[ROM][KK][KOT49H][NIGHTLY] Cyanogenmod 11 [4.4.2][honami]
  • 125 Antworten
Hier mal der Aktuelle Changelog
Since Fri Apr 4 05:05:52 UTC 2014
dalvik
•*dfe86e0 Dalvik :Increase the upper limit check for DexOpt Deps table
external/busybox
•*6786b97 Merge branch '1_22_stable' of git://git.busybox.net/busybox into 1.22
external/whispersystems/WhisperPush
•*0d895ff Fix for crowdin
frameworks/base
•*ba839ff ActivityManager: Update timeline debug statements
•*a20a47c Duplicate sounds file names are displayed in notification list
•*2d596f0 Merge "frameworks: add SmartCover stubs" into cm-11.0
•*7ae217d AppOps: Prompt to remember user choice in ASK mode
•*93e571c Use checkOperation in BroadcastQueue.
•*96a0646 frameworks: add SmartCover stubs
•*fac873d Merge "Keyguard: allow keyguard to be dismissed via intent" into cm-11.0
•*9919305 Keyguard: allow keyguard to be dismissed via intent
•*9c5c269 add VoiceWakeup Settings value
•*a9ff5a9 server: start cne service
•*faae0b4 Merge "msim: Add DC-HSPAP support" into cm-11.0
•*f389c1f Merge "MSimNetworkController: fix Quick Settings" into cm-11.0
frameworks/opt/telephony-msim
•*5dacea2 Merge "Do not show new card dialog if config_auto_provision_enable is set" into cm-11.0
packages/apps/Camera2
•*0ccc193 Fix for crowdin
packages/apps/Settings
•*cad7127 Use SSL for submitting stats
Since Thu Apr 3 05:20:52 UTC 2014
android
•*d616845 Add CURL and BSON to the build.
•*5af1cb6 Add protobuf-c project to the build
build
•*0e6d660 releasetools: use variable instead of fixed name for bootable image
device/sony/rhine-common
•*d24d804 rhine: Update camera overlay
frameworks/av
•*7ef7314 stagefright: Correct the updation of extension sample rate
•*c1055b4 libmedia: Set the correct audio latency in offload mode
frameworks/base
•*f05a112 Merge "systemui: fix qs tiles layout height in landscape mode" into cm-11.0
•*6911baa show connected devices or name of single device on Bluetooth Tile
•*f9732c0 Merge "Solve three memory leaks related to PatchCache" into cm-11.0
•*c61e246 Merge "remove unnecessary switchUser call" into cm-11.0
•*74aef4d Merge "Prevent Lockscreen album art from activating FLAG_KEEP_SCREEN_ON" into cm-11.0
•*2f85b7f Merge "Do not show Home behind full screen activity" into cm-11.0
•*8e9ad37 Merge "Hang off call by power button while screen is on" into cm-11.0
•*01ba12b Merge "Telephony: DcTracker: Fix CDMA APN Data issues." into cm-11.0
•*42d4645 Merge "Telephony: Allow ruim to fetch in CDMA LTE mode" into cm-11.0
•*6488648 Telephony: DcTracker: Fix CDMA APN Data issues.
•*a687ce1 SamsungExynos4RIL: buffer CAT Proactive Command
•*119cde3 Camera2: missing AOSP translation
packages/wallpapers/Galaxy4
•*2e15751 Galaxy4: Set untranslatable
Es wird immer besser :D
Ist die Rom schon alltagstauglich?
Was läuft den noch nicht?
Soweit läuft alles, bzw ich kann nichts feststellen was nicht geht, einziges Manko die Cam. hängt für ein paar Sekunden beim ersten Gebrauch.
Aber das sollte bald besser werden.
Hallo! Ich habe erfahren das ihr bei eurem Z1 Probleme mit dem WLAN-Hotspot bei CM11 habt, stimmt das ? Wenn ja, wie äußern sich die Probleme?
Ich habe ein "Z1 Compact", wenn ich den Haken bei "mobiler WLAN Hotspot" setze, dann steht dort FEHLER. Danach läst sich auch kein WLAN mehr aktivieren, erst nach einem Neustart vom Z1 Compact.
Kennt ihr das Problem?
Gruss
Matze
Nur zur Info: Mit der heutigen Nightly funktioniert der WLAN- Hotspot bei mir...
Aber wie gesagt beim Z1 Compact
Also auch mit der Nightly vom 10.04 habe ich ein Akku Verbrauch von ca. 6%h, na ich bin wieder zurück auf monx.
Sacht mal Freunde der Nacht
Da im ZU-Forum relativ wenige CM nutzen, frag ich einfach mal hier: Ich hab in den CM 11 nightlies festgestellt, das beim scrollen, solange der Finger auf dem Display bleibt, das scrollen relativ ruckelig von statten geht - sollte dann beim Z1 ja genauso sein da gleiche Hardwarebasis. Habt ihr da schon von einer Lösung gehört?
