[THEME] für Sense ROMs - Revolution DHD - CLOSED
  • 911 Antworten
Nein, zumal es noch keinen Sinn macht dafür zu Themen. Capy hat noch einen guten Weg vor sich, bevor die ROM aus dem reinen DEV Stadium rauskommt.
Ok es läuft jetzt alles soweit :) Nur eins bekomm ich noch nicht hin, wie verändere ich die Icons so wie auf dem Bild, dass sie so transparent werden ? Gruß
dein letztes theme funktioniert reibungslos auch auf dem Desire Z
super arbeit^^
Revolution Theme for RCMix3D Bliss
  • Basically all known features
  • Themed all new stuff in com.htc.resources
  • Recoded new systemui (again...) in order to work as designed (if you use as base, please credit)
  • Transparent app drawer with 5x4
  • Transparent notifications
  • Inverted Dialer
  • Inverted Login
  • Custom background for app drawer and notifications
  • Flash your prefered font out of 5 different styles
  • Customize Rosie app drawer background by switching only applistbackground.png
  • Customize Notifications background by switching only status_bar_background.png
  • Add extra toogles or favorite apps to notifications with new toggles app - modded and based on elixir2
  • Themed AOSP widgets
  • Revolution Icon Pack
  • Themed Launcher Pro
  • Large parts of UI themed
Note: If you don`t need any part of this Theme like toggles, fonts or LauncherPro, just delete it from the update.zip, BEFORE you flash the Theme
Correct settings for status toggles, if you want to use the app (you find it in app drawer as "toggles", you need to open the app, hit "statusbar" and choose a name for your widget first.):
You can certainly do way more with the Elixir2 app, it also delivers tons of information about your device or you use the 7 spots for favorite apps.
Download Theme
Multiupload.com - upload your files to multiple file hosting sites!
Download Skin
Download Fonts
Stock Font - Multiupload.com - upload your files to multiple file hosting sites!
Revolution Font - Multiupload.com - upload your files to multiple file hosting sites!
Futura Font - Multiupload.com - upload your files to multiple file hosting sites!
Comfortaa Font - Multiupload.com - upload your files to multiple file hosting sites!
Caviar Font - Multiupload.com - upload your files to multiple file hosting sites!
Bauhaus Font - Multiupload.com - upload your files to multiple file hosting sites!
Note: Not all fonts will work as designed in all languages
Reaktionen: holzloeffel
kann mir bitte einer verraten welches Theme für das neue ARHD 5.2.6 geignet ist? Ich komme aus dem Loop Start nicht wenn ich das Theme für 2.50 Base flashe... sowohl das Revolution Theme als auch Sense HD Theme.
geflasht habe ich REvolution2.50_ClassicCRT_110711
Danke Euch für die Unterstützung!
@he_stheone64
Ist eine gute Arbeit, wie immer! :thumbup:
Warum machst du nur für die Sense 3.5 einen invertierten Dialer?
Ich hab immer noch nicht verstanden wie ich unter Sense die Icons ändern kann, kann mir das jemand schnell erklären ?
Das ist jetzt aber sehr allgemein gehalten, welche Icons willst Du verändern?
Revolution Theme for original DHD Sense 3.0 based ROM`s like ARHD 6.1
  • Inverted Dialer
  • Inverted Login
Note: Due to the current issues with m.10 editor not fully compiling fusion.apk images, it`s not possible at this time to properly theme HTC widgets, Rosie dock and some press effects. See my comment in ARHD thread Sept.6th.
Download Theme
Download Fonts
Auf dem Homescreen in die wie im Bild über mir
Das geht mit Desktop Visualizer
gibt es für arhd 6.1 auch bereits ein skin?
und sry ich habe gerade wenig zeit
kann man alles funktionen des Quicksettings wieder erhalten?
a) nein
b) noch nicht
Ich habe dein Theme (für mich die besten seit ich Android nutze) für Sense 3.5 angepasst.
Ich nenne es "Inferno-rot":
Sehr schön, kannst ja noch Elemente aus CODE Red mit reinpacken bei Bedarf.
Reaktionen: DynBunti
Revolution Theme Update for official Sense 3.0 ARHD 6.1
Credits: lyapota for great extended settings - thx
Besides a couple of changes I`m proud to present the first custom settings background for Sense ROM`s. This fits well into the environment of my other custom background mods.
Changelog:
  • Semi transparent dock
  • Froyo like scrolling in app drawer (no page by page)
  • Custom setting background
  • Extended quick settings Sense 3.5 style - thx to lyapota
Customization options:
App drawer background - applistbackground.png in rosie.apk
Notifications background - status_bar_background.png in systemui.apk
Quicksettings background - quicksettings_background.png in systemui.apk
Settings background - hestheone.png in framework-res.apk
Download Theme
Download Custom backgrounds - fitted for all 4 parts, just rename accordingly
Empty update.zip - use this to flash your custom mods
New setting background - YOU can change that with the new framework and settings hack.
An example, how it now also can look like with only 1 simple png swap
danke für dein theme
kanst du mir sagen wie ich die order der quicksettings ändern kann?
hab noch immer große probleme dein SystemUI zu decompilen bzw zu compile
9.png error ....
Immer erst die pngs aus einer stock systemui reinschaufeln in den hdpi Ordner, dann dekompilieren, edit ausführen und kompilieren, dann zurück. Am schnellsten geht das ganze mit dem Theme Porter von daneshm - http://forum.xda-developers.com/showthread.php?t=737526
Sortieren ist pipi einfach - mach die quicksettings.xml im Layout Ordner auf und sortiere, wie Du es brauchst.
Moin he_stheone64,
Erstmal grandioses Theme =)
Schlicht und Stilvoll ^^
Nun aber eine Frage bzw. Zwei:
1. Hast du die PSD womit du die Icons erstellst iwo in der ZIP versteckt oder woher bekomm ich sie bzw. bekommt man sie überhaupt ?
Denn mir fehlen ein paar wie für Whats App Tapatalk usw...
2. Wie bekomm ich am einfachsten in dein Theme eine "Inverted HTC Clock" ???
Hatte schon in das Thema geschrieben aber leider noch keine Antwort erhalten.
MfG
