Datenbank MIUI GB & V4 (ICS) - Themes - Bootanimation - Lookscreens - Fonts
  • 208 Antworten
Miui Red Crystal
What is themed
**FRAMEWORK-RES
**SYSTEMUI
**LAUNCHER
**PHONE
**CLOCK
**STATUSBAR
**TOGGLES
**WALLPAPER
**LOCKSCREEN
**PROGRESSBAR
AND SOME OTHERS
I was trying to make the screenshot more festive, but ended up just downgrading the screenshots on accident
This is my first MIUI theme, still getting the hang of all the features
A lot of new things to edit. Next one will have more...
INSTRUCTIONS
Download MTZ and place in the MIUI/THEME folder
open THEME MANAGER and hit MENU to IMPORT THEME... Then APPLY
DOWNLOAD
*As Request
Blues (replaced the Orange in MIUI)
And added some purple on things to match wallpaper
New statusbar, title bar, browser color and highlights
Bootanimation shown is included
INSTRUCTIONS
Place MTZ in MIUI/THEMES folder and apply theme
DOWNLOAD
Reaktionen: Deepthrow
[BOOTANIMATIONS] windows phone 7 boot animations for android......
here i present the windows phone 7 boot animation.....
android engraved:
FFlzsyT
watch the boot animation here: normal and with dots{WVGA}
V7R2iYn
UiJmHlJ
{QVGA}:
Lezwrrj
it plays just like windows phone7 but repeats it over and over..
its for hdpi and ldpi devices...
for wvga screens: 1. normal: bootanimation2.zip
2. with dots: http://db.tt/NHDJong
for qvga screens: wp7 bootanimqvga.zip
how to apply?:::::
option1: place it to data/local via root explorer and give all permissions(if s-off) and reboot
option 2: place to data/local via adb:
Installing custom boot animations (Credit to jcase from XDA):
Windows:
1.) Download the desired animation, rename the zip file to "bootanimation" and move into your Android SDK/Tools folder.
2.) Run the following adb command to push the animation into the proper place:
Code:
adb push bootanimation.zip /data/local/
3.) Enjoy!
hey masta,
hab n problem mit deiner bootanimation von post 14.
hab mir die bootanimation.zip runtergeladen, aber wenn ichs per cwm installiere kommt immer nur installation aborted?
edit:
dieses hier
http://zaiko.dangerweb.hu/Untitled1.gif
@ masta_gee: bei mir klappt dein rotes theme irgendwie nicht? er zeigt es im theme manager garnicht an bei mir?
[THEME][28.08] NeonGT and NeonBT v1.0NEW UpDaTe !!!
Hello all, this is a port of my NeonGT theme to MIUI. It's based on the original to be found here.
28.08 - UPDATE - NeonGT and NeonBT v1.0
This is close to a final release at it's going to get right now. I've updated quite a few things - notification pulldown is more transparent, redesigned the pulldowns and popups, tweaked the new battery some more to make the edges smoother, plus many other small revisions. Oh ya, and I've converted it to blue too. Enjoy.
This release uses the new battery icon. If there's enough demand I'll upload versions with the old battery...
NeonGT 1.0
NeonBT 1.0
Clocks
INSTALL INSTRUCTIONS
Unzip the .mtz file from the zip and place it in your /sdcard/MIUI/theme folder, then apply using theme manager. MIUI Theme Manager can sometimes be quite fussy, so if anything doesn't look right try applying the theme again.
Regarding the lockscreen music controls, if they don't appear at first, simply double tap the area below the clock and date and they will show up. Not sure why, MIUI can be strange sometimes.
TO USE THE NEW CLOCKS
Updated 17.07: You have two choices here. 1: Install the themes as normal and the default analog clock will be themed to match the new MIUI clock style (minus the second hand). 2: Copy the attached zip file to your memory card, boot your phone into recovery mode and choose "Install zip from sdcard" > "Choose zip from sdcard". Select the file and the three clocks will be installed (to /system/media/gadget/clock). Reboot. Now when you go to add a new widget to your screen, choose the analog 2x2 clock and click the small button on the top right corner to choose a different layout. Note that you can only have one instance of the analog clock at a time, so remove your old one before adding a new colour.
