G1 WLAN Probleme? Help!
  • 231 Antworten
Setzt doch mal (für die die keine Verbindung bekommen)
Ne statische IP: (beispiel Konfig mit Router auf der 192.168.1.1)
IP : 192.168.1.250
SubNetMask : 255.255.255.0
Gateway : 192.168.1.1
DNS : 192.168.1.1
dann mal testen ob die Internetverbindung geht bzw mal :
Terminal :
ping Google
und
ping 74.125.43.103
geht beides ? welches geht nicht ??
prot Recv-Q Send-Q Local Adress Foreign Adress
tcp: 0 0 192.168.0.101:39405 209.85.229.188:5228 ESTEBLISHED
udp: 0 0 0.0.0.0:0000 0.0.0.0:*
$ ping www.google.at
PING www.l.google.com (74.125.43.99) 56(84) bytes of data.
64 bytes from 74.125.43.99: icmp_seq=1 ttl=243 time=1012 ms
64 bytes from 74.125.43.99: icmp_seq=14 ttl=243 time=903 ms
From 192.168.0.101 icmp_seq=17 Destination Host Unreachable
From 192.168.0.101 icmp_seq=18 Destination Host Unreachable
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=26 ttl=243 time=574 ms
64 bytes from 74.125.43.99: icmp_seq=27 ttl=243 time=638 ms
64 bytes from 74.125.43.99: icmp_seq=50 ttl=243 time=745 ms
From 192.168.0.101 icmp_seq=78 Destination Host Unreachable
From 192.168.0.101 icmp_seq=79 Destination Host Unreachable
64 bytes from 74.125.43.99: icmp_seq=87 ttl=243 time=504 ms
ab hier umgeschalten = wlan aus 3g ein
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=100 ttl=235 time=435 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=101 ttl=235 time=385 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=102 ttl=235 time=977 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=103 ttl=235 time=460 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=104 ttl=235 time=288 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=105 ttl=235 time=418 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=106 ttl=235 time=327 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=110 ttl=238 time=576 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=111 ttl=238 time=285 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=112 ttl=238 time=277 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=113 ttl=238 time=287 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=114 ttl=238 time=278 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=115 ttl=238 time=289 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=116 ttl=238 time=275 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=117 ttl=238 time=285 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=118 ttl=238 time=277 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=119 ttl=238 time=287 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=120 ttl=238 time=287 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=121 ttl=238 time=297 ms
64 bytes from bw-in-f99.google.com (74.125.43.99): icmp_seq=122 ttl=238 time=289 ms
ping mit ip ohne dns funken ne weile besser..
nehm also mal an des meine dns server ziemlich grottig sind ..
stell mal auf opendns um ..
geb bescheid ...
lg
ok dns auf opendns umgestellt..
PING www.l.google.com (74.125.77.147) 56(84) bytes of data.
64 bytes from 74.125.77.147: icmp_seq=1 ttl=242 time=1025 ms
64 bytes from 74.125.77.147: icmp_seq=23 ttl=242 time=782 ms
From 192.168.0.101 icmp_seq=25 Destination Host Unreachable
From 192.168.0.101 icmp_seq=26 Destination Host Unreachable
From 192.168.0.101 icmp_seq=27 Destination Host Unreachable
From 192.168.0.101 icmp_seq=29 Destination Host Unreachable
From 192.168.0.101 icmp_seq=30 Destination Host Unreachable
From 192.168.0.101 icmp_seq=31 Destination Host Unreachable
^C
--- www.l.google.com ping statistics ---
31 packets transmitted, 2 received, +6 errors, 93% packet loss, time 127812ms
rtt min/avg/max/mdev = 782.624/903.824/1025.024/121.200 ms, pipe 3
$ ping 74.125.43.103
PING 74.125.43.103 (74.125.43.103) 56(84) bytes of data.
