[ROM][4.3][JB] iHackers v3.0 [Xperia Z1] FW 14.2.A.1.136
  • 55 Antworten
NeBuKa
Servus Leute!
Edit Anfang:
[ROM] iHackers v3.0 [Xperia Z1], die Links für das v3 funktonieren nicht mehr, es wird die v4.1 verlinkt, hier nochmal Links für das v3 und Kernel dafür.
Features:
Release:
  • Based on Stock JB 4.3 (Official). Firmware - 14.2.A.1.136.
  • Aroma Based Installer with Loads of Options.
  • The ROM has been fully Deodexed.
  • All the Apps have been Zipaligned manually. Added Zipalign on Boot.
  • The ROM has been Busyboxed.
  • Support for init.d has been enabled. Several init.d Scripts have been added.
  • The ROM is Rooted. The Installer contains all the Rooting Methods/Apps Preincluded.
  • SQLlite3 Support Added and Optimized.
  • Supports all variants of Xperia Z1.
General:
  • Advanced Power Menu Added. Full Screen Toggle and Screenshot Options Integrated too.
  • Xposed Installer, Performance Control and LBE Security Master Integrated With Settings Menu.
  • Long Press on Back Button on Navigation Bar Kills the Forground Application.
  • Softkeys with Various DPI (28, 32, 36, 40, 44, 48) Added.
  • Battery % Icons Added. Go to Power Management and Disable Status Bar Information for Removing Battery Percentage Text.
  • Clear all Recent Apps Button Added on Recent Apps Panel.
  • Clock Position Centered By Default.
  • NFC Screen Off Option Enabled.
  • Disabled Scrolling Cache for Smoother Experience.
  • Enabled Voicemail and Speed Dial Settings Menu.
  • Call Record Option Added.
  • Added Various Fonts.
  • Security Check Disabled.
  • Transparent SystemUI and Navigation Bar.
  • Added Multilanguage Support for Various Languages.
  • Updated All Sony and Other Apps Including Home, Albums etc.
  • Heavily Debloated Useless Apps.
  • Added New iHackers Bootanimation.
  • 360 Degree Screen Rotation Enabled.
  • Added Insecure adbd Support.
  • Force Enabled USB Debugging.
  • Disable USB Debugging and ADB Notifications.
  • All Reboot and Remounting Issues Fixed.
  • Wide Resources and Dependencies Fixed.
Installer:
  • Several Addons and Applications Included.
  • Bloatware Removal Options Added (Refer to Notes)
  • Google Glass Apps (Transparent) Included and All Updated To Latest Versions.
  • SCPU Control Apps Added, CPU Control FCs Resolved too.
  • More Apps Added Which are Optional To Install in Aroma Version. All of them are updated to the Latest Versions.
  • Per App Details (What the App Does, Should It be removed, Will removal of the App be helpful or problematic) Added in Bloatware Removal Script.
  • A Few More Camera Apps Added, All the Camera Apps are optimized to work on Xperia Z1. You will notice better quality and smoother experience while using the included camera apps.
  • Sevral Launchers added and Optimized for Use on iHackers ROM. Iconset and Themes for alternate Launchers have been added too. All the included Launchers are Fast, Stable, Lagfree, Super Smooth and Full of Features.
  • Iconset have been replaced with a beautiful collection of 3500+ Icons, That means you will now have MIUI Style Icons for almost all the apps you install, If you feel that there are still some apps left out whose icons are not included let me know I will include them in the next release.
  • The Default Wallpaper for both Desktop and Lockscreen have been changed.
  • Several other UI Improvements, which you will know once you use the ROM.
Fixes:
  • All Lag Almost Totally Gone. Smoothness, Stability, I/O, Fluidity, Responsiveness have increased all together to a considerable extent.
  • Finally 4K Video Works Perfectly and Without Any Lag Whatsoever.
  • Brightness Problem Fixed. If you still face a Problems Let Me Know.
  • CPU Overclocking More stable and Less Battery Draining Now, Refer to Notes for More Details.
  • Optimized the ROM for better support, Faster and Smoother Interface and Lesser Incompatibility Issues.
  • Fixed the Issue of Small Contact Picture display during calling even if a HighRes Picture is attached to the Contact.
  • Mysterious Contact and Phone FCs Completely Resolved, Contact and Call Log Scrolling Completely Lagfree and Super Smooth too.
  • Proximity Sensor Delay and Several Other Bugs Related to Proximity Sensor Almost Completely Gone If you still face problems refer to notes.
  • Video Recording more stable, Smoother and With Higher FPS. Audio Recording More Cleaner and NoiseFree. Auto-Focus Issues during Video Recording Resolved too.
  • Speaker Volume Issues Solved, You Should Use the Sound Mods to adjust it better, PureAudio and ViPER4Android work very well with the ROM, its your preference if you want to install one or both, they can both work good together too, Let me know if you aren't able to configure them properly.
  • Elasticity and Transitions on Launcher are Smoother and Better Now.
  • In Call Volume Issue Solved.
  • Glitching, Itching and Flickering Issues Resolved.
  • Removed Almost All Bloatware.
  • Streamlined Redundant Components.
  • Optimized WiFi Speed and GPS Positioning.
  • UI and Refresh Rate Improvements.
  • Fixed Song Play Failure When Screen is Off.
  • Optimized Memory Usage and Memory Management.
  • Fixed FCs Issues on Several Apps.
  • Improved Browser Responsiveness and FC Issues.
  • Increased 3G and 2G Speed.
  • Fixed Network Unavailability Problem.
  • All Third Party Apps Removed for Minimal Version.
  • All Bloatware Removed for Both Aroma and Minimal Version.
  • Fixed Zero Brightness Problem Completely.
  • Battery Consumption and Heating Problems Solved.
  • Lockscreen UI, Wallpaper and Theme Changed.
  • Night Blindness Issues Solved.
  • All Apps Updated to Latest Versions.