TO DO
Further cleanup/tweaking
OLDER UPDATES
24.08 - NeonGT v0.91
This update mainly fixes the black text on black buttons issue as well as the notification dropdown. It looks a bit greyer now but that's what's needed to handle both light and dark text. I've also skinned the task manager (aka sidekick)[/color]
09.08 - NeonGT v0.9
Many under the hood refinements, including:
New icons: Root Explorer, AppBrain, Drop Box, VLC, Mobo Player, GMail, Droidwall
New darker buttons
Tweaked notification pulldown colours
Refined bubble battery icon to better match the theme
New alarm notification icon
Lockscreen now supports cover art
Tweaked volume/colour sliders
Tweaked tab header buttons
Changed text input colour to black
Themed stock browser menu icons
Updated notification background
plus a few more minor tweaks[/color]
23.07 - NeonGT v0.8
New battery icon
Increased font size by 10 percent
Switched mms sent and received bubbles
Tweaked many of the icons to look better
Themed more notification icons
Skinned the folder pupup window
Skinned the calendar widget
Themed contacts
Partially themed the theme manager
Made icon dock semi-transparent
New Miren browser icon
Plus lots of other tweaks
17.07 - v0.7 - Now available in both green and blue. I have included a new boot animation and tweaked the lockscreen to work fine with MIUI 1.7.15. As a bonus, there's also a zip file with three modified versions of the new MIUI analog clock in red, green and blue
13.07 - v0.5 - Now compatible with MIUI 1.7.8, themed the dialer (still a bit to do), new lockscreen, many other general tweaks
25.06 - v0.4 - Tweaked notifications, refined buttons, added updated lockscreen, tweaked colours, refined some icons, new dock
22.06 - v0.3 - New wallpaper, new icon set, tweaked notification pulldown some more, added 5-way lockscreen
20.06 - v0.2 - New clock, modified notification pulldown, replaced most statusbar icons
DOWNLOADS
DOWNLOAD NEONGT 1.0
DOWNLOAD NEONBT 1.0
DOWNLOAD NEONGT v0.91 with new battery
DOWNLOAD NEONGT v0.91 with old battery
DOWNLOAD NEONGT v0.9 with new battery
DOWNLOAD NEONGT v0.9 with old battery
DOWNLOAD NEONGT v0.8
DOWNLOAD NEONBT v0.7
DOWNLOAD THEMED CLOCKS
Reaktionen: DJChris und Deepthrow
Quelle: Originally Posted by h_zee13
Here is my new theme.
I haven't added a clock yet, not sure if I should or not....what do you guys think?
Oh and just double tap the top of the screen to show music controls
Circles
Circles v1
PS: It's the first time I'm uploading my theme to Minus.com, so if anyone is having issues downloading then please let me know.
_______________________________________________________________________________________________________________________
Quelle: http://forum.xda-developers.com/showpost.php?p=17185972&postcount=2866
Here is a mod of Mela HD that Westi01 has made
Simple Minimal
Download
4Minimal
Download
Once again I'm unable to put these lockscreen to the first page because I've run out of space.
beginnend vom 2 September
Mehr bei xda: http://forum.xda-developers.com/showthread.php?t=1134657&page=285
[MIUI Theme] Icon Set - Placid HD
by stiffspliff
Published on 09-01-2011 08:43 AM
10 Comments
With permission from the original creator of these icons, MIUI.us would like to showcase a new set of icons for MIUI.
This is a great icon set for those that enjoy the minimal look.
The icon set is called Placid HD
Made by MIUI.us member: dfskevinohyeah
Original thread: http://forums.miui.us/showthread.php...-WIP-PLACID-HD
Download Link(s):
Multiupload.com - upload your files to multiple file hosting sites!
http://dl.dropbox.com/u/18958627/PlacidHD.mtz
http://dl.dropbox.com/u/8539974/PlacidHD.mtz
[LOCKSCREEN][23/09 v2.3] Samsung Galaxy S Puzzle LS [800x480][854x480][960x564]
Samsung Galaxy S Puzzle Lockscreen Lookalike
by fodi aka picard
Now support for 840x480 plus 854x480 and 960x564 (testers needed for the latter two as I couldn't test them myself)
Features:
- current version: v2.3a and v2.3b
- implemented stock glass lockscreen as close as possible
- unlock by dragging "Sweep glass to unlock"
- view missed calls or unread messages by fitting puzzle pieces
- with music control
- two versions: v2.3a for puzzles moving as sliders and v2.3b for puzzles moving freely
Changelog:
v1: original release
v2:
-enlarged unlock area (now as high as screen_height-300)
-time&date now moving with unlock
-support for 840x480, 854x480 and 960x540 (other resolutions should be broken since it uses screen width and height for filenames)
-v2.1 is slider-puzzles and v2.2 is free-puzzles
v2.3:
- tweaked puzzle settings: now you don't need to fit them as closely as before
- renamed "lines": v2.3a is slider-puzzles and v2.3b is free-puzzles
Download:
Minus.com (preferred, please use this first):
v2.1: galaxy_s_glass_lock_multi_v2.1 - Minus.com
v2.2: galaxy_s_glass_lock_multi_v2.2 - Minus.com
v2.3a: galaxy_s_glass_lock_multi_v2.3a - Minus.com
v2.3b: galaxy_s_glass_lock_multi_v2.3b - Minus.com
Dropbox:
v1:http://dl.dropbox.com/u/24114955/gal...glass_lock.mtz
v2.1: http://dl.dropbox.com/u/24114955/gal...multi_v2.1.mtz
v2.2: http://dl.dropbox.com/u/24114955/gal...multi_v2.2.mtz
v2.3a: http://dl.dropbox.com/u/24114955/gal...ulti_v2.3a.mtz
v2.3b: http://dl.dropbox.com/u/24114955/gal...ulti_v2.3b.mtz
Any feedback is welcome, especially for 854x480 and 960x560 as I couldn't test them
Meizu M9 Lockscreen clon
Hello to everyone:
Here, I present to you a project RoinGrindWald and I have been working very hard. Meizu lockscreen v1.2
Home unlocker bouncing animation
Sms unlocker bouncing animation
Phone unlocker animation
Battery animation (credit to RoinGrindWald He nailed this one)
phone and sms notification
Music control with album art and expectrum.