From 192.168.0.101 icmp_seq=14 Destination Host Unreachable
From 192.168.0.101 icmp_seq=15 Destination Host Unreachable
From 192.168.0.101 icmp_seq=19 Destination Host Unreachable
From 192.168.0.101 icmp_seq=21 Destination Host Unreachable
^C
--- 74.125.43.103 ping statistics ---
32 packets transmitted, 0 received, +14 errors, 100% packet loss, time 31062ms
64 bytes from 74.125.43.103: icmp_seq=2 ttl=243 time=1315 ms
64 bytes from 74.125.43.103: icmp_seq=3 ttl=243 time=316 ms
64 bytes from 74.125.43.103: icmp_seq=4 ttl=243 time=1275 ms
64 bytes from 74.125.43.103: icmp_seq=5 ttl=243 time=276 ms
64 bytes from 74.125.43.103: icmp_seq=8 ttl=243 time=312 ms
64 bytes from 74.125.43.103: icmp_seq=9 ttl=243 time=1255 ms
64 bytes from 74.125.43.103: icmp_seq=13 ttl=243 time=1234 ms
64 bytes from 74.125.43.103: icmp_seq=19 ttl=243 time=1163 ms
^C
21 packets transmitted, 8 received, 61% packet loss, time 20072ms
rtt min/avg/max/mdev = 276.489/893.806/1315.674/460.443 ms, pipe 2
ja also ... wie gesagt :) manchmal gehts manchmal nicht :)
der einzige unterschied sind die pipes durch die es läuft. nachdem aber android wie linux ist
kann man ja beim erstellen einer pipe nicht wirklich viel falsch machen .. naja .. wer weiss
lg
Bei mir ist das Problem, dass mein G1 das PW von meinem privaten WLAN nicht speichert. Ich muss es jedes mal bei der Verbindung neu eingeben. Was mach ich falsch? Wo kann man es speichern?
Vielen Dank im Vorraus.
Also, Freunde:
Ich hatte jetzt dauernd das Problem, das mein G1 zwar eine Verbindung zum Router herstellen konnte und auch eine IP bezogen hat - aber keinerlei Daten-Transfer vorhanden war - ich konnte also keine Internet-Verbindung aufbauen.
Ich habe jetzt mehrere Router ausprobiert (Belkin, Fritzbox, D-Link) und mich jeweils erfolglos durch alle möglichen Einstellungen gekämpft. Leider vergeblich, immer das gleiche Ergebnis.
Habe mir heute jetzt mal den linksys WRT54GL-DE geholt. Und was soll ich sagen - nach reibungsloser Installation läuft alles 100% perfekt. Das G1 funktioniert einwandfrei. Ohne irgendwelche speziellen Einstellungen à la Mac-Filter usw...
Werde mich melden falls sich was ändern sollte. Ich habe allerdings den Verdacht, das das G1 sich einfach mit den anderen Routern nicht "verträgt" (warum auch immer).
Vielleicht konnte ich ja irgendjemandem helfen.
Greets P.
kann das jemand bestätigen ??
Ich habe auch einen WRT54GL mit Tomato Firmware und es läuft 1a. Bei meinen Eltern daheim ein Telekom Speedblubb W500 oder so geht auch
Reaktionen: tobiasth
Ich kann nur vom Gegenteil berichten: WLAN mit dem G1 läuft bei mir mit allen möglichen Routern vom teuren NetGear über den billigsten D-Link bis zum professionellsten Industriezeug an der Uni über die unbekannte Marke im Starbucks problemlos. Und das mit RC29, RC30, JF 1.41 ADP und jetzt JF 1.43 ADP1.1.
Womit ich Probleme hatte war WEP. Aber wie zuvor schon gesagt, das braucht man ja auch nicht.
Hallo
Ich hatte bis vor zwei Minuten genau das gleiche Problem.
Mein G1 ist einfach nicht richtig Online gegangen.
Hab zwar eine IP bekommen jedoch bin ich nie mit dem Browser oder Market ins Web gekommen.
Ping hat auch nicht funktioniert....
Habe einen DI-524 für das WLAN.
Habe dann nochmal auf der DLink Seite nachgesehen und eine neue Firmware gefunden.
Zwar in Englisch aber das macht ja nix wenn es funktioniert.
DI-524_fw_revg2_313b02_ALL_en_20090105.zip
Firmware eingespielt und sieht da.
Mein G1 ist Online :)
Kein Fehler mehr oder sonstwas.
Also vielleicht einfach mal nach einer neuen Firmware für euren Router suchen. :)
Bei mir hat es funktioniert.
lg
Isehwurscht
PS: Gebe aber natürlich keine Garantie beim Firmware einspielen. Wenn man die Falsche erwischt kann es sein das das Gerät hinüber ist.
Also VORSICHT!!
Hi und Hallo,
bin hier ganz neu und dies ist mein erster Eintrag.
Ich hatte das anscheinend gleiche Problem wie einige hier, sich in ein gesichertes Wlan einzuklinken.
Ich gebe zu, dass ich den Threat nicht zu Ende gelesen habe als ich das Problem "erahnte". Es ist also inzwischen vieleicht erledigt. Trotzdem, eventuell hilft es ja jemandem mal, hier meine Problembeseitigung.
Es war das Passwort. Genau genommen die Passwortlänge. Bei meinem G1 ist keine Wlan-Verbindung möglich, sobald die Anzahl von 22 Zeichen überschritten wurde.
