jedie
- Themenstarter
- #41
Also ganz tot ist es nicht.
Am Linuxrechner wird der Interne Speicher über USB angeboten.
Ich hab mal das gemacht:dragonball schrieb:Kommst du noch rein in den Bootloader?
$ fastboot -l devices
BX902YSXXX&ZLP fastboot usb:1-3
$ fastboot reboot-bootloader
rebooting into bootloader...
OKAY [ 0.000s]
finished. total time: 0.000s
FXP233-cm-10-20130820-UNOFFICIAL-pepper $ fastboot boot boot.img
creating boot image...
creating boot image - 6860800 bytes
downloading 'boot.img'...
(bootloader) USB download speed was 19271kB/s
OKAY [ 0.370s]
booting...
FAILED (remote: Wrong range:0x10008000-0x10692375. Ok:0x00000000-0x05efffff)
finished. total time: 0.378s
SpeedySola v5.5 $ fastboot boot boot.img
creating boot image - 8722432 bytes
(bootloader) USB download speed was 19212kB/s
OKAY [ 0.470s]
booting...
FAILED (remote: Wrong range:0x10008000-0x1085894f. Ok:0x00000000-0x05efffff)
finished. total time: 0.477s
24/042/2013 22:42:47 - INFO - Device connected in flash mode
24/043/2013 22:43:30 - INFO - Selected MT27i / 6.1.1.B.1.10 / Global
24/043/2013 22:43:30 - INFO - Preparing files for flashing
24/043/2013 22:43:31 - INFO - Device disconnected
24/043/2013 22:43:32 - INFO - Please connect your device into flashmode.
24/044/2013 22:44:11 - INFO - Device connected in flash mode
24/044/2013 22:44:11 - INFO - Opening device for R/W
24/044/2013 22:44:11 - INFO - Device ready for R/W.
24/044/2013 22:44:11 - INFO - Reading device information
24/044/2013 22:44:11 - INFO - Phone ready for flashmode operations.
24/044/2013 22:44:11 - INFO - Current device : Unknown: Oct 31 2012/12:13:19 - BX902YS473 - Unknown: Oct 31 2012/12:13:19 - Unknown: Oct 31 2012/12:13:19 - Unknown: Oct 31 2012/12:13:19
24/044/2013 22:44:11 - INFO - Start Flashing
24/044/2013 22:44:11 - INFO - Processing loader
24/044/2013 22:44:11 - INFO - Checking header
24/044/2013 22:44:11 - INFO - Flashing data
24/044/2013 22:44:12 - INFO - Loader : S1_Root_3065 - Version : R5E006 / Bootloader status : ROOTED
24/044/2013 22:44:13 - INFO - Processing kernel.sin
24/044/2013 22:44:13 - INFO - Checking header
24/044/2013 22:44:13 - INFO - Flashing data
24/044/2013 22:44:16 - INFO - Ending flash session
24/044/2013 22:44:16 - INFO - Flashing finished.
24/044/2013 22:44:16 - INFO - Please unplug and start your phone
Hab nun MT27 / 6.1.1.B.1.54 / Global drauf gemacht. Bringt auch nix.dragonball schrieb:Kann das grad net öffnen. Also beste Lösung ist die stock.54 ICS zu flashen und von vorne anzufangen![]()
jedie schrieb:FXP216-cm-9-20130419-UNOFFICIAL-pepper.zip läuft bei mir jetzt eine weile, eigentlich sehr gut!
25/025/2013 00:25:34 - INFO - Device connected with USB debugging off
25/025/2013 00:25:34 - INFO - For 2011 devices line, be sure you are not in MTP mode
25/025/2013 00:25:34 - INFO - Device connected with USB debugging on
25/025/2013 00:25:34 - INFO - Connected device : Sony Xperia Sola
25/025/2013 00:25:34 - INFO - Installed version of busybox : N/A
25/025/2013 00:25:34 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54
25/025/2013 00:25:35 - INFO - Device disconnected
25/026/2013 00:26:17 - INFO - Device connected in flash mode
25/027/2013 00:27:00 - INFO - Device disconnected
25/029/2013 00:29:16 - INFO - Device connected in flash mode
25/029/2013 00:29:51 - INFO - Selected X10 / V1 / BLRelock
25/029/2013 00:29:51 - INFO - Preparing files for flashing
25/029/2013 00:29:51 - INFO - Please connect your device into flashmode.
