[English]HO!NO! LauncherPro Scrolling theme for milestone
  • 22 Antworten
HO!NO!
Hi
After i see this kind of theme on other phone, i decide to do it for the milestone.
Photo of it
20110101231632.png20110101231757.png20110101231828.png20110101231856.png20110101231928.png20110101232020.png
Tutorial
Step 1.
Download and extract the source files to your sdcard, leave out the "PSD".
Step 2.
With ‘Wallpaper Set and Save’, set the wallpaper. It should be in \sdcard\Wallpaper\.
Step 3.
Set up Launcher Pro with the following settings
Homescreen Settings
Number of screens = 6
Default Screen = 1
Number of Columns = 5
Number of Rows = 5
Auto-fit Items = Ticked
Appearance Settings
Dock Background – Custom – set included dock
Hide Notification bar = ticked
Hide icon labels = ticked
Disable wallpaper scrolling = unticked
Step 4.
On screen 1 add transparent icons over the left hand bar, to do this;
Long press home screen > Shortcuts > LauncherPro Shortcuts > Screen 6 > Remove Label > Tap the icon and change it to “blank.png”. Move the shortcut above “Settings” (top left).
Repeat this for screens 2-5
Step 5.
Add dock icons to dock. This is my setup.
That gives you the basis of the theme.
Download Source files
Please Show me your creativity!!!
Enjoy!!
Reaktionen: da.russe, Pwned, Diamond-X und 3 andere
wow, looks cool! i just changed from miui to the latest ho!no! yesterday and so far im really happy with 12.27v2. i will look into this after work...thank you!
EDIT: hmmm, i cant get it to work.
- step 1: ok
- step 2: found out,that "wallpaper set and save" is an app ;) ok, and with that i must navigate to the psd? or only to one of the jpgs?
- step 3: ok
- step 4: i dont see any launcher pro shortcuts...must i create new ones?
Launcherpro shortcut must be on sdcard if you have unzip thé source file
.lps file must be like this /sdcard/screen1.lps
aaah, okay! now i see them! is it possible for you to pack this theme into a new Ho!No!-Release with all this settings? Or do we need the files on the SD-Card? It whould be nice if everything was just packed into your nandroid! ;)
moviecut weißt du wie man mit dieser psd datei funktioniert?
edit: oder hast du das vllt so hingekriegt wie HO!NO und machts ein nandroid
Habs jetzt hinbekommen und finde es echt sehr schick! Die psd-datei brauchst du nicht (die ist wohl nur zum bearbeiten für fotoshop). nandroid klappt nicht, da du ja anscheinend die dateien auf der sd-karte brauchst...
also, so sollte es klappen:
1) zip downloaden und ins rootverzeichnis der microsd entpacken (psd-datei braucht nicht mitkopiert werden. nimmt nur unnötig platz weg..)
2) gallery starten, den ordner "Wallpaper" suchen. Dort sollten 8 Dateien drin sein. eine davon auswählen, dann auf "mehr" > festlegen als > Hintergrund
Dann (wichtig!!) den Bereich links festlegen. Also so groß wie möglich ziehen und dann komplett nach links an den rand.
(die App "Wallpaper Set and Save" benötigt man nicht!)
3) Launcher Pro Settings (Menü -> Properties)
Homescreen Settings
Default Screen = 1
Number of Rows = 5
Auto-fit Items = anhaken
Appearance Settings
Dock Background – Custom – den Ordner "Dock" suchen, dass einzige Bild dort auswählen.
Hide Notification bar = anhaken (hab ich nicht gemacht!)
Hide icon labels = anhaken (hab ich auch nicht gemacht!)
Disable wallpaper scrolling = haken raus!
4) Jetzt im Bildschirm ganz links, oben links lange drücken > Verknüpfungen > LauncherPro Shortcuts > screen_6.lps auswählen > Label-Text komplett löschen > auf das Icon klicken und ändern > in der Gallery den Ordner "Icon" auswählen. Dort müsste eine “blank.png” sein. jetzt habt ihr nen unsichtbaren link, der auf den sechsten desktop scrollt. Normalerweise liegt der jetzt schon oben links. ansonsten müsst ihr ihn suchen und nach oben links auf “Settings” schieben.
Das ganze dann mit Screen 5-2 machen und jeweils die unsichtbaren links links an der seite anordnen.
5) jetzt noch die 5 Verknüpfungen untem im lancher pro anpassen. Ich habs so gemacht:
Position 1 (links unten)
– lange drücken, > Verknüpfungen > LauncherPro Shortcuts > screen_1.lps auswählen > Label-Text löschen > Icon auf "blank.png” setzen
- lange drücken > "Swipe gesture action" auswählen > open App Drawer auswählen
Position 2 – Dialer auswählen (ich habe dailer one), als Icon in der gallery den Ordner "Manup's Simple Word Icons_Clean_164SET" suchen und ein passendes Icon nehmen (z.b. Dialer2.png)
Position 3 – SMS (handcent, Handsent.png)
6) Menü -> Preferences > Backup homescreen & settings ;)
Reaktionen: herzog2
Ich hab mal die Dateien von Ho!No! zusammen mit meinem Launcher Pro-Backup hochgeladen. Damit sollte es viel einfacher sein!