Graphics:
  • Added Pure™Graphics HD + Rendering Version (Credits to Jeeko).
  • Enabled GPU Rendernig.
  • Enable Dithering but did not Affect Consumption.
  • Enabled Use of the GPU for the Touch Capacitation and Management.
  • Improved Video HW Rendering.
  • Increased Benchmarking Scores on the AnTuTu Graphic Rankings.
  • Improved Pixel Density, DPI and Brightness.
  • Eliminated Lag System with the Video Entropy Generator.
  • Liquified the UI.
Audio:
  • Added PureAudio™ Engine v1.0 (Credits to Jeeko).
  • Clearer Sound.
  • No More Track Noises.
  • Now, The ROM is also compatible with the Headphones that don't support Audio Render at 60KHz.
  • Wherever possible, arranged for the Conversion of the Songs (in background) below 256 kbps to 320kbps.
  • During Playback of Songs / Sounds make a Soft Frequency Scaling to Reduce Noise and Highlight the Track.
  • The ROM now offers More Powerful and Closed Bass.
  • Efficient even with Sony's/Samsung's Generic Headphones.
  • Improved the In-Call Audio Hearing and Transmission a lot.
  • Enhanced the Speakers' Audio and Compression for Playing Music without Headphones in High Quality.
Performance:
  • Added PurePerformances™X Mod (Credits to Jeeko)
  • Radically Improved RAM Management for MIUI (Lags... Adios!).
  • Graphics Improved: Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 System Tweaks.
  • Multimedia Scan Time Drastically Reduced.
  • Network Improvements, 3G Experience Even in 2G Modality.
  • All SQlite Database Optimized.
  • Enabled Hardware Features Turned Off by Default for a Better Experience and Stability.
  • Greatly Increased the AnTuTu Scores: Try it to believe it!!
  • Reduced the Startup Time Per Reboot.
  • Now You can Play Ported Games Without Lags.
  • The Device now itself Cleans the System Every 24 Hours, The Cache Every Week and The Dalvik Every Month (Cronos Easter Egg).
  • Automatically Zipalign on Each Boot (Sensitive to The User).
Battery:
  • Drastically Decreased the Battery Drain.
  • Check the Activities that Consume Too Much Battery and Stops Them with PureWakelocks™.
  • When the Phone is Charging Reduces System Services for Faster Charging.
  • The Battery is Calibrated on Every Boot.
  • Disabled System Animations When the Battery is Nearly Exhausted.
  • Improvements in build.prop as Regards The Part of Consumption.
  • Enabled a Non-Aggressive Dithering to save CPU.
  • When You Lock the Device, The Engine makes sure that the GPU is turned off.
  • Enabled Deep Sleep.
Tweaks:
  • Audio Drivers and Libraries all Updated to Latest Versions with more tweaks for Better and Cleaner Sound.
  • Optimized Music Player Libraries and Increased Volume and Effects. Music Player and MusicFX FCs Completely Resolved.
  • Camera Tweaked for Better Focus and Quality, Its Comparively Better Now.
  • Parts of Bravia Engine.
  • Parts of CrossBreeder (credits to dev).
  • Parts of Adrenaline Engine (credits to dev).
  • PureGraphics HD.
  • V6 supercharger.
  • Enabled Video Entropy Generation (Like Seeder).
  • Slightly Improved the Scaling of the Frequencies.
  • Lightend the Load on the CPU Switching the Workload to GPU Rendering.
  • Enabled the Swap Partition in Android (Experimental).
  • Added Several INIT.D Tweaks and Scripts.
  • Default CPU Frequency and Governer Changed.
  • Disabled Normalized Sleeper to Fix Wakelocks.
  • Capacative Backlight Issues Fixed.
  • Flickering Issues Finally Fixed.
  • Battery Scripts and Tweaks (Sleepers).
  • Minifree Handler Tweak.
  • Internet Speed Tweaks.
  • VM Management Tweaks.
  • Kernel Tweaks.
  • SysCTL Tweak.
  • EXT4 Tweaks.
  • IO Tweaks.
  • Lot More That I Do Not Remember++
Sound Effects Fix For Z1 C6903 4.3JB .136 StockRom Download
[MOD] Smart call handling from Z2, Integrated Setting Download für iHackers ROM
Edit Ende:
Ich möchte Euch heute die iHackers 2.1 vorstellen (inkl. jetzt endlich final funktionierender, ausführlicher Installationsanleitung)! -> MEINER Meinung nach sollten die Installationsanleitung IMMER narrensicher geschrieben werden, dann erspart man sich / den Mods zahlreiche Postings! :)
Originalpost (XDA): [ROM] iHackers v2.0 [Xperia Z1] - xda-developers
!!! LOCKED BOOTLOADER !!!
VERSIONEN/DOWNLOAD:
AROMA-VERSION: KOMPLETTVERSION (Details im XDA-Post) - iHackers v2.1 [Aroma] Xperia Z1 | FilesForest
MINIMAL-VERSION: ABGESPECKTE VERSION (Details im XDA-Post) - iHackers v2.1 [Minimal] Xperia Z1 | FilesForest
ADDON-PACK: BEINHALTET ALLES AUSSER DEM ROM AN SICH (Details im XDA-Post) - iHackers v2.0 [Addons Pack] Xperia Z1 | FilesForest
IHACKERS-KERNEL: iHackers Kernel v2.1 [Xperia Z1] | FilesForest
Features:
Code:
[B][U]Release:[/U][/B]
[LIST]
[*]Based on Stock JB 4.3 (Official). Firmware - 14.2.A.0.290.
[*]Aroma Based Installer with Loads of Options.
[*]The ROM has been fully Deodexed.
[*]All the Apps have been Zipaligned manually. Added Zipalign on Boot.
[*]The ROM has been Busyboxed.
[*]Support for init.d has been enabled. Several init.d Scripts have been added.
