[MOD] verbesserte Stock-Camera
  • 53 Antworten
rhrawr
rhrawr
Modifizierte Kamera des LG G2 mit einigen Änderungen gegenüber der Standard-Applikation (1080P @20MB/s und 720P @12MB/s).
Version 1:
1) Modified Camera.msm8970 for the Bettery Video Quality.
2) The Camera Now Shoots up faster than compared to Stock.
3) Increased the Image quality to 99 from 95 in Camera.msm8970
4) Increase The Video Bitrate of the Videos.
1080P Videos are now shot @ 30MB/s.
720P Videos are now shot @ 20MB/s.
5) Better Focusing as changes made in camera.msm8970.
Download:
Camera Mod V1
Version 2:
- Decreased the Max ISO to 1200 from 1600 (The More the ISO the more the noise in the pic)
- Decreased the ISO levels as such-
Note: It may show the Values of the ISO n settings as Such
ISO in Settings - ISO In Actual
1600 - 1200
800 - 650
400 - 310
200 - 200
100 - 100
Auto - Max in Auto (1200)
- Increased the sharpness from 90 to 95.
- Increased the JPEG Preview Quality to 99 from 90.
- Adjusted ISO to Max 200 For face Detection.
- Increased the Minimum FPS of the 1080P Video to 25 & Max to 40 FPS.
- Increased the Minimum FPS for60 FPS Video to 25.
- Many More Adjustments.
Download:
Camera Mod V2
Version 2.5:
- AntiBanding default set to]50Hz
- Exposure Compensation Decresed to -1
- Exposure Compensation Step Decresed to 0.1 from 1.24
- Focus Range adjusted.
- Tried to Fix Video FPS at night to atleast 25FPS. Failed
- Picture Sharpness Decreased to 85
Download:
Camera Mod V2
Version 2.5.1:
- Set FPS at 30 to 60 FPS Range.
- Set Exif Info details.
- Changed the YUV420 formats to YUV422. YUV420 are old formats.
- Decreased Maximum Exposure compensation to 15.
- Increased Minimum Exposure compensation to -15.
- Enhanced Smooth zoom.
Download:
Camera Mod V2.5.1
Version 2.5.2:
- Turned Edge Enhancement On.
- Turned Edge Enhance off. (Makes the night pics blurry)
- Changed Pic Decoder quality to 99.
- Changed Pic Encoder quality to 99.
- Decreased the Bit rates of the Videos as Follows:
1080@60 FPS : 20MB/s
1080@30 FPS : 15MB/s
720@30 FPS : 10MB/s
- Reason, No use of Increasing Bit Rate to Max because of -
1) Increased Size of the Video.
2) Cache Will Fill up so fast that Video wont be able to write on the Memory.
- Fixed the Low Light Video Lag.
- Changed the Default FPS to 30.
Download:
Camera Mod V2.5.2
Zurück zur Stock-Kamera:
Für Notfälle oder falls ihr keine Verbesserung feststellen könnt, einfach wieder die Stock-Kamera via Recovery flashen.
Download Stock
Original-Thread von Jishnu Sur auf XDA-Developers.com
Reaktionen: frenspa, webwude, eFCiKay und 2 andere
Hat jemand schon diesen mod getestet und kann positives berichten?
Das klingt ja sehr interessant!!!
Hab den Mod mal aufgespielt. mal schauen ob es was bringt. Wahrscheinlich wird man keinen wirklichen Unterschied sehen, oder?
Version 2 ist Online:
http://d-h.st/6WQ
V2 Details-
Sry die blöde frage. Wird es über den Trwp installiert.. ?
Ja, ist eine flashbare Zip.
Und der Autofokus zieht. Der ist richtig schnell. Mehr aber zurzeit nicht. Also Nachts immer noch gleich. Und bisschen mehr ISO und Bitrate.
Hat sich damit auch die Trägheit im low light verbessert?
Also low light man sieht mehr. Die FPS einbrüche sind noch da. Aber das lässt sich nicht beheben.
Die nerven richtig.
Ich kann in der Wohnung keine Bilder machen, überhaupt nicht.
Dumme frage.. Woher weiß ich ob der mod bei mir nun drauf ist?
Video aufnehmen, und dann die Bitrate anschauen.
Kann mal bitte jemand der den Mod getestet hat seine Erfahrungen schreiben im Vergleich zur Stock. Danke
Ich habe die Version 2.5.3 drauf.
Der Autofokus ist etwas schneller (aber noch kein Vergleich zum Z1 oder N3)
Die Videoaufnahmen in dunklen Räumen sind besser
"Verschlimmbessert" wird die Cam dadurch jedenfalls nicht ;)
Grüße
Reaktionen: chrissi77
Wo findest Du denn die 2.5.3?
Im jetzt Zustand kann man sagen, ist die cam nur für den außen Bereich bei sehr guten Licht Verhältnisse zu gebrauchen, wenn nicht sogar recht gut. Und das muss der potenzielle Käufer auch zu lesen bekommen und sollte wie mein Vorredner schon sagte, nicht unterm Tisch gekehrt werden!
XDA LG Camera MOD
erster Post unten ...
(Die Version 2.5.4 ist nur eine Versuchsversion)
Danke. Das werde ich gleich mal ausprobieren...
Soll man die zip per TWRP flashen?
Jap
Reaktionen: puffyx
