Hen Ry
Enthusiast
- 1.687
Aktuelle Version
[Z1-C69XX][Z1-C69XX]KitSlim_AMG[Evo 9][02/08/2014]The power is nothing without the mastering
ältere Versionen
[Z1-C69XX]14.4.A.0.108-KitSlim_AMG [Evo 7]
14.4.A.0.108-KitSlim_AMG [Evo 6]
14.3.A.0.7XX | KitSlim_AMG [Evo5][24/06/2014]
14.3.A.0.757 | KitSlim_AMG [Evo3][04/06/2014] & 14.3.A.0.757 | KitSlim_AMG [BlackEvo3][04/06/2014]
14.3.A.0.757 | KitSlim_ AMG [Evo2Fix][01/06/2014][Fully Stable] & 14.3.A.0.757 | KitSlim_ AMG[BlackEvo2][01/06/2014][Fully Stable]
14.3.A.0.757 | KitSlim_ AMG [Evo1][28/05/2014][Fully Stable][/URL] & 14.3.A.0.757 | KitSlim_ AMG [BlackEvo1][28/05/2014][Fully Stable]
14.3.A.0.757 | KitSlim_AMG [Edition][21/05/2014] & 14.3.A.0.757 | KitSlim_AMG [BlackEdition][21/05/2014]
- Merged on 761 baseband
- SemcApk at day
- Sound Option (Thanks @Rajeev and his team)
- Live on YouTube™ (if it's available in your country)
- Pen Mod (Thanks @RyokoN)
- NFC disable at first boot
- Fix my error msm thermal in "set_governor.sh"
- Of best tweaks
- Best stability
- Best rendering
KitSlim_AMG [Evo 6]:
_14.4.A.0.108
_Deodexed
_Zipalign
_Optimised
_Efficiency Optimal
_Stamina Optimal
_FullRoot
_FullOption
_DualRecovery
_AMG Performance Center
_Z2 features imported
_Z2 Cam
_4K, 120Fps timeshift video,...
_Live on YouTube™ (if it's available in your country)
_Option reboot
_Phone records, "HD" image id,...
_Smart Call Handling
_Wallpapers Z1, Z, AMG
_Themes Z1, Z, AMG
_Clock Theme accent color
_TaskKiller button
_Metalic AMGTheme [Bicolore (Gray/Red)]
_Slim
_Fast
_Enduring
_The Best Of Sony
_Two Gapps Available:
SlimGapps
------------------}Works Whitout the Gapps
FullGapps
_14.4.A.0.108
_Deodexed
_Zipalign
_Optimised
_Efficiency Optimal
_Stamina Optimal
_FullRoot
_FullOption
_DualRecovery
_Z2 Cam
_Option reboot
_Themes Z1, Z, AMG
_TaskKiller button
_Slim
_Fast
_Enduring
_The Best Of Sony
SlimGapps
FullGapps
KitSlim_ AMG [Evo3][04/06/2014][Fully Stable]
[Evo3][04/06/2014]:
- Governor "ondemand" by default for a better stamina and less of heat (set_governor.sh)
- Scheduler "deadline" by default for a better stamina and less of heat (init.d)
- Fix "servicemenu"
- Fix of errors (init.qcom.post_boot.sh,...)
- Added of art-filter from Z2 (with the ��
- Fix "servicemenu"
KitSlim_AMG [Evo2][Fully Stable]
KitSlim_FullPowerV4.1 Final Stage[14/05/2014][Fully Stable]
KitSlimFullPowerV4[14/05/2014]
KitSlim_FullPowerV4 Final Stage[11/05/2014]
KitSlimFullPowerV3.4.2[09/05/2014]
KitSlimFullPowerV3.4.1[03/05/2014]
KitSlimFullPowerV3.4[02/05/2014]
KitSlimFullPowerV3.3.1
KitSlimFullPowerV3.3[29/04/2014]
KitSlimFullPowerV3.1[26/04/2014]
KitSlimFullPowerV3[24/04/2014]
14.3.A.0.757KitSlimFullPower[19/04/2014]
-Fix overheating (Sysmon, Thermalengine, Read Cache, Good drivers for Camera, Tweaks, Proximity Sensors, Conflict)
-Fix battery drain (Overheating, Read Cache, Tweaks, Proximity Sensors)
-Fix proximity sensors (hw.config.sh)
-CyanogenMod apns-conf.xlm (all operartor)
-Remove R2R services (not need)
-Back on the old tweaks (stability)
-Tweaks for a better compromise stamina and efficiency
-Back on the old camera (V4.1 drivers, framework, apk)
-Clock with text accent color (as on the Blackedition)
-Mirror Link Available*
*(or dev host Rom+Gapps, or uploded Rom+Gapps... It's same, but for dev host, I am limited at 512MB by files... I have modified the packages for that...)