Credits to RoinGrindWald and Cowsquad.
Enjoy, let me know if you find any problems
Screenshoots
Download link
MeizuM9V1.2.2.mtz
xda-developers - View Single Post - [LOCKSCREEN-THEME] MIUI Lockscreen theme thread (31/08) Video tutorial added in OP
this is all his work i just renamed the file and made it a 12 hour clock.
mtz is attached
sorry folks..for some reason the mtz wasnt attaching on my end
here you go: MEGAUPLOAD - The leading online storage and file delivery service
my new lockscreen
Bist wohl aus dem Bett gefallen, Klickst Du hier Boogieman :D
http://marcarnal.deviantart.com/art/...lock-260775014
der ist jetzt auch hier
Download File
ZIP download, 483 KB
Hab ich was an den Augen? Beim zweiten find ich keinen Link...
edit
[THEME] Seamless Dark [10/1] 1.9.30+ [beta1] Team b|lind|s
Download: http://goo.gl/jkFKm
Mono & Colour Icon Set
NEW ICONS ADDED
MonoKins2.5
Want that simple look?
Try these...
Suit most themes to finish that "simplictic" style off.
ColourKins2.5
Simple yet colourful!
All the brands and icons in there natural colour, heightend by a simple base
Perfect for any theme.
ColourKins2.5 download
MonoKins2.5 download
Please be nice...
this is my 3rd icon set for public release and i'm still adding icons to the pack.
Will be updated when I can, any major icons i've missed out - please just ask nicely for them and i'll see what I can do
</RosieKins>
[Theme][Please read meeasge n.1420]Ultimate iPhone theme[6.8]
Centered clock is not included
-Changelog:
Version 6.8:
-Fixed lockscreen, and added music icon when you hearing music.
-Deeper comapss skin.
-improved Browser skin.
-Changed Search widget to look like in the iOS.HOW EVER it might look really ugly on phones with high resolutions (like sensation,evo 3d etc).
-More blue has been added to music player.
-fixed the Toggels skin and added more icons for Access control etc. (changes some aswell).
-In case you're using extanded setting mod, I added Carrir logo -iPod (lolXD).
-added some icons.
-and a lot of small tweaks and addons (wallpaper mask and more.)
[-Download:
6.8 :
4G : Click here
3G : Yet Not Available (If you want it, download the recent 3g version and only apply the homescreen and wallpapar.)
ältere Versionen: [-Download: 6.8 : 4G : Click here 3G : Yet Not Available (If you want it, download the recent 3g version and only apply the homescreen and wallpapar.)
Reaktionen: Tommunity84
[Theme][9.20.0] MIUI Infinite
MIUI Infinite
MIUI Infinite is back to it's roots. I know I like to experiment with new design elements every once in a while, but I've gone back to what I believe made MIUI Infinite great. It comes with the original Infinite lock screen, many unique Infinite features, and 1000+ custom Vexillium icons. I invite you to try it out.
Official MIUI Infinite 9.20.0 release:
[Link]
Extras
Infinite dock and icons: [Link] [Screenshot]
Wallpaper in LP preview: [Link]
Previous versions:
8.12.5: [Link] [Screenshot] [Screenshot]
7.10.1: [Link] [Screenshot] [Screenshot]
6.21.1: [Link] [Screenshot] [Screenshot]
6.21.1 camera lockscreen: [Link]
6.21.1 browser lockscreen: [Link]
6.20.8: [Link]
6.15.6 (Old Lockscreen): [Link]
6.10.1: [Link]
6.9.7: [Link]
6.2.1 Original: [Link]
6.2.1 Cream: [Link]
Additional screenshots:
Ice Cream Sandwich Lockscreen
0 Oktober 13, 2011 Posted by marco in Lockscreens
Hier ist es, eines der erste Ice Cream Sandwich Lockscreens für Miui. Erstellt wurde es von picard666,
ein Benutzer von XDA. Der Benutzer UNS1N von Miui Germany hat es danach noch ins Deutsch übersetzt und ist nun bereit auch hier bei uns zu Verfügung.
Photos
thumb.php
thumb.php
thumb.php
Download Ich Cream Sandwich
Reaktionen: uns1n und Zwerkel
:) so ein Zufall. Hatte gestern bei miui noch die neue v2 hochgeladen.
Reaktionen: Ulmi