[*]The ROM is Rooted. The Installer contains all the Rooting Methods/Apps Preincluded.
[*]SQLlite3 Support Added and Optimized.
[*]Supports all variants of Xperia Z1.
[/LIST]
[B][U]GENERAL:[/U][/B][INDENT]
[LIST]
[*]Advanced Power Menu Added. Full Screen Toggle and Screenshot Options Integrated too.
[*]Xposed Installer, Performance Control and LBE Security Master Integrated With Settings Menu.
[*]Long Press on Back Button on Navigation Bar Kills the Forground Application.
[*]Softkeys with Various DPI (28, 32, 36, 40, 44, 48) Added.
[*]Battery % Icons Added. Go to Power Management and Disable Status Bar Information for Removing Battery Percentage Text.
[*]Clear all Recent Apps Button Added on Recent Apps Panel.
[*]Clock Position Centered By Default.
[*]NFC Screen Off Option Enabled.
[*]Disabled Scrolling Cache for Smoother Experience.
[*]Enabled Voicemail and Speed Dial Settings Menu.
[*]Call Record Option Added.
[*]Added Various Fonts.
[*]Security Check Disabled.
[*]Transparent SystemUI and Navigation Bar.
[*]Added Multilanguage Support for Various Languages.
[*]Updated All Sony and Other Apps Including Home, Albums etc.
[*]Heavily Debloated Useless Apps.
[*]Added New iHackers Bootanimation.
[*]360 Degree Screen Rotation Enabled.
[*]Added Insecure adbd Support.
[*]Force Enabled USB Debugging.
[*]Disable USB Debugging and ADB Notifications.
[*]All Reboot and Remounting Issues Fixed.
[*]Wide Resources and Dependencies Fixed.
[/LIST]
[/INDENT][B][U]INSTALLER:[/U][/B][INDENT]
[LIST]
[*]Several Addons and Applications Included.
[*]Bloatware Removal Options Added (Refer to Notes)
[*]Google Glass Apps (Transparent) Included and All Updated To Latest Versions.
[*]SCPU Control Apps Added, CPU Control FCs Resolved too.
[*]More Apps Added Which are Optional To Install in Aroma Version. All of them are updated to the Latest Versions.
[*]Per App Details (What the App Does, Should It be removed, Will  removal of the App be helpful or problematic) Added in Bloatware Removal  Script.
[*]A Few More Camera Apps Added, All the Camera Apps are optimized to  work on Xperia Z1. You will notice better quality and smoother  experience while using the included camera apps.
[*]Sevral Launchers added and Optimized for Use on iHackers ROM.  Iconset and Themes for alternate Launchers have been added too. All the  included Launchers are Fast, Stable, Lagfree, Super Smooth and Full of  Features.
[*]Iconset have been replaced with a beautiful collection of 3500+  Icons, That means you will now have MIUI Style Icons for almost all the  apps you install, If you feel that there are still some apps left out  whose icons are not included let me know I will include them in the next  release.
[*]The Default Wallpaper for both Desktop and Lockscreen have been changed.
[*]Several other UI Improvements, which you will know once you use the ROM.
[/LIST]
[/INDENT][B][U]FIXES:[/U][/B][INDENT]
[LIST]
[*]All Lag Almost Totally Gone. Smoothness, Stability, I/O, Fluidity, Responsiveness have increased all together to a considerable extent.
[*]Finally 4K Video Works Perfectly and Without Any Lag Whatsoever.
[*]Brightness Problem Fixed. If you still face a Problems Let Me Know.
[*]CPU Overclocking More stable and Less Battery Draining Now, Refer to Notes for More Details.
[*]Optimized the ROM for better support, Faster and Smoother Interface and Lesser Incompatibility Issues.
[*]Fixed the Issue of Small Contact Picture display during calling even if a HighRes Picture is attached to the Contact.
[*]Mysterious Contact and Phone FCs Completely Resolved, Contact and Call Log Scrolling Completely Lagfree and Super Smooth too.
[*]Proximity Sensor Delay and Several Other Bugs Related to Proximity  Sensor Almost Completely Gone If you still face problems refer to notes.
[*]Video Recording more stable, Smoother and With Higher FPS. Audio  Recording More Cleaner and NoiseFree. Auto-Focus Issues during Video  Recording Resolved too.
[*]Speaker Volume Issues Solved, You Should Use the Sound Mods to  adjust it better, PureAudio and ViPER4Android work very well with the  ROM, its your preference if you want to install one or both, they can  both work good together too, Let me know if you aren't able to configure  them properly.
[*]Elasticity and Transitions on Launcher are Smoother and Better Now.
[*]In Call Volume Issue Solved.
[*]Glitching, Itching and Flickering Issues Resolved.
[*]Removed Almost All Bloatware.
[*]Streamlined Redundant Components.
[*]Optimized WiFi Speed and GPS Positioning.
[*]UI and Refresh Rate Improvements.
[*]Fixed Song Play Failure When Screen is Off.
[*]Optimized Memory Usage and Memory Management.
[*]Fixed FCs Issues on Several Apps.
[*]Improved Browser Responsiveness and FC Issues.
[*]Increased 3G and 2G Speed.
[*]Fixed Network Unavailability Problem.
[*]All Third Party Apps Removed for Minimal Version.
[*]All Bloatware Removed for Both Aroma and Minimal Version.
[*]Fixed Zero Brightness Problem Completely.
[*]Battery Consumption and Heating Problems Solved.
[*]Lockscreen UI, Wallpaper and Theme Changed.
[*]Night Blindness Issues Solved.
[*]All Apps Updated to Latest Versions.
[/LIST]
[/INDENT][B][U]GRAPHICS:[/U][/B][INDENT]
[LIST]
[*]Added Pure™Graphics HD + Rendering Version (Credits to Jeeko).
[*]Enabled GPU Rendernig.
[*]Enable Dithering but did not Affect Consumption.