CM 11 im ZU-Forum: https://www.android-hilfe.de/forum/...-aosp-cyanogenmod-official-builds.492882.html
Bin derzeit beim 757er stock ROM mit DooMKernel, das läuft recht geschmeidig. Als alter CM-Fan (hatte schon CM 6 und 7 auf dem Motorola Milestone und CM 7 auf dem Desire HD, sowie CM 10.2 auf dem Galaxy S3 und eben CM 11 auf dem Z Ultra) würde ich aber gerne mal wieder CM raufwerfen - hab nur nicht die Lust dauernd neu zu flashen - so ein Backup/Restore-Zyklus dauert ja auch gerne mal 20 Minuten.
Also ich kann das nicht reproduzieren :(
Allerdings habe ich den Pimped kernel drauf und ein wenig getweaked mit pimp my z1 und anderen Tools.
Gibt es den ggf. Auch für das ZU ?
Lg meet
Reaktionen: TimeTurn
@TimeTurn ich hatte dir dazu woanders schon was geschrieben gehabt, aber ist wohl unter gegangen.
Auf meinem ZL hatte ich das auch nie.
Versuch mal folgendes.
Entwickleroptionen Fensteranimationen auf aus stellen und GPU Rendering einschalten so hab ich bis jetzt immer eine wunderbare Performance hin bekommen.
GPU-Rendering habe ich natürlich schon probiert. Die Fensteranimation hat keine Auswirkung aufs scrollen, warum sollte sie auch. Benutze CM ja nicht erst seit gestern :flapper:
Keine Ahnung warum es Auswirkungen haben sollte, ist für mich ne unnötige Animation :D
Hm dann weiß ich leider auch nicht warum das beim Ultra so ist, und bei anderen Z Geräten nicht.
Weil das Z1 scheint es nicht zu haben, und mein schwächeres ZL auch nicht :D
Edit: Könntest ja mal AOKP probieren wenn es das für das Ultra gibt. Ob das dort auch vorhanden ist.
Hallo Gemeinde,
Nachdem ich seit Februar schon die CM11 Nightlies nutze, mal mehr mal weniger zufrieden, ist nun, mit der Nightlie
vom 10.05. folgendes passiert. Wollte heute die Nightlie vom 15.05. installieren, und bemerkte, das ich nicht mehr in den Recovery Modus booten kann. Alle Bemühungen blieben erfolglos. Auch der ROM Manager schafft es nicht, ins Recovery System zu booten.
Wie kann ich nun das CWM am einfachsten neu installieren ?
Oder gibt es eine Möglichkeit, das CWM zu reparieren, damit ich wieder dort hin booten kann ?
Bitte um Hilfe
LG Frank
Einfach die Boot . IMG aus der cm11.zip via fastboot erneut flashen. Ggf. Hilft das schon.
Grüße
Meet
Guten Abend zusammen
ich benutze auf meinen Z1 schon immer CM11. Ich habe leider erst um Urlaub
festgestellt das der WLan Hotspot nur manchmal funktioniert.
Ich kann das sofort sehen, wenn ich den Hotspot einschalte. Wenn das Icon sehr schnell in der Statuszeile erschein funtioniert der Hotspot. Wenn es länger dauert (gefühlt 10Sek.) dann ist der Hotspot zwar sichtbar aber man kann sich nicht anmelden.
Ich habe das auch schon mit der aktuelle Version vom 7.6.2014 getestet.
Hat jemand das gleiche Problem?
Gibt es dazu schon eine Lösung?
weiß jemand, wann es mal ein CM11 Milestone oder Release Candidate für das Z1 gibt? Bei CM gibt es bisher nicht einmal ein eigenes Forum für das Z1....
Das nightly zu installieren, trau ich mir im Moment (noch) nicht....
Hi, ich habe die letzte Nightly CM11 vom 07.06.14, den pimped Kernel, Bootloader offen und root.
Meine Frage ist kann ich SuperSu verwenden ?
Habe zurzeit noch den CM internen Superuser.
Gibt es da Probleme, wenn beide beide parallel laufen ?
SuperSu gefällt mir persönlich besser.
Danke
@DIE_HARD: Du hast dein Recovery wiedergefunden? :tongue:
Ja, Wenn du SuperSU via Recovery flasht, geht das wunderbar.
Alte Superuser-Funktion (Systemmenü nicht mehr verwenden) und die SuperSU App benutzen.
Meiner Erfahrung nach gehen manche Dinge dann sogar besser.
Bsp: RomToolbox Pro. TB hört auf zu meckern usw.
Reaktionen: DIE_HARD
J ich hab mein Recovery in der Tat wiedergefunden, manchmal ist das Problem halt vor dem Bildschirm ;-)
Okay also ich flash SuperSu zip übers recovery.
Muss ich die alten Berechtigungen in Superuser löschen oder da alles so lassen wie es ist ?
Thx
LOL.
Einfach flashen. Alle Rechte werden dann in SuperSu neu vergeben.
Sunny
scherzy32
  • th3chos3n
Aaskereija
Aaskereija
HowToBrickMyPhone
HowToBrickMyPhone
HowToBrickMyPhone