- Bugs Fix
- Fix Networks Loss
- Bugs Fix
- Fix Networks Loss
- Fix reboot inside the recovery
- I have changed some settings
- Best stamina
- Best responsiveness
- More smooth
- Little fix for Google Search
- The rom is fully stable now, all works well, very well
- There is only the Gapps that were modified
- I set the read cache to 1024 (only for the phone, not for the sd)... And not by tweak init.d, or by tweak on build.prop
- I fixed the forced closure of the new album
- I have put the real "reader by sony" instead of shortcut, because according your account, it was not necessarily available
- I have add torch apk
- Update of "TvSideView"
- I fixed the problem for the Rom without GAPPS ( request of your language, at all the reboots)
- Gapps update for paste with the rom
- Reboot in aroma disable (ROM)
- Gmscore update (ROM)
- GMS_Maps update (GAPPS)
- Velvet update (GAPPS)
- YouTube update (GAPPS)
- Livewaremanager update (GAPPS)
- Fix walkman fc
- Boost mod sound (integrated)
- Z2 caméra (integrated)(not supercam 4K)
- Bgdefocus (integrated in Gapps Slim and Full...)
- fix Aroma 6903
- deleted intelligente gesture (the port not work (25%) for the moment)
- Added playstore and these serv in the rom... (you can flash just the rom but not recommanded)
- 2 Gapps modified for the romV3.1
- The number build is stock no name from rom
- The patch are update
- New Concept
- New uploader (dev-host)
- Fw14.3.A.0.757 (C6903 by default)
- TWRP
- FullRoot
- Deodexed
- Optimized
- New tweak
- Great Stable
- Great Fast
- Great Smooth
- Great Sony Design
- Reboot Options
- Full Options
- One Rom Package
- Two Gapps Package ( slim or full )
- Three True Patch for C6902/C6906/C6943 with good build.prop)
- Rebuild 14.3.A.0.757 UB/LB
- DualRecovery
- FullRoot
- Deodexed
- Optimized
- Slimized
- Great Sony Design
- Fix localisation (Gps, wifi, réseau)
- Fix charge off line
- Fix updater script
- Full Options (Z2 intelligent gesture, my Xperia, Sony select is back)
- Option reboot
- Themes XperiaZ 2012Colors
- Best of Sony in small size
ROM
- 14.3.A.0.7XX-KitSlim_AMG [Evo5][24/06/2014]
- 14.3.A.0.7XX-KitSlim_AMG [Evo4][12/06/2014]
- 14.3.A.0.757-KitSlim_AMG [Evo3][04/06/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEvo3][04/06/2014]
- 14.3.A.0.757-KitSlim_AMG [Evo2][01/06/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEvo2][01/06/2014]
- 14.3.A.0.757-KitSlim_AMG [Evo1][28/05/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEvo1][28/05/2014]
- 14.3.A.0.757-KitSlim_AMG [Edition][21/05/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEdition][21/05/2014]
KitSlim_FullPower-V4.1Fix_Final_Stage ->- KitSlimFullPowerV4 -> wurde gefixt -> wird nicht mehr angeboten
- KitSlimFullPowerV3.4.2
- KitSlimFullPowerV3.4.1
- KitSlimFullPowerV3.3.1
Kernel
StocKernel_761 - Flashable zip for C6903 UB/LB
StocKernel_757 - Flashable zip for C6903 UB/LB
Patch FwC6903 + build.prop -> MD5: 760dcdcd218a60c0a8180a00bf93d670
BLACK APPS
BLACK MIXTE SERIE EVO5
BLACK MIXTE SERIE EVO4
Mod
[Volume Boost XZ2-XZ1-XZ1C] Increase internal-external speaker and headphone volume Boost mod sound (integrated)
Screenshots 1-3 ohne Gapps, 4-6 mit Gapps
ohne Gapps läuft die ROM auch (es wird aber empfohlen die Gapps zu installieren)
