[MOD] Sense 3.0 (incl. Rosie!) für Sense 2.1 Roms
  • 3 Antworten
Thief
Thief
Dauer-User
222
Hier ein richtig guter Mod von den xda's, der es ermöglicht auf allen custom Roms mit 2.36.405.8 Basis und Sense 2.1 Sense 3.0 zu flashen incl. 3D widgets und Rosie!
Das einzige Problem ist das es keine flashbare zip gibt, d.h man muss es per Root explorer oder adb auf das Desire HD kopieren!
[SIZE=+1]Changelog[/SIZE]
  • HTC Trace
    0.1: Initial release
  • Rosie 3 + Widgets
    - thanks to Virtuous Unity Team for the good base and resizing help
    - this is not a flashable zip.
    - for dev testing only
    - remove all old sense 2.1 widgets and idlescreen_clock.apk prior to pushing
    - do not push if you're not sure what you are doing
    - please do not report bugs
    - 0.15: Rosie: changed drawer grid view divider to look as in stock 2.1
    - 0.14: resized htc sense lwp included (Mode10Wallpapers.apk)
    - 0.13: clock 3d widget select city layout improvements
    - 0.12: Rosie: leap resized, thanks Diamondback
    - 0.11: More rosie resizes, fixed gaps in personalize/all apps (list view)
    - * thanks to diamondback and damo (Rosie_workspace from his rom as base for editing)
    - 0.10: Rosie resized[/b]
    - 0.10: Removed Calendar & widget
    - 0.9: Included initial port of sense 3.0 Calendar (now works wih 3.0 calendar widget)
    - 0.9: New widgets: MyShelf_Widget, conflicts: EReader widget
    - 0.8: Bad upload. do not use
    - 0.7: New widgets: com.htc.FMRadioWidget, com.htc.MusicWidget, HtcCalculatorWidget, HtcPhotoWidget[/b]
    - 0.6: Rosie.apk: tilt should be completely disabled now (i hope so)
    - 0.5: HtcWeather3DWidget.apk: update from widget now works
    - 0.4: Rosie.apk: drag & drop placement improved
    - 0.4: Rosie.apk: something about tilt, don't remember
    - 0.3: Rosie.apk: disabled gsensor tilt
    - 0.3: added htc people widget
    - 0.3: breaks: htccontactwidgets.apk
    - 0.2: added widgets: twitter, bookmarks, calendar, photo grid
    - 0.2: new incompatibilies: htccalendarwidgets.apk, com.htc.TwitterWidget.apk, htcbookmarkwidget.apk
    - 0.1: Sense 3 Rosie, Weather widget, mail widget, clock3d widget, stock widget, messages widget
Hier könnt ihr die Sense 3.0 Rosie laden (version 0.15):
http://api.viglink.com/api/click?fo...ther, etc - xda-developers&txt=Rosie3-0.15.7z
Ihr könnt natürlich auch den Sense 3.0 lockscreen, die Kamera app oder das wetter pack installieren, die findet ihr auch alle hier, wo auch der changelog und alle downloads aufgelistet sind:
[DEV] Sense 3 Ports for Sense 2.1 GB Roms: Rosie, widgets, lockscreen, weather, etc - xda-developers
So nun zur genauen installation bzw einrichtung der Sense 3.0 rosie und 3D widgets (soweit ich das verstanden habe):
Per Root explorer:
1: Entpackt die 7z datei und zieht auch dann den ordner mit den apks auf die sd
2: ersetzt die widgets und die rosie in system/apps mit den neuen und setzt die permissions richtig!
3: installiert die neuen apps und die rosie :)
Per adb:
Funktioniert genauso, nur glaube ich das die permissions nicht manuell gesetzt werden müssen.
Reaktionen: UWdus
Wie ist denn dein Eindruck bisher?
Habs noch nicht ausprobiert da ich heute coredroid 7.0 flashe wo das ja schon drauf ist.
Habs auf RevolutionHD und finde den Lockscreen 1. Sahne!
