Aaskereija
Inventar
- 5.601
WICHTIG! ICH ÜBERNEHME KEINE HAFTUNG FÜR EVENTUELLE SCHÄDEN AN EUREN GERÄTEN! NUTZUNG DER ANLEITUNG AUF EIGENE GEFAHR!
Build 1
- Initial Release
Build 2
-- Improve Audio effects
- Allow EGL hibernation
- Fix bootanimation stutters
- Add 1024 free extra kbytes (RAM)
- Enable zRAM (64MB)
- Read only 1 page cluster at a time
- Enable option to wake device using volume rocker
- Start Dalvik with a low memory footprint
- Re-enable JIT cache
- Decrease minimum brightness avalaible
- Updated CM 11 Sources to 2014/06/15
Build 3
- Android 4.4.4
- Update kernel toolchain
- We use TWRP now !
- BlueZ 5.20
- Patch Towelroot
- Logo in Settings > About phone
- Updated CM 11 Sources to 2014/06/29
Build 4
- Goodbye OTA Updater ! Hello OpenDelta !
- Netflix fix
- Updated CM 11 Sources to 2014/07/06
Build 5 aká Stable (M8) release
- improvements
- Sources taken from CM11 stable M8 release
Build 6
- Some fixes (probably)
Build 7
- Updated CM 11 Sources to 2014/07/13
Build 8
- bootbare boot.img
- CM11 improvements
Build 9
- TWRP updated
- Fixed receiving of all types of files via Bluetooth
- libmedia with audio parameter
- New audio resampler
- Testing sco audio blob for Bluetooth
- CyanogenMod 11.0 sources updated to 2014/08/03
Build 10 Weekly
- Bluez updated to version 5.22
- TWRP updated
- CyanogenMod 11.0 sources updated to 2014/08/10
Build 11 Weekly
- CyanogenMod 11.0 sources updated to 2014/08/17
- Probably some fixes (full changelog soon)
Build 12 Weekly
- CyanogenMod 11.0 sources updated to 2014/08/24
- STE logo removed from phone status
Build 13 Weekly
- Fixes on OMX, Wifi Direct and other swag fixes you want.
- Xperia STE logo on Settings is back
- CyanogenMod 11.0 sources updated to 2014/08/31
Build 14 Weekly
- CyanogenMod 11.0 sources updated to 2014/09/07
Build 15 Weekly
- TWRP updated to 2.8
- CyanogenMod 11.0 sources updated to 2014/09/14
Build W15 M10 Stable 2
- CyanogenMod 11.0 sources updated to M10 (SNAPSHOT) 2014/09/17
Build W16-S2
- Bluez updated to version 5.23
- TWRP updated to version 2.8
- CyanogenMod 11.0 sources updated to 2014/09/21
Build W17
- No important or hardware fix
- CyanogenMod 11.0 sources updated to 2014/09/28
Build W18
- YouTube fix
- CyanogenMod 11.0 sources updated to 2014/10/05
Build W19 M11 Stable 3
- Twitch fix
- CyanogenMod 11.0 sources based on M11 for Lotus updated to 2014/10/12
Last stable build for Lotus!
Build W20-S3
- CyanogenMod 11.0 sources updated to 2014/10/19
Build W21-S3
- GPS fix not in this build. (next week)
- CyanogenMod 11.0 sources updated to 2014/10/26
Build W22-S3
- CyanogenMod 11.0 sources updated to 2014/11/02
Build W23-S3
- GPS Fix !
- Some other fixes
- CyanogenMod 11.0 sources updated to 2014/11/09
Build W24-S3
- CyanogenMod 11.0 sources updated to 2014/11/16
Build W25-S3
- CyanogenMod 11.0 sources updated to 2014/11/23
Build W26-S3
- Bug about Display Settings fixed
- CyanogenMod 11.0 sources updated to 2014/11/30
Build W27-S3
- CyanogenMod 11.0 sources updated to 2014/12/07
Build W28-S3
- Only some CyanongenMod fixes
- CyanogenMod 11.0 sources updated to 2014/12/14
Build W29-S3
- CyanogenMod 11.0 sources updated to 2015/01/19
Build W30-S3
- BlueZ 5.23
- TWRP 2.8.4.0
- Memory tweaks
- BT fix
- CyanogenMod 11.0 sources updated to 2015/01/25
Build W31-S3
- Last TWRP version (probably)
- Many CM fixes like SystemUpdateService fix
- CyanogenMod 11.0 sources updated from 2015/01/25 to 2015/03/27
Weekly FINALE
- Final CyanogenMod 11.0 build
- CyanogenMod 11.0 sources updated to 2015/06/25
Funktioniert nicht
- FM Radio
- A2DP (Musik nicht, Anrufe funktionieren)
- Bluetooth funktioniert nicht (W29)
		- Initial Release
Build 2
Build 3
- Android 4.4.4
- We use TWRP now !
- BlueZ 5.20
- Patch Towelroot
Build 4
- Netflix fix
- improvements
Build 6
Build 7
Build 8
- bootbare boot.img
- CM11 improvements
Build 9
- TWRP updated
Build 10 Weekly
- TWRP updated
Build 11 Weekly
Build 12 Weekly
Build 13 Weekly
Build 14 Weekly
Build 15 Weekly
Build W16-S2
Build W17
Build W18
- YouTube fix
- Twitch fix
Build W20-S3
Build W21-S3
Build W22-S3
Build W23-S3
- GPS Fix !
