Hen Ry
Enthusiast
- 1.681
- Themenstarter
 - #61
Destroyedbeauty schrieb:Disable the custom msm_mpdecision module by adding this init.d script (check attached ZIP / RAR below and extract file inside!) in the init.d folder (system/etc/init.d) and give 0777 permissions to the script.. And rename the mpdecision_bck back to mpdecision..
Then your phone will behave normally again, at Doomkernel v17 ofcourse..
DooMLoRD schrieb:ya with all other governors there is a lot of issue..
will mostly remove it from future releases...
DooMLoRD schrieb:[ IMP NOTE ]
1] starting from v19 onwards you will not be able to get back to stock kernel directly as the wifi related files get changed while flashing kernel!
2] I will release updated advanced stock kernel package to support easily going back to stock kernel!
3] THIS BREAKS exFAT compatibility for now! if you have exFAT based external SDCARD IT WILL NOT WORK WITH THIS KERNEL VERSION!
I am working on fixing this but it will take some time!
4] Xperia Z Ultra is now officially supported! I will release kernel for that device in this thread in next few hours (need to do some more tests)
