed: http://www.box.com/s/fj9rz3ol35fnm07xuchd
via xda-developers
[THEME][ALL][ICONS and more] Vexillum + MIUI v4 | updated 28/12/11
Hi there!
I have merged an package with the Vexillum Project and some MIUI v4 stuff that i found from some users.
Theme contains:
Some MIUI 4 icons
MIUI 4 boot logo and sound
Android 4.0 font
ICS wallpaper/lockscreen wallpaper
Vexillum Project 23/11/11
Changelog:
28/12/11
Added MIUI v4 bootsound
Renamed to Vexillum + MIUI v4
Fixed Preview
Added Roboto Font (ICS Android 4.0 font)
27/12/11
Package made
Screenshots:
DOWNLOAD
To do:
What to do?
Thanks to:
lippol94
trbn.brgr
boycuteo
