Probleme beim Handy Rooten
  • 16 Antworten
_Farodin_
Hallo leute
Ich versuche jetzt schon seit mehreren tagen verzweifelt mein handy zu rooten (Sony Xperia P) und kriege es einfach nicht hin. Ich bekomme folgende Fehlermeldungen:
Bei dem Root von Bin4ry:
= This script will root your Android phone with adb restore function =
= Script by Bin4ry (thanks to Goroh_kun and tkymgr for the idea) =
= Idea for Tablet S from Fi01_IS01 =
= (20.04.2013) v29 =
Device type:
1) Normal
2) Special (for example: Sony Tablet S, Medion Lifetab)
3) New Xperia Root by Goroh_kun (Xperia Z, Xperia V [JellyBean] ...)
x) Unroot
Make a choice: 1
Checking if i should run in Normal Mode or special Sony Mode
Please connect your device with USB-Debugging enabled now
Waiting for device to shop up, if nothing happens please check if Windows ADB-dr
ivers are installed correctly!
adb server is out of date. killing...
* daemon started successfully *
2054 KB/s (210390 bytes in 0.100s)
remote object '/system/bin/ric' does not exist
Found Sony Backup-Restore.apk
LT26,LT22 etc. mode enabled!
Pushing busybox....
2254 KB/s (1085140 bytes in 0.470s)
Pushing su binary ....
4645 KB/s (380532 bytes in 0.080s)
Pushing Superuser app
3677 KB/s (1468798 bytes in 0.390s)
Making busybox runable ...
Pushing fake Backup
3600 KB/s (73728 bytes in 0.020s)
Extracting fakebackup on device ...
Watch now your device. Select the backup named RootMe and restore it!
Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.L
AUNCHER] cmp=com.sonyericsson.vendor.backuprestore/.ui.BackupActivity }
If all is successful i will tell you, if not this shell will run forever.
Running ......
Good, it worked! Now we are rebooting soon, please be patient!
Waiting for device to come up again....
Going to copy files to it's place
mount: permission denied (are you root?)
You can close all open command-prompts now!
After reboot all is done! Have fun!
Bin4ry
Drücken Sie eine beliebige Taste . . .
Beim verusch mit dem Flashtool zu rooten:
25/044/2013 14:44:17 - INFO - <- This level is successfully initialized
25/044/2013 14:44:17 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
25/044/2013 14:44:17 - INFO - You can drag and drop ftf files here to start flashing them
25/044/2013 14:44:28 - INFO - Device connected with USB debugging on
25/044/2013 14:44:29 - INFO - Connected device : LT22
25/044/2013 14:44:29 - INFO - Installed version of busybox : N/A
25/044/2013 14:44:29 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54
25/044/2013 14:44:41 - INFO - Pushing C:\Program Files\Flashtool\.\devices\LT22\busybox\1.20.2\busybox to /data/local/tmp/busybox
25/044/2013 14:44:41 - INFO - Pushing C:\Program Files\Flashtool\custom\root\subin\Supersu\su to /data/local/tmp/su
25/044/2013 14:44:41 - INFO - Pushing C:\Program Files\Flashtool\custom\root\subin\Supersu\Superuser.apk to /data/local/tmp/Superuser.apk
25/044/2013 14:44:43 - INFO - Pushing C:\Program Files\Flashtool\custom\root\AdbRestore\RootMe.tar to /data/local/tmp/RootMe.tar
25/044/2013 14:44:44 - INFO - Now open your device and restore "RootMe" backup. Waiting ...
25/044/2013 14:44:44 - INFO - You have 60 seconds to follow the restore advice
25/044/2013 14:44:44 - INFO - Running adbrestoreexploit
25/044/2013 14:44:45 - INFO - Restore worked fine. Rebooting device. Please wait ...
25/044/2013 14:44:49 - INFO - Waiting for device
25/044/2013 14:44:49 - INFO - Device disconnected
25/045/2013 14:45:15 - INFO - Device connected with USB debugging on
25/045/2013 14:45:17 - INFO - Root hack did not work.
25/045/2013 14:45:17 - INFO - Cleaning hack files
25/045/2013 14:45:18 - INFO - Rebooting device. Please wait.
25/045/2013 14:45:23 - INFO - Device disconnected
25/045/2013 14:45:49 - INFO - Device connected with USB debugging on
25/045/2013 14:45:50 - INFO - Connected device : LT22
25/045/2013 14:45:50 - INFO - Installed version of busybox : N/A
25/045/2013 14:45:50 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54
ich hoffe mir kann irgendjemnd helfen
PS:
Habe android version 4.0.4, und ja, debuggmodus ist eingeschaltet
Moin,
schade das du deine Zeit bei dem schönen Wetter verschwendest, anstatt mal etwas im Forum zu lesen.
Keine 10 Threads vorher findest du nämlich einen (https://www.android-hilfe.de/forum/...system-update-probleme-mit-rooten.390744.html), der fast so klingt vom Topic wie deiner ;-)
Und es wäre ein Wunder, wenn da nicht schon auf der ersten Seite innerhalb der ersten 10 Posts ne Lösung (https://www.android-hilfe.de/forum/...-probleme-mit-rooten.390744.html#post-5340017) steht ;-)
https://www.android-hilfe.de/forum/...me-mit-rooten.390744-page-2.html#post-5361241
ich hab da jetzt irgendwie keine antwort für mein problem gefunden, könntest du es mir vielleicht mal erklären ? (am besten eine erklärung für dummies die keine ahnung davon haben ^^)
danke im vorraus !
