[Theme/Diskussion] SenseCream V4.0 BLUE für alle 4.0.4 Sense Roms - 15/08/12
  • 5 Antworten
Q
quercus
Gast
Quelle: XDA
[THEME] SenseCream Blue v4.0 - *ALL* OneX Sense4 ROMs (ICS4.0.4) [updated 13th Aug]
Download auf XDA
WHAT DO YOU GET
v4.0
  • Rebased on 2.15.x / 2.17.x base
  • changed common app background from black to endursa's fixed holo background
  • Few other minor cosmetic issues
Code:
v3.1
  • Fully themed Dialer/Phone.apk (including lockscreen answer button thanks to geenyous!)
  • Changed HTC green system text to blue (thanks to lex_is300 and jerrytan93)
  • Themed Play Store to match system appearance
  • Fixed notification pulldown - now supports transparency/custom backgrounds
  • changed common app background from dotted grey to black
v3.0
  • Rebased on latest HTC ROM base (2.05.401.2)
  • Dialer elements changed from green to blue (more dialer themeing to come!)
  • Few more graphical glitches addressed
v2.5
  • Themed HTC IME.apk
v2.4
  • Converted to the VillainTheme system, to provide compatibility with all Sense 4.0 ROMs
  • Made my own wifi icon, will try and post some screenshots tomorrow - let me know what you think
v2.3
  • Updated to be compatible with LeeDroid v6.x
  • Skin rebased on HTC Matte skin
  • Fixed wifi icon alignment
v2.2
  • Updated to be compatible with LeeDroid v5.1 and j4n87's Extended Quick Settings mod
  • Included Lee's fix for the notification pulldown glitch, and endursa's fixed holo background
v2.1
  • Themed framework-res/SystemUI/com.htc.resources - *blue/black theme throughout
  • Battery icons/charging icons
  • Other system icons*
  • Shutdown menu etc
  • Signal strength indicators
  • ICS styling for non-ICS apps (see Titanium Backup screenshot)
  • Blue progress bars (see Titanium screenshot and volume slider)
  • Blue overscroll / press highlights etc
  • Pop-up menu boxes / dialog boxes
  • Notification shade looks more ICS-style - you WILL lose the transparent notification shade mod
  • All stock HTC apps now have an ICS feel to them (calendar / HTC Music / Mail etc)
  • More things I forgot - seek and you shall find!
funzt einwandfrei .... klasse theme
update v 3.0
UPDATE
Version 3.1 - for ROMs built on the 2.05.x Base
ViperX v1.x - tested myself
InsertCoin v7.x - thanks to meleelord and robertus23
maXimus v2.x - thanks to jejehtc
ARHD v7.x - thanks to SweDunda and thom109 (though others have had issues, so proceed with care..and a nandroid backup!)
hallo
habe arhd 7.x..
theme instlliert, scheint auch soweit zu funktionieren, nur das mein sense ui sich beendet...kann man da was machen?
gruss
andy
4dro1d
4dro1d
4dro1d
djhymz
2WF
2WF
2WF