[*]Enabled Use of the GPU for the Touch Capacitation and Management.
[*]Improved Video HW Rendering.
[*]Increased Benchmarking Scores on the AnTuTu Graphic Rankings.
[*]Improved Pixel Density, DPI and Brightness.
[*]Eliminated Lag System with the Video Entropy Generator.
[*]Liquified the UI.
[/LIST]
[/INDENT][B][U]AUDIO:[/U][/B][INDENT]
[LIST]
[*]Added PureAudio™ Engine v1.0 (Credits to Jeeko).
[*]Clearer Sound.
[*]No More Track Noises.
[*]Now, The ROM is also compatible with the Headphones that don't support Audio Render at 60KHz.
[*]Wherever possible, arranged for the Conversion of the Songs (in background) below 256 kbps to 320kbps.
[*]During Playback of Songs / Sounds make a Soft Frequency Scaling to Reduce Noise and Highlight the Track.
[*]The ROM now offers More Powerful and Closed Bass.
[*]Efficient even with Sony's/Samsung's Generic Headphones.
[*]Improved the In-Call Audio Hearing and Transmission a lot.
[*]Enhanced the Speakers' Audio and Compression for Playing Music without Headphones in High Quality.
[/LIST]
[/INDENT][B][U]PERFORMANCE:[/U][/B][INDENT]
[LIST]
[*]Added PurePerformances™X Mod (Credits to Jeeko)
[*]Radically Improved RAM Management for MIUI (Lags... Adios!).
[*]Graphics Improved: Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 System Tweaks.
[*]Multimedia Scan Time Drastically Reduced.
[*]Network Improvements, 3G Experience Even in 2G Modality.
[*]All SQlite Database Optimized.
[*]Enabled Hardware Features Turned Off by Default for a Better Experience and Stability.
[*]Greatly Increased the AnTuTu Scores: Try it to believe it!!
[*]Reduced the Startup Time Per Reboot.
[*]Now You can Play Ported Games Without Lags.
[*]The Device now itself Cleans the System Every 24 Hours, The Cache Every Week and The Dalvik Every Month (Cronos Easter Egg).
[*]Automatically Zipalign on Each Boot (Sensitive to The User).
[/LIST]
[/INDENT][B][U]BATTERY:[/U][/B][INDENT]
[LIST]
[*]Drastically Decreased the Battery Drain.
[*]Check the Activities that Consume Too Much Battery and Stops Them with PureWakelocks™.
[*]When the Phone is Charging Reduces System Services for Faster Charging.
[*]The Battery is Calibrated on Every Boot.
[*]Disabled System Animations When the Battery is Nearly Exhausted.
[*]Improvements in build.prop as Regards The Part of Consumption.
[*]Enabled a Non-Aggressive Dithering to save CPU.
[*]When You Lock the Device, The Engine makes sure that the GPU is turned off.
[*]Enabled Deep Sleep.
[/LIST]
[/INDENT][B][U]TWEAKS:[/U][/B][INDENT]
[LIST]
[*]Audio Drivers and Libraries all Updated to Latest Versions with more tweaks for Better and Cleaner Sound.
[*]Optimized Music Player Libraries and Increased Volume and Effects. Music Player and MusicFX FCs Completely Resolved.
[*]Camera Tweaked for Better Focus and Quality, Its Comparively Better Now.
[*]Parts of Bravia Engine.
[*]Parts of CrossBreeder (credits to dev).
[*]Parts of Adrenaline Engine (credits to dev).
[*]PureGraphics HD.
[*]V6 supercharger.
[*]Enabled Video Entropy Generation (Like Seeder).
[*]Slightly Improved the Scaling of the Frequencies.
[*]Lightend the Load on the CPU Switching the Workload to GPU Rendering.
[*]Enabled the Swap Partition in Android (Experimental).
[*]Added Several INIT.D Tweaks and Scripts.
[*]Default CPU Frequency and Governer Changed.
[*]Disabled Normalized Sleeper to Fix Wakelocks.
[*]Capacative Backlight Issues Fixed.
[*]Flickering Issues Finally Fixed.
[*]Battery Scripts and Tweaks (Sleepers).
[*]Minifree Handler Tweak.
[*]Internet Speed Tweaks.
[*]VM Management Tweaks.
[*]Kernel Tweaks.
[*]SysCTL Tweak.
[*]EXT4 Tweaks.
[*]IO Tweaks.
[*]Lot More That I Do Not Remember++
[/LIST]
[/INDENT]
Was beinhaltet das ROM im AROMA für Optionen:
Code:
Devices:
    Xperia Z1 C6902
    Xperia Z1 C6903
Kernels:
    iHackers Kernel
    DooMKernel
Mods:
    Audio Mod
    Graphics Mod
    Performance Mod
Sound Mods:
    ALSA Volume Boost
    Pure Audio
    Viper4Android
Bootanimations:
    iHackers v1
    iHackers v2
    Sony Xperia
Root:
    SuperUser (Koush)
    SuperSu (Chainfire)
    SuperUser (ChainsDD)
Miscellaneous:
    Dark Settings
    Stock SystemUI
    Translucent SystemUI
    Standard Gapps
    LBE Security Master
[B][U]Personalization:[/U][/B]
Launchers:
    Xperia Home
    Apex Launcher
    Nova Launcher
    Nexus Launcher (GEL)
    Advanced Xperia Launcher
Iconsets/Themes:
    MIUI v5 Iconset (3rd Party Launchers)
Camera Addons:
    Motiongraph
    Motionshot
    Panorama 360
    Wikitude Places
Android 4.4 (KitKat) Apps:
    Google Experience Launcher
    Google Calender
    Google Camera
    Google Gallery
    Google Hangouts
Xposed Modules:
    20 MP Superior Auto
    Advanced Power Menu
    App Settings
    Bootmanager
    Gravity Box
    Network Speed Indicator
    Ultimate Dynamic Navbar
    xBlast Tools
    Xperia Flip Settings
    XUI Mod
Glass Apps:
Main -
    Calendar
    Email
    Genie Widget
Google -
    Gmail
    Google Calendar
    Google Hangouts
    Google Keep
    Google Music
    Google Now
    Google Play Store
    Google Plus
    Google Videos
    Google YouTube
    Google Voice
    Google Settings
    Google Translate
Miscellaneous -
    AdAway
    Apollo Music
    Battery Stats Plus
    Box
    Copy
    Dropbox
    ES File Explorer
    Flash Player
    Facebook
    GitHub
    IMDb
    Mighty Text Tablet
    Paypal
    Twitter
    Whatsapp
    Zedge
Installationsanleitung für iHackers 2.0 (Custom Rom) für LOCKED BOOTLOADER:
BITTE AN TA-BACKUP DENKEN (ANLEITUNG HIER IM FORUM)!
