[UTIL] | X10Flash GUI & 2.1 Firmware (added docomo multitouch)
  • 5 Antworten
UKSheep
UKSheep
Dauer-User
569
Für alle die nicht warten wollen ;)
Bin4ry schrieb:
Okay guys.
Here is new X10flash for Firmware 2.1 Version
Windows 7/Vista Users should diasable UAC!!
Download Flasher:
Please download in this thread:
xda-developers - View Single Post - NEW X10FlashTool - All in One (15.01.2011) NEW
Download Firmware:
X10i:
Multiupload.com - upload your files to multiple file hosting sites! Nordic Thanks to imugur and Reb0rn
Multiupload.com - upload your files to multiple file hosting sites! GERMAN
Multiupload.com - upload your files to multiple file hosting sites! CH (thanks to pippolino)
X10a:
Multiupload.com - upload your files to multiple file hosting sites! ROGERS (thanks to henh)
Multiupload.com - upload your files to multiple file hosting sites! GENERIC (thanks to BluechipJ & batman112)
Put the extracted files into the new "firmware" Folder and run the X10flash.bat
SO-01:
Multiupload.com - upload your files to multiple file hosting sites! DOCOMO MULTITOUCH (thanks to indigomode)
Multiupload.com - upload your files to multiple file hosting sites! DOCOMO (thanks to indigomode)
You have to wipe your USERDATA !! This is important, otherwise you will enter Bootloops etc.
Also be sure SEUS is NOT running! (But at least it should have detected your phone once)
THIS FIRMWARE IS ONLY FOR X10 NOT FOR MINI (PRO) or X8 !
But the flashtool should be capable of flashing all Xperia Series now!
If someone decrypts the Rom you can try it :)
Regards
Bin4ry
If you have more ROMS, just drop me a PN and i will add them to this post!
IF YOU HAVE PROBLEMS LIKE "Unable to Open Channel" please try this guide:
thanks aussiesausage
xda-developers - View Single Post - [UTIL] | X10Flash GUI & 2.1 Firmware (added docomo multitouch)
[UTIL] | X10Flash GUI & 2.1 Firmware (added docomo multitouch) - xda-developers
THX @ Bin4ry, indigomode usw. :)
MfG
UKSheep
Reaktionen: muffinmann
hi leute hab gerade geflasht alle daten sind weg kein multitouch hab mir die nordisch raufgeladen. Flashvorgang war positiv. Angezeigt wird aber auch nur update 1 nicht 2.
irgendwas is schief gegangen.
Hat es sonst noch wer probiert?
Werd weiter probieren!
Mfg
Warum sollte es 2 anzeigen?
mfg Quercus
Dachte das es sich schon um update 2 handelt
Mfg
:smile:
:rolleyes2:macht nix:winki:
O
Anonym6x6
Anonym6x6
  • TomTom83
TomTom83
asdf