- Some other fixes
Build W24-S3
Build W25-S3
Build W26-S3
Build W27-S3
Build W28-S3
Build W29-S3
Build W30-S3
- BlueZ 5.23
- TWRP 2.8.4.0
- Memory tweaks
- BT fix
Build W31-S3
Weekly FINALE
Funktioniert nicht
- FM Radio
Falls etwas schief geht:
Sony Companion
Firmware zum flashen mit Flashtool
Downloads:
Rom: CM11 - FINAL BUILD Der Hub-Server ist leider wohl für immer Offline! ReUpload des Final Build stammt von mir!
GApps: Google-Stock / AOSP-Stock / Mini / Micro / Nano / Pico (Uni) / Pico
Updates auch per OTA:
Einstellungen > Über das Telefon > System Updates
Und nicht vergessen: Nach Update Cache + Dalvik Cache leeren!
Das flashen einer Custom-Rom und eines veränderten Kernel bedeuten einen tiefen Eingriff in das System deines Xperia GO, du entfernst zwischendurch das komplette OS vom Handy, deswegen sei dir immer sicher was du tust und nutze diesen Guide erst, wenn du ihn auch verstehst und du auch verstehst was du tust. Frage lieber vorher, nicht dann wenn es zu spät ist! Sony's sind zwar in der Regel immer rettbar, doch sollte man die Gefahr eines Full-Brick immer im Hinterkopf behalten.
1. Daten sichern
Falls ihr eure Daten/Apps/Kontakte absichern wollt und dies noch nicht getan habt, empfehle ich euch die App Helium (ohne Root) oder die App Titanium Backup (Root), die speichern so ziemlich alles.
		2. Flashtool vorbereiten:
3. Custom-Rom vorbereiten:
Falls ihr von einer anderen Custom-Rom kommt oder nicht die aktuelle Android version (4.1.2) habt, flasht bitte vorher mit Flashtool die letzte aktuelle Stock-Rom.
Kopiert euch die Rom.zip und GApps.zip danach auf eure Interne SD und aktiviert in den Einstellungen unter Entwickler Optionen das USB-Debugging.
Kopier danach die boot.img aus der Rom.zip nach C:\Flashtool\x10flasher_lib
4. Bootloader öffnen:
*#*#7378423#*#* als Anruf eingeben, danach sollte das Service Menü auftauchen wo ihr bei Service info > Configuration > Rooting Status nachseht ob euer Bootloader auf Bootloader unlock allowed: Yes steht (Andernfalls nicht möglich!)
Für das TA-Backup benötigst du Root, (Das beeinflusst nicht den Bootloader) mithilfe des Easy Rooting-Toolkit von DooMLoRD. Eine One-Klick Methode über den PC (minimale Englischkentnisse vorrausgesetzt).
Unlock-Code von Sony zusenden lassen
TA-Backup machen.
Ab diesem Zeitpunkt sollte dein Handy zu mind. 50% geladen, USB-Debugging aktiviert und Ausgeschaltet sein!
Los Gehts!
Windows-Eingabeaufforderung (CMD) aufrufen, in dem Fenster dann cd C:\Flashtool\x10flasher_lib\ ein eingeben. Wenn kein Fehler auftaucht drückt die Lauter-Taste (Vol +) eures Handys und steckt gleichzeitig das USB-Kabel an. (Lila LED)
danach fastboot.exe -i 0x0fce getvar version eingeben um die Verbindung zu testen.
Falls nur <waiting for device> erscheint hast du wohl einen Fehler gemacht, überprüfe einfach deine Schritte beim Flashtool-Bilderguide erneut.
Jetzt fastboot.exe -i 0x0fce oem unlock 0xKEY eingeben (KEY stellt den von Sony zugesendeten Code dar) und Enter drücken.
TA-Backup machen.
Los Gehts!
Der Bootloader ist jetzt geöffnet!
5. Kernel & CM11 Installieren:
Die boot.img enthält Kernel, Recovery und Root, desshalb der wichtigste Schritt, wie ihr diese flasht, könnt ihr mit einer von beiden Anleitungen lernen:
boot.img flashen mit CMD oder Flashtool
Nachdem nun hoffentlich die boot.img erfolgreich geflasht wurde, startet euer Handy neu und müsst beim Kernel-Logo (SONY mit 3 STE logos unten) nach der verschieden Farbigen LED und einer kurzen Vibration schnell die Lauter-Taste (Vol +) drücken um in die Recovery zu kommen.
Geht in TWRP auf Wipe, dort dann auf Advanced Wipe und wählt Dalvik Cache, System, Data und Cache an und swiped dann den Slider nach rechts.
Danach zurück und auf Install, dort die Rom.zip auswählen und dann auf Add more zips, wählt zusätzlich die GApps aus. TWRP kann bis zu 10 zips auf einmal flashen. Beachtet aber bitte die Reihenfolge das ihr zuerst die Rom auswählt, ansonsten kann es Probleme geben.
Wenn alles geklappt hat drückt reboot system und warten bis das Phone zum Willkommen Screen bootet.
Erster Boot kann bis zu 5 Minuten dauern und ist vollkommen normal!
Viel Spass mit CM11!
Unterstützt die Entwickler!
1€ genügt!
Für weitere tolles Roms, deren Support und OTA!
Weitere Informationen hier.
1€ genügt!
Quellen/Credits: Sony, Flashtool,
Thread at XDA by wan5xp, Google Drive,
Google Play, thx to TKruzze for GApps,
HubDroid of Team STE,
meetdaleet für die TA-Backup Anleitung,
Easy Rooting-Toolkit von DooMLoRD,
Danke an jeden der mich auf Fehler im Guide hingewiesen hat
Probleme bitte melden.
