hanschke
Gast
FEATURES
- Transparency
- Status Bar Layout
- Date Format
- Brightness Control
- Horizontal Recent Panel
- Clock Location
- Power Widget Enhancements
- Tabbed Layout
- Bottom Statusbar
- Volume control
- Statusbar Theming
USAGE
Reloaded ICS replaces the default user interfaces and adds many options for you to choose from.
Install CWM zip in recovery, clear dalvik cache, and reboot.
After reboot, click on the settings button in your expanded statusbar, or find the Reloaded ICS icon in your app drawer.
REQUIREMENTS
Any Deodexed CM9 ROM. Reloaded ICS is not compatible with tablets.
DOWNLOADS
http://forum.xda-developers.com/attachment.php?attachmentid=1045986&d=1336376220
xda-developers - View Single Post - [DEV] Reloaded ICS 1.9b3-041012 | CyanogenMod 9 UI Enhancements | Update: themes
This should work on all phones with CM9. This list is just some of the devices that have been tested.
CHANGELOG
May 7, 2012 - Version 1.9b4
- Statusbar icon alignment bug fix
- Reloaded Settings bug fixes
- New color settings for wifi/data indicator & data type
- Updated power widget icons to new CM ones
- Full Circle battery set added
- Stock signal/wifi icons with transparency
- (thanks to lilxflip for the stock transparency icons)
- Lots of other bugfixes
Known issues:
- Small display bugs while changing settings - toggle themes on/off to fix
- CM9 Torch toggle requires you to have torch app installed (net.cactii.flash2)
- (not really an issue but listed here to avoid erroneous posts)
- USB string bugs in certain kangs
April 10, 2012 - Version 1.9b3
- All text color bugs fixed when no themes are applied
- Initial battery icon implementation, 6 different types, more to come
- Alternate notification style, inspired from fake Jellybean screenshots
- Wifi/bluetooth switches no longer jump, acts like Settings toggles
- Other bugfixes
Known issues:
- Some display and alignment bugs when changing settings, restart or turn themes on/off to fix
- Hard to see activity indicator on top of new wifi/3g icons
April 2, 2012 - Version 1.9b2
- Restarting UI no longer necessary for changes
- Theming
- New app to allow better organization
- Navigation bar customization (CM9 navbar editing patched in)
- New wifi/3g/battery icons to allow for theming
- Too many to list!
March 20, 2012 - Version 1.7
- Audio widget - volume slider in statusbar
- Widget ordering, select how you want audio/backlight/power widget displayed
- Hide auto-brightness button option
- Date positioning options as requested
- Large battery text style
- Updated Reloaded Settings
[DEV] Reloaded ICS 1.9b4-050712 | CyanogenMod 9 UI Enhancements | All phones - xda-developers
