		Wolfbreak
- 66
Wolf
		 TW | Gingerbread 2.3.3 | Theme, Tweaks & Extra's |
	How to install my ROM Video
 | Demonstration Video of my ROM
Screenshots
Screenshots
	Requirements
- Any working ROM with xRecovery
- Flashtool
- FTF bundle posted below
- Wolf_Xperia_6.0.0.zip posted below
Features
- Stock Sony Ericsson 2.3.3 ROM
- Pre-rooted (Superuser files pre-installed, busybox pre-installed!)
- Recovery 0.3 (fully working)
- FPS Uncap Hack
- Mobile BRAVIA Engine, xLoud and Theme Chooser
- Very Light Weight [80mb]
- DLNA
- More Free Memory&RAM
- Build.prop tweaks
- CPU Governor Tweaks
- removed unneeded SE and Google Services
- Ringtones and Notifications on SD Card to save internal Memory
- faster Startup
- better Memory Management [more free RAM]
- improved Peformance, Smoothness and Battery
- Reboot Options Mod included
- Compcache Tweak
- patched app_process & system_server for alot smoother ROM
- patched sqlite for alot faster IO R/W + Battery
- Battery Tweaks
- Process Priority Tweaks
- Automatic ZipAlign
- SD Card Speed boosted
- VM/Sysctl tweaks
- Kernel tweaks
- Android Internal Taskkiller tweaked
- I/O Scheduler tweaks
- Reduced lags
- Better memory management
- Network speed tweaks & improvements
- alot more so check it out....
How to install this ROM?! [Fresh Install]
- Reboot into xRecovery and make a back-up of your current ROM. (You'll need a working xRecovery or else it will say Device/SD Card busy).
- Wipe the following in xRecovery:- Factory Reset (Full wipe)
- Wipe Cache Partition
- Wipe Dalvik Cache
- Go to install Custom Zip and choose Wolf_Xperia_6.0.0s/c
 The following steps are only required if you don't have the new 2.3 kernel and .71 baseband, if you do have them you can reboot your phone and enjoy this ROM.
- Turn off the phone by taking out your battery when ROM installation is finished
- Open Flashtool and flash the FTF Bundle I made available for download. Press on Flash and follow the steps given to put your x10 into flashmode and flash the baseband and kernel.
- When Flashtool is finished you can plug out the USB, turn your phone on and enjoy this ROM!
Downloads
Wolf_Xperia_6.0.0s/c for Baseband 71 (The ROM itself!)
FTF bundle (2.3.3 kernel and baseband .71)
Additional Downloads
- Click Here for Additional Downloads
Credits:
- Zdzihu/FreeXperia Team for everything they did!
- Doomlord/aZuZu for Root & Kernel
- sj8023ld for Statusbar Not. Widget Mod
- ThJap for some nice Tweaks and Japanese EMOJI & SP push fix
- Goro for Kernel
- PlayGunsta for finding some nice Tweaks
- TripNRaVer for some Tweaks
- pvyParts for EDT Tweaks & Not. Bar Toggle
- my_Immortal for EDT Tweaks & Not. Bar Toggle
- 28spawn for xLoud
- All Users for their support
- If i forgot someone send me a PM and i edit it!
