[METAMORPH] Launcher Pro Updates für he_stheone64 Themes
  • 42 Antworten
The metamorph only helps you to theme your launcherpro, whenever fede (the dev) launches updates. When this happens:
1. You download the update from the market
2. You rename the launcher in data/system (which is called fede...something) to Launcher.apk
3. You move Launcher.apk to system/app
4. Boot into OpenRecovery and apply the metamorph - in your case LauncherProSummerBlues
Reaktionen: batmania15
Ahhh ok now that makes sense. I was looking for the file in data/system to be called Launcher.apk now that I know its fede.... I now see it. Thank you for the help on that.
However, I'm still having trouble applying the metamorph theme. It will not take the changes. Everything applies but nothing changes. Also in the remove metamorph menu in OR there is nothing listed to remove after I do the install. I am unzipping the package as is with the proper root folder name LauncherProSummerBlues and putting that in addons/metamorph.
It's still not working. Do I need to have busybox installed? If so which version? Anything else that i could be missing?
I GOT IT TO WORK. Please disregard my last post. I did what you said and it worked perfectly. Now have the newest LP pro and the metamorph theme actually took this time. PHEWW. Thanks for sticking with me and explaining that, that was the one step i was getting hung up on.
O
  • obafemi-droid
TheSpiritof69
TheSpiritof69
-FuFu-
-FuFu-
-FuFu-
he_stheone64
  • he_stheone64
2 3
Kitzu