benötigte Tools/Dateien:
- Flashtool (neueste Version)
- cubeundcube (https://twitter.com/cubeundcube/status/403131776786112512)
- iHackers 2.0 (iHackers v2.1 [Aroma] Xperia Z1 | FilesForest)
- Dual-Recovery
-- 1x flashbare Version (Confixx)
-- 1x installierbare Version (Confixx)
- SuperSU-Fix (-=- [NUT]'s XDA download page -=-)
- XPOSED-Installer (http://forum.xda-developers.com/attachment.php?attachmentid=2480630&d=1388291418)
- richtigen Kernel:
-- C6903 (Z1 mit LTE) (http://bit.ly/C6903-290)
-- C6902 (Z1 ohne lTE) (http://bit.ly/C6902-290)
Vorbereitung:
... des PCs:
- Ordner auf C: mit Namen 'wie beliebt' erstellen
- Flashtool + cubeundcube in diesem Ordner installieren
- ebenfalls in diesem Ordner drei Unterordner erstellen ('Kernel', 'Dual-Recovery' und 'Firmware')
-- die installierbare Dual-Recovery-Version in den Ordner 'Dual-Recovery' im entpacken Zusatand (wenn nicht schon entpackt) packen
-- die entsprechende Kerneldatei (ACHTUNG welche Z1-Version man hat: mit oder ohne LTE) in den Ordner 'Kernel' packen
--- C6903 (Z1 mit LTE)
--- C6902 (Z1 ohne lTE)
... des Z1s:
- Z1 mit PC verbinden
- Treiber installieren lassen
- auf internem und externem Speicher einen Ordner mit Namen 'wie beliebt' erstellen
- folgende Files in diese Ordner kopieren (erspart das Suchen/Laden in Zukunft):
-- iHackers 2.0
-- die flashbare Dual-Recovery-Version
-- XPOSED-INSTALLER
-- SuperSU-Fix
In Zukunft müssen dann bei einem iHackers-ROM-Update nur ein paar Dateien von 1) und 2) getauscht/ersetzt werden! Rest ist ja dann schon auf der externen SD-Karte!
1) Firmware-Downgrade auf .534 (MUST HAVE WENN MAN AUF .257 ODER GAR SCHON AUF .290 IST):
- Z1 im ausgeschalteten Zustand mit USB-Kabel mit dem PC verbinden und dann die LEISERTASTE drücken
-> Z1 leuchtet rot und sofort grün (innerhalb von 1 Sekunde)
- Flashtool am PC starten (Flashtool zeigt an das Z1 im Flash Mode ist)
- Klick auf Blitz
- Flash Mode auswählen
- oben rechts (im Flashtool) auf '...' klicken und die heruntergeladene .534-Firmware suchen/auswählen
- unten rechts (im Flashtool) auf 'Flash' klicken und abwarten bis Balken ganz am Ende ist (ACHTUNG: hält ca. 2cm vor Ende für 1 Minute an)
- FERTIG (Z1 ist jetzt auf Firmware .534)
- Rebooten lassen
- First-SetUp machen (ACHTUNG: KEINE SOFTWARE INSTALLIEREN LASSEN VOM PLAY STORE! KEIN OTA-UPDATE MACHEN!)
2) Z1-Rooten mit cubeundcube:
- Herstellerinformationen -> letzte Option -> 7x drücken bis da steht, dass man jetzt Entwickler ist
- USB-Debugging einschalten
- Unbekannte Quellen einschalten
- im 'cubeundcube'-Ordner die 'install.bat' doppelklicken
- Z1 mit dem PC verbinden
- Rootvorgang solltet automatisch starten (oder den Anweisungen auf dem Bildschirm folgen)
- Z1 bootet 1x neu
- FERTIG (Z1 ist gerootet und SuperSu ist installiert)
Dual-Recovery installieren (Confixx):
- entpacken
- *.bat starten und die 'SuperSU-Version' auswählen
- Anweisungen folgen (ACHTUNG: Man muss 1x am Z1 Etwas bestätigen)
SICHERSTELLEN, DASS ALLE DATEIEN VON OBEN AUF DEM TELEFON SIND!!!
SICHERSTELLEN, DASS DAS Z1 NICHT MEHR MIT DEM PC VERBUNDEN IST!!!
4) Boot ins Recovery:
- Z1 rebooten lassen
- nach dem 'SONY'-Logo vibriert das Z1 2x
- SOFORT nach dem Vibrieren die LAUTERTASTE gedrückt halten bis man im Recovery ist
5) Installationsreihenfolge im Recovery (Rom, SuperSU-Fix, Dual-Recovery, XPOSED):
- Wipen (die Option mit dem FactoryReset nehmen)
- wenn fertig die Option 'Install ZIP from external SD-card' auswählen
- iHackers 2.0-ROM von der externen SD-Karte auswählen und mit den gewünschten Optionen installieren
- am Ende die 'Reboot'-Option ausschalten
- auf 'Fertig' gehen
- man kommt wieder zurück ins Recovery
- erneut die Option 'Install ZIP from external SD-card' auswählen
Lt. iHACKERS ist ein SuperSu-Fix bei 2.1 nicht mehr notwendig
- SuperSu-Fix von der externen SD-Karte auswählen und flashen
- flashbares Dual-Recovery von der externen SD-Karte auswählen und flashen
Lt. iHACKERS ist ein Install vom XPOSED bei 2.1 nicht mehr notwendig
- XPOSED von der externen SD-Karte auswählen und flashen
ACHTUNG! GANZ WICHTIG!