1) Zip ins Root-Verzeichnis der microsd entpacken.
2) Menü-Taste > preferences > "restore backup"
3) Hintergrund setzen (siehe Punk2 im Post über diesem..)
4) fertig!
  • HONO_scrolling theme_and_LP_Backup.zip
Reaktionen: herzog2
für die widgets die er im video hat muss man launcher pro plus haben so wie ich gelesen habe oder? wenn ja gibbet ein anderen weg das plus zu bekommen als es zu kaufen:winki:
kauf es dir bitte einfach. manche dinge sind einfach so gut, dass man die sich gönnen muss. alleine fürs widget resizen lohnt sich der plus. und der programmierer hats verdient. 3 euro, das ist ein großes pils inner kneipe!
Hey
sorry falls die Frage schon mehrmals gestellt wurde. Was brauche ich um das Theme zum laufen zu bringen. Habe meinen Stein so wie er ausgeliefert wurde, ohne irgendwelchen mod/hack usw
benötige ich einen um das theme zum laufen zu bringen?
Schöne Grüße
Ok, hat sich erledigt, geht auch ohne
andere Frage, ich möchte das MSN zeichen ändern, sowie musik und kalender ändern
wie kann ich das machen?
und wie bekomme ich die oberste zeile (uhr netzt usw) so hin wie beim threadersteller?
bei mir ist es aktuell ausgeblendet, kann ich ja aber einfach wieder einbleden
ajo, ich habe das hintergrund bild mit den blöcken
sobald ich mein Milestone drehe, sind die Bilder weg wo ich mich grad befinde (das msn zeichen, kalender usw)
lg
who schrieb:
Hey
Schöne Grüße
lg
1) die oberste Zeile bekommst Du, in dem Du den Ho!No!-Mod installierst
Link1: https://www.android-hilfe.de/forum/...n-ho-no-cm6-mod-fuer-das-milestone.56768.html
Link2 (immer aktuell!): [ROM] HO!NO! CM6 mod for 0.05-10.12.27-v2 - xda-developers
Als Anleitung kannst Du genauso vorgehen, wie im CM6-How-To beschrieben (Ho!No! ist nur eine leichte Modifikation davon, die vorgehensweise ist identisch. Nur das es sich dabei um ein Nandroid handelt und nicht um ein Update.zip)
Anleitung: https://www.android-hilfe.de/forum/...nogenmod-auf-dem-milestone-updated.62440.html
2) das mit dem Quer-Format ist leider so...kann man nichts dran machen...
Danke für deine Antwort
Ich möchte zwar mein Milestone bearbeiten wie ich möchte (themes, root usw)
aber ich habe immer angst das was schiefläuft und meine Garantie fusch ist -.-
dann flashst du ne full sbf und kannst es einschicken...man kann alles restlos rückgängig machen! und es lohnt sich, mal nen mod auszuprobieren! :scared:
glaub mir, du willst nicht mehr zurück ;)
Ich hab mein stein auch ers seit weihnachten hab aber am selben abend miui drauf gemacht und vorher g.o.t für den kernel un jez hab ich schon zich roms ausprobiert und nutze jez cm6.
Edit: habs soweit fertig nur will der app drawer net so ganz hab screen1.lbs und dann swipe aber swipe will net so gehn er geht zwar zum screen1 aber öffnet net den drawer. Und welches widget is das für die uhr auf screen1 die man im video sieht? Und das einstellungs widget kenn ich leider auch net der rest is ja launcher pro plus widgets.
Kennst du das einstellungs widget? @moviecut
Hey,
Ich habe Cm6 drauf und wollte gerade NOHO testen, aber ich schaffs nicht des aufs handy zu spielen...
habs als nadroid restore versucht und als update...wie gehts denn..habt ihr kurze step by step...ab der or reicht sagt mir nur wie (entpackt oder nicht) und wohin..und befehl im or
danke
Really nice work! What is the name of the clock and weather widget on the firstscreen? And which widget is the one on the settings screen?
Weiß irgendjemand wie die Widgets heißen?
Uhr= Simi Clock
Wetter = Beautiful widget
Gruß Bernd
Reaktionen: Diamond-X
würde mich auch interessieren. :thumbsup:
Vor allem das auf Seite 2
Oben: Simi Folder
Unten Beautiful widget die zusätzlichen Schalter Widget
Gruß Bernd
Sakaschi
Sakaschi
Sakaschi
basian mile
basian mile
basian mile
Otandis_Isunos
Otandis_Isunos
