Adinoid
Enthusiast
- 1.104
Link zum Theme: [Theme] Ice Cream Sandwich for CM7: v 1.6 Updated: 11/08/2011
- Credits an sonnysekhon
Bilder zum Theme:
Bilder zum Theme:
Changelog:
Version 1.6:
Redrew the LauncherPro preferences menu icon.
Added ICS blue back as the default color, if you don't like it, remove the 2 lines that say color in com_android_vending.xml.
Added a new image for call log titlebar to show both black and white text.
Added a new icon for ADW settings.
Added the dock timepicker images to all variations of ADW to match the rest of the theme.
Changed the text selection color for default orange to ICS blue.
Fixed the GPS statusbar notification discrepancy.
Removed the grey dividers as they only go well with the ICS background, I have added the divider images to the blue background mod zip for those who want it.
Version 1.5:
Fixed the progress bar bug.
Made the notification icons grey (I know for a fact now that they are grey in the GN).
Fixed the market color discrepancy.
Added ICS style dividers in lists.
Made the clock widget look more like that on the GN (thanks to 2t0m).
Themed the Music 4.0 widget.
Added visual feedback when pressing buttons in the dialer.
New upload and download notification icons.
Made it compatible with the statusbar layout from xda.
Made the sound toggle notification widget icons consistent with ICS.
Version 1.4:
Removed the accurate battery % mod.
Changed the dialer background to ICS black.
Added some new ICS notification icons.
Added some keyboard images.
Themed CM7 music.
Changed the button pressed image.
Bug fixes.
Version 1.3:
Added the accurate battery % mod (big thanks to nachopre, who made the individual images). Uncheck battery % in CM Settings.
Changed the dialer background.
Fixed some menu images.
Bug fixes.
Version 1.2:
Fixed the search app graphical discrepancy.
Fixed the tabs to look more like those in ICS.
Fixed the null signal icon.
Bug fixes.
Version 1.1:
Made the notification widgets' 'off' images darker.
Bug fixes.
Version 1.0:
Made the notification menu look more like ICS (thanks to ZduneX25).
Some other minor cosmetic changes.
Published on the market (uninstall the xda version first).
Beta 1:
Fixed battery % (thanks to nhnt11).
Themed the camera app.
Made the widget backgrounds look more polished.
Fixed the search widget glitches.
Other minor cosmetic changes.
Alpha 4:
Fixed the search widget border.
Fixed the dialer to make it wider.
Changed the textboxes a little.
Fixed some battery images but the % is still not working properly, you guys will have to wait until the next release.
Alpha 3:
Made the Google Widget thinner.
New data images.
New 4G Wimax images.
ICS keyboard.
ICS popups.
ICS widget background.
Fixed signal roaming images.
Added Honeycomb Notification Power Widget images.
Fixed a lot of cosmetic bugs.
Added a lot of ICS blue images to tie the theme together.
Removed most of the unnecessary stuff that was lingering from my other themes.
Added ICS Morph (Use Metamorph or Zipthemer).
New USB connected/disconnected images.
Alpha 2:
Resized Statusbar Images.
Alpha 1:
Initial Release.
FAQs:
Why is the search icon not in the app drawer?
- It had to be made transparent to mimic the ICS search widget, minor trade-off.
How do I apply the morph?
- Use Metamorph or Zipthemer from the market.
What to do with the Extras zip?
- Simply unzip it and apply the contents manually (wallpapers. icons etc).
Will there be a MDPI version?
- Maybe in the future. Please don't ask for an ETA.
Why am I experiencing some graphical glitches?
- You need to reboot.
Why is some of the notification text black on black?
- It is beyond the scope of the theme chooser to theme some system level text. For example, usb debugging notification (just turn off the usb debugging notification in settings).
Most 3rd party apps that show black text will have an option in the settings to invert the text. If not, it's an error on the app developer's part for hard coding the text color instead of choosing the system text color.
