wwallace1979
Enthusiast
- 914
- Themenstarter
- #341
Neues Update auf Version 4.0.0 erschienen und eingepflegt
eXistenZ Premium V4.0.0
Quote:
- Based on latest 5.1.1 23.4.A.1.232
- Reworked Lockscreen Weather code and Layout.
- Reworked Lockscreen Weather Settings.
- Xperia Z5 Lockscreen Clock.
- Reworked Low Battery code.
- Add Compass Quick Toggle.
- Reworked Notification Quick Toggle to diplay only working Sound Modes.
- Add Power Menu & Reboot Intent to framework.
- Add Power Menu Quick Toggle (Click to Power Menu, Long Press to Reboot Options).
- Add Power Menu in Navigation Bar (Replace Left Menu).
- Add Advanced Reboot Options to Power Menu (Reboot, Recovery, Bootloader, Soft Reboot, Restart SystemUI).
- Add One Click Reboot.
- Add Visualizer Quick Toggle.
- Reworked Volume Quick Toggle to collapse Notification Panel when pressed.
- Add Brightness Mirror (Long press Brightness Slider is showing Background instead of Notification Panel).
- Allow Coloring of Brightness Slider.
- Allow Coloring of Ripple Effect.
- Removed Navigation Bar Cursor Control who was causing problem with themes.
- Optimize Notification Panel View code.
- Allow Individual Coloring of all Status Bar Header texts.
- Add Status Bar Header Custom Background (Default, Modern, Poly HD).
- Reworked Status Bar Header and Quick Toggles coloring settings, they are now all in same place.
- Reworked Network Controler code.
- All Quick Toggles available on Lockscreen.
- Add Auto Start Settings.
- Add Location based Wifi Settings.
- Xperia Z5 Animations CPU Boost.
- Xperia Z5 Scroller CPU Boost.
- Xperia Z5 OverScroller Fling CPU Boost.
- Xperia Z5 Launching App CPU Boost.
- Xperia Z5 Assertive Display Optimization.
- Reworked eXistenZ theme.
- Xperia Z5 apps (Phonebook, Conversations, Email, Setup Wizard, Clock Widget, Home Launcher, Calendar, Clock, Skin Core, Small Apps Launcher & Small Apps, Xperia Keyboard, Themes, Weather, Weather Widget, ...).
- Xperia Z5 settings (Image Enhancement, Smart Features, ...).
- Xperia Z5 Wallpapers.
- Various code Optimizations and fixes.