- unter 'Advanced' bitte 'POWER OFF' auswählen
- im folgenden Fenster eines der 'NOs' auswählen
- Z1 schaltet sich jetzt aus
6) Kernel .290 installieren:
- USB-Kabel am PC anschließen und LEISERTASTE drücken (Z1 blinkt kurz rot, dann grün)
- Flashtool starten (Flashtool zeigt an das Z1 im Flash Mode ist)
- Klick auf Blitz
- 'Flash Mode' auswählen
- oben rechts (im Flashtool) auf '...' klicken und den heruntergeladenen .290-Kernel im Ordner 'Kernel' auf C: auswählen
- FERTIG
- Rebooten lassen
ANMERKUNG:
Habt Ihr hinterher Probleme mit SuperSu und/oder XPOSED bitte (leider ist es so) die komplette Anleitung erneut durchgehen und dann aber SuperSu-Fix und XPOSED im Recovery mit flashen!
!!! UNLOCKED BOOTLOADER !!!
Bei Nutzung von iHackers mit einem UNLOCKED BOOTLOADER unterscheidet sich die Installationsanleitung nur in ein paar Punkten.
Voraussetzung:
- Z1 mit bereits ungelocktem Bootloader und installiertem Custom-Recovery (DUAL ist nicht zwingend notwendig, kann aber genutzt werden)
- AROMA-VERSION: KOMPLETTVERSION (Details im XDA-Post) - iHackers v2.1 [Aroma] Xperia Z1 | FilesForest
- richtigen Kernel:
Ist Euer Bootloader noch gelockt muss dieser erst wie folgt geöffnet werden!
Ihr benötigt für das flashen lediglich ein Recovery (ich würde dennoch die installierbare, oben aufgeführte Dual-Version nehmen)! SupuerSU/Root etc. wird nicht benötigt!
-> Alternativ könnt Ihr auch den Advanced Stock Kernel von iHackers via fastboot flashen um die Recovery zu erhalten) Ihr könnt euch also das flashen der SuperSU sparen, nach der oben genannten Unlock Anleitung.
Der Installationsvorgang:
1. Kopiert iHackers 2.1 (AROMA-VERSION) auf die externe Speicherkarte eures Handys.
2.
Bootet in die Recovery und führt folgende Wipes aus: "Advanced Wipe -> Dalvick cache, cache, data, internal storage, system. Danach führt vorsichtshalber noch einen "Format Data" aus.
3.
Nun geht auf Install -> Wählt die ROM von der externen Speicherkarte aus und lasst die Installation durchlaufen.
WICHTIG:
SOLLTET IHR BEREITS AUF .290 sein entfallen die nachfolgenden Schritte: 4, 5, 6 und 8
4.
Nach Abschluss -> geht auf Home. Dann auf Reboot (NEIN, NICHT REBOOTEN!!!) -> und wählt dort "Power off" aus!
5. Öffnet am PC Flashtool und wählt die Stripped.ftf aus (Diese muss sich im Flashtool/firmwares Ordner befinden!). Geht auf "flash" und wartet bis das Flashtool euch auffordert das Handy im Flashmode anzustöpseln.
6. Steckt dann das Handy an und lasst den Flashvorgang durchlaufen.
7. Handy abstöpseln, booten, freuen :D
8. (optional) Nun könnt Ihr einen Custom Kernel eurer Wahl (in diesem Fall den iHackers 2.1) flashen!
Der ursprüngliche Beitrag von 21:19 Uhr wurde um 21:21 Uhr ergänzt:
BEVOR JEMAND FRAGEN SOLLTE:
BOOTLOADER-UNLOCK AUF EIGENE GEFAHR!!!
Gruß + Viel Spaß mit dieser geilen ROM,
NeBuKa
Deine Anleitung gefällt mir. Bis auf einen Punkt :
Entwickler wirst du nach 7x drücken.
Und warum zur Hölle empfiehlst du Kingo Root? Ist doch mittlerweile ausreichend bekannt, dass die vom Nutzer Daten übermitteln.
Würde dir cubeundcube oder B1n4ry empfehlen (funktioniert nur mit 534 Roms). Die Anleitung und Bezugsquellen findest du in meiner Root Anleitung.
LG meet
Reaktionen: trahzebuck
Anleitung modified,
NeBuKa
Hallo!
iHackers hat entschieden sein ROM nur noch gegen Spende zu offerieren! Somit werde ich mich dann wohl mal nach einem anderen CR umschauen!
NeBuKa
Finde monx da besser vom Modell her - bei dem kriegt man als Spender halt die "early releases " und einige Features früher. Naja schade um iHackers. Wobei es auch ein wenig verständlich ist. Schließlich nimmt man ja auch mehrere Euro in die Hand für ne App, wenn die einem zusagt. Allerdings muss man ne Rom auf Herz und Nieren testen, bevor man damit zufrieden sein kann. Und dass geht dann halt nicht, wenn es keine free Version gibt.
LG.meet
Die ROM ist schon abgefahren, keine Frage! Hatte diverse schon mal getestet und iHackerst ist schon premium!
Echt blöd! Dachte halt immer, dass auf XDA Privatleute Ihr KnowHow gerne mit der Community für LAU teilen!
So sieht es ja fast so aus wie: 'Hey Leute, brauche Kohle ...!'
