Z1 will sich nicht flashen lassen
  • 4 Antworten
Jogele1
ich versuche schon seit ein paar std mein handy zu flashen da mein systemui defekt war allerdings lässt sich das handy nicht flashen warum auch immer....
hier ist mal der log des flashtools
07/004/2015 14:04:18 - INFO - <- This level is successfully initialized
07/004/2015 14:04:18 - INFO - Flashtool Version 0.9.14.0 built on 12-02-2014 22:45:00
07/004/2015 14:04:23 - INFO - Device connected in flash mode
07/004/2015 14:04:29 - INFO - Selected null
07/004/2015 14:04:29 - INFO - Flash canceled
07/004/2015 14:04:38 - INFO - Selected Bundle for Sony Xperia Z1 (C6903). FW release : 14.4.A.0.108. Customization : GENERIC_DE
07/004/2015 14:04:38 - INFO - Preparing files for flashing
07/005/2015 14:05:48 - INFO - Device disconnected
07/006/2015 14:06:46 - INFO - Please connect your device into flashmode.
07/006/2015 14:06:56 - INFO - Device connected in flash mode
07/006/2015 14:06:56 - INFO - Opening device for R/W
07/006/2015 14:06:56 - INFO - Reading device information
07/006/2015 14:06:56 - INFO - Phone ready for flashmode operations.
07/006/2015 14:06:57 - INFO - Current device : C6903 - BH900Q3Z13 - 1277-0154_R2C - 1274-8313_14.4.A.0.108 - EURO-LTE_14.4.A.0.108
07/006/2015 14:06:57 - INFO - Start Flashing
07/006/2015 14:06:57 - INFO - Processing loader.sin
07/006/2015 14:06:57 - INFO - Checking header
07/006/2015 14:06:57 - INFO - Flashing data
07/006/2015 14:06:57 - INFO - Loader : S1_Root_6732 - Version : LOADER_RELEASE_MSM8974_28_AID_4 / Boot version : S1_Boot_MSM8974_Rhine1.2_LA1.04_19 / Bootloader status : ROOTABLE
07/006/2015 14:06:57 - INFO - Processing partition-image.sin
07/006/2015 14:06:57 - INFO - Parsing boot delivery
07/006/2015 14:06:57 - INFO - Phone boot version : S1_Boot_MSM8974_Rhine1.2_LA1.04_19. Boot delivery version : S1_Boot_MSM8974_Rhine1.2_LA1.04_19
07/006/2015 14:06:57 - INFO - Boot delivery is up to date. Nothing done for boot bundle
07/006/2015 14:06:57 - INFO - Processing kernel.sin
07/006/2015 14:06:59 - INFO - Processing rpm.sin
07/006/2015 14:06:59 - INFO - Checking header
07/006/2015 14:06:59 - INFO - Flashing data
07/006/2015 14:06:59 - INFO - Processing fotakernel.sin
falls es nötig ist kann ich noch erwähnen dass ich es auf die selbe firmware flashen wollte und zwar 14.4.A.0.108.GENERIC_DE hand yist ohne vertrag gekauft und gerootet ist es auch noch. Wenn ich das handy versuche neuzustarten kommt eine englische meldung "the software update failed..." dannach schaltet sich das handy automatisch wieder aus. Ich glaube das waren alle wichtigen infos ich hoffe ihr könnt mir helfen :D
Okay Hans selber gemacht irgendwie mit PC comepenion hab kein root mehr und Android Vers 5.
Wenns nach 10 minuten immernoch nicht weiter geht, dann einfach nochmal probieren oder mal eine andere .ftf ausprobieren
Das problem ist leider immernoch nicht behoben habs jetzt mit 3 ftfs versucht hat alles nicht geklappt es bleibt immer genau da hängen. Und wad icj interessant finde ist wenn ich das Handy von usb Kabel entferne dann sollte eigentlich die meldung kommen device disconnected. Aber es kommt nichts. Ich hab echt keine ahnung mehr was ich tun soll. Mit pc companion lässt sich das handy flashen halt nur auf die neueste androud version was ich schlecht finde.
läuft bei dir ein Antiviren programm im hintergrund? Wenn ja > Beenden.
Drauf achten das vor dem Start von flashtool keine adb.exe im Taskmanager läuft
  • 1DROID
1DROID
Sarahlein
  • Sarahlein
Aaskereija
Aaskereija
Netbook
Netbook