Naja, ok
- du schreibst, du hast ICS 4.0.4
- im log was du gepostet hast, steht es noch genauer "25/044/2013 14:44:29 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54"
- deine Firmware Version (Build number) 6.1.1.B.1.54
- im Thread als 5ter Eintrag steht (https://www.android-hilfe.de/forum/...-probleme-mit-rooten.390744.html#post-5340017) das man diese Version nicht mehr so einfach mit der bin4ry Methode rooten kann.
- als Post 25 steht wie du root bekommen kannst (https://www.android-hilfe.de/forum/...me-mit-rooten.390744-page-2.html#post-5361241)
An deiner Stelle würde ich noch ein paar Tage warten, dann solltest Du eh Jelly Bean bekommen (Android 4.1.2 Build 6.2.A.0.400). Und ich würde erst dann rooten.
wie kann ich denn rooten wenn ich jellybean hab ? geht das dann einfach so mit dem programm von Bin4ry ?
hallo nochmal
ich hab heute nochmal versucht mein Sony Xperia P mit bin4rys tool v30 versucht die backup & restore app hat sich gar nicht geöffnet und ich bekam folgender (Fehler)meldung
Code:
Warning: Activity not started, its current task has been brought to the front
Running ......
Kann mir jemand helfen wie ich das problem lösen kann ? Ich hätte schon gerne root rechte ^^
_nafets_ schrieb:
Die bin4ry Methode funktioniert ab Version 6.1.1. nicht mehr. Man kann es nur noch über "Umwege" benutzen
Infos findest Du wie schon gesagt in den Sammelthreads, oder im Thread zur Firmware.
https://www.android-hilfe.de/forum/...are-6-1-1-b-1-54-ftf-ics-xperia-p.338594.html
Das Problem wurde schon öfter besprochen
https://www.android-hilfe.de/forum/...-ics-xperia-p.338594-page-5.html#post-4652533
Ich gehe mal davon aus, dass du noch immer die anfägliche SW drauf hast. Hast du überhaupt mal die Postings von _nafets_ gelesen?
hmmm ich hab aber 6.2.A.0.400 und nicht 6.1.1.B.1.54
gibt es dafür eine mehr oder wenig "einfache" methode ?
Also die einfachste Methode ist wenn du zurück auf ICS gehst und von da ab rootest und dir dann JB holst.
Ansonsten gibt es eine "nicht sooooo einfache" Methode JB zu rooten.
Den original Thread findest du HIER auf XDA.
Zum Bootloader unlock findest du HIER eine kleine Anleitung.
aber da kann man viel falsch machen, mit dem ganzen flashen oder ? können da daten verschwinden
Es besteht immer die Gefahr etwas falsch zu machen, bzw. das Gerät zu beschädigen.
Deswegen solltest du dich vorher einlesen, falls dir manche Begriffe "spanisch" vorkommen und die Anleitungen GENAU befolgen. Generell gilt bei allen Anleitungen **AUF EIGENES RISIKO***. Wenn du dir also unsicher bist, lies dich lieber noch etwas genauer durchs Forum.
Für viele resultierende Fehler gibt es Lösungen - oder eben einfach nochmal flashen :D
Beim flashen selbst bleiben deine Daten erhalten, diese solltest du allerdings generell löschen bzw. das Gerät zurück setzten um die Firmware sauber aufzuspielen und dadurch die meisten Fehlerquellen zu verweiden. Bei einem Bootloader unlock gehen generell alle deine Daten verloren.
Ich glaube du bringst da einiges durcheinander...
Es hilft ihm gar nichts, ics zu rooten, wenn er jb möchte. Auch verschwinden keine Daten wenn man den Bootloader öffnet...
Xperia P
JB stock Rom, sliding xp 8.2.1
Der ursprüngliche Beitrag von 21:33 Uhr wurde um 21:38 Uhr ergänzt:
@ te
Der einfachste weg jb zu rooten ist der, einen autoroot Kernel zu flashen, dafür brauchst du einen unlocked bootloader. Hast du?
Es gibt auch einen weg mit locked bootloader aber nie versucht.. findest im Forum ein Thema dazu.
Xperia P
Soweit ich mich eingelesen hatte ist der Rootvorgang mit unlook Bootloader von ICS einfacher. Von da an kann man ja immer noch auf JB wechseln, behält aber offenen Bootloader.
Sorry, wenn ich hierbei etwas falsch verstanden habe.
(Zudem meine ich auch gelesen zu haben, dass bei einem BL-unlock die Daten gelöscht werden.)
Danke für deine Berichtigung.
Also wenn du nur rooted und stock willst, wird das mit unlocked Bootloader nichts.
Gesendet von meinem LT22i mit der Android-Hilfe.de App
Warum nicht? Schau mal meine Signatur... Denke mal hast dich verschrieben.... ich hoffe das du locked bootloader meinst.
Xperia P
Xperia P
Ja, selbstverständlich meine ich das... Habe mich wohl nur verschrieben.
  • Sindy80
der_henk
der_henk
  • Holo
Aaskereija
Aaskereija
  • Flo97
ZwischendenWelten
Z