Der ursprüngliche Beitrag von 07:27 Uhr wurde um 08:02 Uhr ergänzt:
< UPDATE >
So, Freunde der Nacht!
Ich habe mich mal durchgerungen! Ich lade gerade die 2.1 runter und werde berichten und ggf. updaten!
NeBuKa
Der ursprüngliche Beitrag von 08:02 Uhr wurde um 08:26 Uhr ergänzt:
< UPDATE DES TUTs >
- neueste FULL-ROOT-DUAL-CWM-DOWNLOADLINKs hinzugefügt (NUT flash + install)
- Roottool 'KINGO (KINGO sendet Userdaten ins WWW)' durch 'cubeundcube' ersetzt und Anleitung dementsprechend angepasst (Downloadlinks, ...)
- einen gravierenden Fehler im Tut geändert: Ich schrieb ursprünglich, dass man vor Kernelflash (am Ende) auf 'YES - DISABLE RECOVERY BLABLA' gehen muss! Das war falsch! Man(n)/Frau muss eines der 10 'NOs' auswählen da sonst ROOT umgehend verloren geht!
So! Bin in den nächsten Tagen auf 2.1 und werde berichten! Anleitung ist die gleiche für Locked BL!
Würde mich freuen, wenn mir ein gewiefter CR-User meine Anleitung hier für einen UNLOCKED BOOTLODER zukommen lässt (as detailled as possible), dann packe ich die auch noch mit rein oben! ^^
In diesem Sinne,
NeBuKa
Der ursprüngliche Beitrag von 08:26 Uhr wurde um 10:02 Uhr ergänzt:
BITTE LESEN: [ROM] iHackers v2.0 [Xperia Z1] - Page 116 - xda-developers
(ab Seite 109 geht es los) - ich denke hier wird in Kürze Etwas passieren! Entweder die ROM wird bei XDA gekickt oder die ROM wird doch 'Donation-Free'! :)
11:00: XDA-Admins haben sich eingeschaltet!
Reaktionen: meetdaleet
:p
War aber abzusehen. XDA sieht sowas eigentlich nicht gerne.
LG meet
Ansich fand ich die Rom echt gut,auch mit ner Spende find ich ok,die Entwickler stecken halt sehr viel Zeit und Herzblut rein,genau wie die Leute die hier helfen,aber es wäre ok jedem selbst zu überlassen ob er Spenden will oder nicht.
Ich hatte ein paar Problemchen mit der Rom,was nicht heisst das sie schlecht ist!!
Bin auf Stock zurück, ist mir sehr wohl,besonders die Akkulaufzeit.
Habe mir das Framework installiert und zb den Boot Manger,das Adv Power Menü und habe das was ich brauche.
Akkulaufzeit für mich überragend.
meetdaleet schrieb:
:p
LG meet
Nachdem das bis zu MikeChannon - dem XDA-Gott - vorgedrungen ist, wird diese Praxis keinen Bestand haben. Hoffentlich schmeißen die ihn nicht gleich raus.
Und jetzt hat monx den Verdacht geäußert, das iHackers bei ihm gemopst hat. :-(
Wobei sich die Jungs in den Z1 Foren schon eine Belohnung verdient hätten. Bei den Usern die da rumlaufen.... Habe Ende 2013 vom Note auf das Z1 gewechselt und hätte nicht gedacht, dass es noch schlimmer sein könnte... :-(
Das Rom selbst ist gut aufgebaut, die Root Probleme scheinen im Griff zu sein. Die monx Version gefällt mir dennoch besser.
Ich finde die Arbeit der Developer beachtlich.
Gerne belohne Ich selbige auch mit einer Spende!
Aber die von iHacker gewählte Praxis ist halt nicht mit der Philosophie von XDA zu vereinbaren.
LG meet
Auwaia! Dann bin ich ja mal gespannt, was da passieren wird! Ich denke iHackers ist gerade im Tiefschlaf (kommt ja aus Indien)! Mal abwarten was er dazu schreiben wird, etc.!
Der ursprüngliche Beitrag von 12:54 Uhr wurde um 14:24 Uhr ergänzt:
14:00: XDA-Superadmin hat sich eingeschaltet!
NABEND MÄDELS!
So, es ist vollbracht und iHACKERS 2.1 ist online for public and donate-free!
Anleitung und deren Links entsprechend angepasst!
Viel Spaß,
NeBuKa
Jajaja :p
Und nur weil paar andere Leute und Ich ausgeflippt sind im XDA Forum :D
Naja aber finde, dass schon gut, dass er das zu spüren bekommen hat, dass das nicht korrekt ist. Auch wenn es scheinbar nur ein Missverständnis war.
Aber seine komische "Ich bin CEO einer sehr sehr sehr sehr großen" Firma (iHackers) Leier, nervt ein wenig. Wenn Ich mir die Homepage ansehe, sieht mir die Firma nicht sonderlich groß aus. Geschweige denn "professionell".
LG meet
ALLES wird gut, XDA formattiert da ggf. hier und da drüber! ^^
PS 1:
Ich suche noch jemanden, der meine Anleitung für UL aufsetzt! Ich traue mich noch nicht, somit möchte ich da Nichts falsch machen!
PS 2:
Kann es sein, dass im XDA-TUT da die Dual-Recoveries fehlen? Warum wird bei einem UB kein Dual-Recovery in der TUT erwähnt? *confused*
NeBuKa
Du brauchst keine extra ULBL Anleitung zu schreiben :)
Die Installation ist identisch.
Man muss halt einen Custom Kernel drauf haben, für die Recovery bzw. eine UB Recovery.
Lediglich das TA-Backup fällt weg, da der BL ja schon geöffnet wurde. Vorteil des ULBL ist ja nur, dass man nen Custom Kernel (ala DooMKernel) nehmen kann.
LG meet
Der ursprüngliche Beitrag von 18:45 Uhr wurde um 18:49 Uhr ergänzt:
Und den BL öffnet man ja nicht und hat keine Recovery oder so drauf :p
Oder keinen Custom Kernel....