Jetzt läuft alles fehlerfrei und schnell.
Meine Wlan-Einstellungen auf'm Router:
Modell: W701 Telekom
SSID: Sichtbar
DHCP - ON
Leasetime - Auto
Sicherheit: WPA2 PK
MAC-Filter: ON
Kanal: 11
Noch ein Hinweis:
War das Passwort zu lang und falsch, zeigte er mir an. Netz außer Reichweite.
War das Passwort einfach nur zu lang, kam die Ansage: Es konnte keine Netzwerverbindung aufgebaut werden.
So long, vieleicht ist damit Jemandem geholfen.
Der Bergspion
Tachen,
also ich habe weiter das Problem, das ich zwar mit meinem WLAN verbunden bin, aber keine Seite aufgebaut bekomme.
Selbst wenn ich mein WLAN auf mache, klappt kein Datenfluss.
Hallo Wasabi,
hast Du evtl. auf dem Router DHCP auf ON gestellt und dem G1 eine feste IP gegeben? Es gibt Router, die das nicht geregelt bekommem. Bei XP wird dann zum Beispiel die Verbindung auch als "verbunden" angezeigt aber sie funktioniert nicht. Keine Konnektivität usw....
Das G1 zeigt den Konnektivitätsfehler aber nicht an.
Kannst Du von einem PC Dein G1 pingen? Oder kannst Du vom G1 den Router oder einen anderen PC pingen?
Gruß der Bergspion
Wasabi schrieb:
Tachen,
Na dann, auf mit der Diagnose... PC ans WLAN ran und gucken...
Was ist die Ausgabe von
Code:
nslookup www.google.com
bzw.
Code:
host www.google.com
Was sagt
Code:
ping 192.168.0.1
Was sagt
Code:
ping 74.125.77.104
Es könnte z.B. so aussehen (unter Windows XP, nur für dich ;)):
Code:
C:\Documents and Settings\Darth Mutilarous>nslookup www.google.com
Server:  iser.urz.unibas.ch
Address:  131.152.1.1
Non-authoritative answer:
Addresses:  74.125.77.104, 74.125.77.147, 74.125.77.99, 74.125.77.103
Aliases:  www.google.com
C:\Documents and Settings\Darth Mutilarous>ping 74.125.77.104
Pinging 74.125.77.104 with 32 bytes of data:
Reply from 74.125.77.104: bytes=32 time=78ms TTL=238
Reply from 74.125.77.104: bytes=32 time=75ms TTL=238
Reply from 74.125.77.104: bytes=32 time=80ms TTL=238
Ping statistics for 74.125.77.104:
    Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 75ms, Maximum = 80ms, Average = 77ms
Control-C
^C
Das wäre ein gutes Resultat. :)
P.S.: Danke für den Hinweis mit dem Passwort, Bergspion. :)
@ Autarkis
Hier sind meine Ergebnisse.
  • Dok2.doc
Hallo Wasabi,
Beim localen Pingen hast Du 192.168.0.1 angepingt. Diese IP wird es bei Dir nicht geben, da Dein Router (alicebox) wie relativ weit oben steht die 192.168.1.1 besitzt.
Der Router und wie ich annehme der PC sind online, sonst könntest Du nicht erfolgreich google.de anpingen. Du sagtest ja, Dein Wlan wäre komplett offen. Lass sich Dein G1 bitte wieder mit dem Wlan verbinden und gehe dann mal bitte mit Deinem PC auf deinen Router und schau mal, ob Du die Mac-Adresse Deines G1 in den eingetragenen PC's auf Deinem Router findest. Und guck mal welche IP es vom Router bekommen hat.
Wenn ja, dann pinge mal bitte von Deinem PC diese IP an und sag uns das Ergebnis.
Mir kriege döös schon hi.
Gruß Bergspion
Auf meine Meinung zum Thema wirst du noch mehrere Stunden warten müssen, da mein G1 keine .doc - Dateien anzeigt... ;)
für alle .doc muffel
Vielen Dank Schluepferknoten.
Also, das WLAN ist meiner Meinung nach nicht 100% richtig mit dem Internet verbunden, und zwar stimmen insbesondere die DNS-Einstellungen nicht ganz.
Eventuell ist es auch eine Eigenart dieser Alicebox, aber die Antwort auf nslookup Google sollte mit der IP-Adresse(n) von Google beantwortet werden und nicht mit der von www.google.com.localdomain.
Durchsuch mal das WLAN-Setup und lösche die Zeichenfolge ".localdomain" überall raus.
  • LaueGTH
winne
Kouya1600
Kouya1600
Kouya1600
x-domi-x
  • x-domi-x
x-domi-x
x-domi-x
