Android beta gama D
Gast
Vielleicht solltest du das Rooten lieber sein lassen, das ging ja schon nach hinten los ^^
das SP bleibt beim flashen aus1Unplug your device from your PC
2Power OFF the device (Turn your phone OFF)
3Hold down the VOLUME DOWN button
4While holding the VOLUME DOWN button plug your phone back to your PC
If it is your first time for your phone on the PC, install the flashmode driver, and then get the HW detection to work. Eg, install the driver, then turn off your phone, and then hold down the Down volume button and plug it in windows will then go into hw detection and install the driver for the phone. It will try to check online, so skip that, and it will install the proper driver you just locally installed.