Lediglich der Initial Boot mit der Stripped.ftf (KERNEL) muss gemacht werden. Danach kann man im fastboot den Custom Kernel wieder draufflashen.
LG meet
Du Streber! Schreib das mal für Leute, die nicht vom Fach sind (wie mich)! *scherz*
Wenn hier jemand ins Forum kommt, ist neu, liest das, dann geht er direkt zu einer anderen ROM! *gg*
Mach Dir doch bitte kurz mal die Mühe, nimm meine LB-Tut und bastel die doch mal bitte eben für UB um, dann setze ich die oben rein und dann kann jeder entscheiden!
Was meinst?
Unlocked Bootloader:
Wenn Ihr die ROM mit einem Unlocked Bootloader nutzen wollt, unterscheiden sich die Installationen nur marginal.
Voraussetzungen:
- Xperia Z1
- Unlocked BL mit installierter Custom Recovery
- Die flashable.zip aus dem OP sowie die Stripped.ftf (Kernel)
Sollte euer BL noch gelocked sein:
Öffnet diesen nach folgender Anleitung :(TA-Backup nicht vergessen :D)
https://www.android-hilfe.de/forum/...chliessen-ta-backup-recovery-root.515383.html
Ihr benötigt für das flashen lediglich eine Recovery. SupuerSU/Root etc. wird nicht benötigt!(Alternativ könnt Ihr auch den Advanced Stock Kernel von iHackers via fastboot flashen um die Recovery zu erhalten) Ihr könnt euch also das flashen der SuperSU sparen, nach der oben genannten Unlock Anleitung.
1. Kopiert die flashable.zip auf die Externe Speicherkarte eures Handys.
2. Bootet in die Recovery und führt folgende Wipes aus: "Advanced Wipe -> Dalvick cache, cache, data, internal storage, system. Danach führt vorsichtshalber noch einen "Format Data" aus.
3. Nun geht auf Install -> Wählt die flashable.zip von der externen Speicherkarte aus und lasst die Installation durchlaufen.
4. Nach Abschluss -> geht auf Home. Dann auf Reboot (NEIN, NICHT REBOOTEN!!!) -> und wählt dort "Power off" aus!
8. (optional) Nun könnt Ihr einen Custom Kernel eurer Wahl flashen! (DooMKernel oder ähnliches...)
Hier für Copy/Paste: :D
[B][COLOR="red"]Unlocked Bootloader:[/COLOR]
Voraussetzungen:
- Xperia Z1
[Spoiler]
[/B]
[url]https://www.android-hilfe.de/forum/anleitungen-fuer-sony-xperia-z1.1453/anleitung-bootloader-oeffnen-schliessen-ta-backup-recovery-root.515383.html[/url]
[COLOR="red"]Ihr benötigt für das flashen lediglich eine Recovery. SupuerSU/Root etc. wird nicht benötigt!(Alternativ könnt Ihr auch den Advanced Stock Kernel von iHackers via fastboot flashen um die Recovery zu erhalten)[/COLOR] Ihr könnt euch also das flashen der SuperSU sparen, nach der oben genannten Unlock Anleitung.
[/spoiler]
[COLOR="Blue"][B]Der Installationsvorgang:[/B][/COLOR]
[spoiler]
[COLOR="Red"][B][I]1.[/I][/B][/COLOR] Kopiert die flashable.zip auf die Externe Speicherkarte eures Handys.
[COLOR="Red"][B][I]2.[/I][/B][/COLOR] Bootet in die Recovery und führt folgende Wipes aus: "Advanced Wipe -> Dalvick cache, cache, data, internal storage, system. Danach führt vorsichtshalber noch einen "Format Data" aus.
[COLOR="Red"][B][I]3.[/I][/B][/COLOR] Nun geht auf Install -> Wählt die flashable.zip von der externen Speicherkarte aus und lasst die Installation durchlaufen.
[COLOR="Red"][B][I]4.[/I][/B][/COLOR] Nach Abschluss -> geht auf [B]Home[/B]. Dann auf Reboot ([COLOR="red"][B]NEIN, NICHT REBOOTEN!!![/B][/COLOR]) -> und wählt dort "[COLOR="red"][B]Power off[/B][/COLOR]" aus!
[COLOR="Red"][B][I]5.[/I][/B][/COLOR] Öffnet am PC Flashtool und wählt die Stripped.ftf aus (Diese muss sich im Flashtool/firmwares Ordner befinden!). Geht auf "flash" und wartet bis das Flashtool euch auffordert das Handy im Flashmode anzustöpseln.
[COLOR="Red"][B][I]6.[/I][/B][/COLOR] Steckt dann das Handy an und lasst den Flashvorgang durchlaufen.
[COLOR="Red"][B][I]7.[/I][/B][/COLOR] Handy abstöpseln, booten, freuen :D
[COLOR="Red"][B][I]8. (optional)[/I][/B][/COLOR] Nun könnt Ihr einen Custom Kernel eurer Wahl flashen! (DooMKernel oder ähnliches...)
[/spoiler]
Der ursprüngliche Beitrag von 19:26 Uhr wurde um 19:30 Uhr ergänzt:
So, jetzt kannst du's kopieren :D
LG meet
Reaktionen: trahzebuck und NeBuKa
@meetdaleet
Na evtl. könnte man noch ergänzen, dass 4. bis 6. nicht notwenig ist, wenn man schon von einer .290er kommt. :)
Ich hab mich nach der Anleitung vom Entwickler gerichtet.
Kann Nebuka ja als optional markieren, so wie meinen letzten schritt (8).
LG meet
Hallo zusammen!
So, TUT angepasst!
Was fehlt mir noch:
- Link zur flashable-zip
- Link zum Kernel
Mag ja sein das ich blind bin ...
NeBuKa
superpotjera
superpotjera
superpotjera