25/029/2013 00:29:52 - INFO - Opening device for R/W
25/029/2013 00:29:52 - INFO - Device ready for R/W.
25/029/2013 00:29:52 - INFO - Reading device information
25/029/2013 00:29:57 - INFO - Unable to read from phone after having opened it.
25/029/2013 00:29:57 - INFO - trying to continue anyway
25/029/2013 00:29:58 - INFO - Start Flashing
25/029/2013 00:29:58 - INFO - Processing loader
25/029/2013 00:29:58 - INFO - Checking header
25/029/2013 00:29:58 - INFO - Ending flash session
25/029/2013 00:29:58 - ERROR - S1 Header checksum Error
25/029/2013 00:29:58 - ERROR - Error flashing. Aborted
25/029/2013 00:29:58 - INFO - Device connected in flash mode
25/029/2013 00:29:58 - INFO - Device disconnected
25/030/2013 00:30:37 - INFO - Selected MT27 / 6.1.1.B.1.54 / Global
25/030/2013 00:30:37 - INFO - Preparing files for flashing
25/030/2013 00:30:42 - INFO - Please connect your device into flashmode.
25/030/2013 00:30:59 - INFO - Device connected in flash mode
25/031/2013 00:31:00 - INFO - Opening device for R/W
25/031/2013 00:31:00 - INFO - Device ready for R/W.
25/031/2013 00:31:00 - INFO - Reading device information
25/031/2013 00:31:00 - INFO - Phone ready for flashmode operations.
25/031/2013 00:31:00 - INFO - Current device : MT27i - BX902YSXXX - 1261-8249_R1G - 1254-4241_6.1.1.B.1.54 - WORLD_6.1.1.B.1.54
25/031/2013 00:31:00 - INFO - Start Flashing
25/031/2013 00:31:00 - INFO - Processing loader
25/031/2013 00:31:00 - INFO - Checking header
25/031/2013 00:31:00 - INFO - Flashing data
25/031/2013 00:31:01 - INFO - Loader : S1_Root_3065 - Version : R5E003 / Bootloader status : ROOTED
25/031/2013 00:31:01 - INFO - Disabling final data verification check
25/031/2013 00:31:01 - INFO - Processing partition-image.sin
25/031/2013 00:31:01 - INFO - Checking header
25/031/2013 00:31:01 - INFO - Flashing data
25/031/2013 00:31:01 - WARN - This file is ignored : simlock.ta
25/031/2013 00:31:01 - INFO - Processing kernel.sin
25/031/2013 00:31:03 - INFO - Processing fotakernel.sin
25/031/2013 00:31:03 - INFO - Checking header
25/031/2013 00:31:03 - INFO - Flashing data
25/031/2013 00:31:05 - INFO - Processing modemfs.sin
25/031/2013 00:31:05 - INFO - Checking header
25/031/2013 00:31:05 - INFO - Flashing data
25/031/2013 00:31:07 - INFO - Processing prcmu.sin
25/031/2013 00:31:07 - INFO - Checking header
25/031/2013 00:31:07 - INFO - Flashing data
25/031/2013 00:31:07 - INFO - Processing modem.sin
25/031/2013 00:31:10 - INFO - Processing apps_log.sin
25/031/2013 00:31:10 - INFO - Checking header
25/031/2013 00:31:10 - INFO - Flashing data
25/031/2013 00:31:10 - INFO - Processing cache.sin
25/031/2013 00:31:12 - INFO - Processing system.sin
25/031/2013 00:31:12 - INFO - Checking header
25/031/2013 00:31:13 - INFO - Flashing data
25/035/2013 00:35:01 - INFO - Processing userdata.sin
25/035/2013 00:35:01 - INFO - Checking header
25/035/2013 00:35:01 - INFO - Flashing data
25/035/2013 00:35:15 - INFO - Ending flash session
25/035/2013 00:35:15 - INFO - Flashing finished.
25/035/2013 00:35:15 - INFO - Please unplug and start your phone
25/035/2013 00:35:15 - INFO - Device connected in flash mode
25/035/2013 00:35:15 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
25/035/2013 00:35:42 - INFO - Device disconnected
25/036/2013 00:36:09 - INFO - Device connected with USB debugging off
25/036/2013 00:36:09 - INFO - For 2011 devices line, be sure you are not in MTP mode
25/048/2013 00:48:26 - INFO - Device disconnected
Eigentlich war CWM-Recovery drauf. Aber da komm ich auch nicht mehr rein.
Btw. gibt es das auch als FTF ?
