[Rom]WB-XPERIA TW Gingerbread V4 | 55fps, no Audio lag, xLoud & Bravia | 8/8/2011
  • 156 Antworten
I use over 24hours and my battery left 40%.
Wifi on 24/7 except sleeping. ( if not whatsapp will ring nonstop =P )
No setcpu, No cpu master, No UC/OC.
4.0.4s stock kernel.
Originally Posted by Wolfbreak
V5 Changelog:
  • Fixed CPU resetting after Screen Off
  • alot faster Reboots
  • newest DooMKernel for Custom Version
  • Script to mount System RW on Startup
  • changed Governor to Smartass and tweaked it for best Performance/Battery Balance
  • cleaned the whole ROM/Tweaks and Scripts
  • new On/Off Widget Style in Not. Bar
  • GPS Tweaked
  • Fixed a major bug in the Tweak File
  • new Deadline IO Schedulor + Tweaked
  • optimized ramdisk
  • zipalign when needed for data and system Apps
  • fixed Camera Shutter Sound
  • optimized Dalvik VM
  • fixed Permissions for some System Folders
  • Dialer, Superuser, Messages Lagfix
  • New Mount Tweaks Noatime and Nodiratame
  • New SD Card Tweaks
  • No new fair Sleepers Kernel Tweak
  • New Battery Tweak
  • Increasing maximum allowed Process
  • New Kernel Tweaks
  • and alot more i cant remember all i did in the last days
V5 Release:
06.09.2011 or 07.09.2011 becouse i want to test it more before
Reaktionen: SirMarco und Scum
Oh endlich mal wieder ein Update, das wird die Comunity freun ;)
V5 Changelog:
  • patched app_process and system_server binaries with modded Honeycomb ones [alot smoother scrolling]
  • patched SQLite for faster IO R/W + better Battery
  • patched libui for faster Performance
  • Script to check for Permissions and wrong Entrys on boot
  • New Wolfbreak Tweaks!
  • changed Governor to SmartassV2 and tweaked it for best Performance/Battery Balance
  • GPS Tweaked
  • optimized ramdisk
  • Renice/Process Priority Tweaks
  • New Battery Tweak
  • New Kernel Tweaks
V5 Release:
Reaktionen: SirMarco, Fire123 und Scum
Xloud&Bravia V5
Someone who wants to test it cause for me is working great, it works for custom and stock, thats why ull see on display 5.0.0 only...........as last time all credits to my friend Sahibunlimited who taught me, so if u wanna thanks thank him too please: http://forum.xda-developers.com/show...postcount=8236
Info:
xda-developers - View Single Post - [ROM] Wolfs TW Gingerbread | Feel the difference | V5 availabe now | 11/9/2011
Download:
http://forum.xda-developers.com/attachment.php?attachmentid=716216&d=1315715898
Achtung nach der Instalation steht unter Build-Nummer wieder 4.0.4c (selber getestet)
Wenn da wieder 4.0.4 steht dann hast das falsche installiert, und dir fehlen ein paar Tweaks. Er hatte versehentlich ein altes geuppt aber es später korregiert. also noch mal neu laden.
Servus Leute eine Frage Brauche ich Bootloader, wen ja wieso oder für was ist er gut.
Danke. ;)
Was ist so die Beste einstellung für CPU Master? :)
V6
Downloads
FTF bundle (2.3.3 kernel and baseband .71)
Additional Downloads
  • Click Here for Additional Downloads
V6 Changelog:
  • New Statusbar Mod, now with Data On/Off Widget too [thanks sj8023ld]
  • New init.d, build.prop, more free RAM, OOM Priority, ARC Launcher Tweaked, Faster Scrolling, Smoother Animations and alot more.....
  • Updated Superuser to latest 3.0
  • Updated Busybox to latest 1.19.2
  • Updated Adblock Hosts File
  • Now using Google DNS Server
  • Force Converations,Superuser,Phone and Launcher in Memory
  • Increase touch responsiveness
  • E/3G/H tweaked for faster Speed
  • Disable blackscreen calls
  • new Mount Tweaks
  • SQLite Database tweak
  • Governor Tweaks
  • Auto-zipalign when needed
  • new Kernel Tweak
  • Disable verify-bytecode and journalism for more free RAM + more responsive UI
V6 Release (will not wipe DATA):
Download:
Informations
Please click some Ads to support me
Works for unlocked Bootloader and locked Bootloader
Reaktionen: Fire123, Texaner und Scum
V6 out
hallo, habe WB v6c installiert, soweit alles top.
habe mit setcpu einige anpassungen vorgenommen
dazu meine frage: bei version 4 ist folgenes zu lesen:To manually change Governors navigate to system/etc/init.d and delete 98governor file and reboot.
gilt das auch für anpassungen mit setcpu bei version 6?
denn mit setcpu kann man ja "Governors" ändern?
ich suche für die WB-Rom eine Camera-App welche breitbild-fotos schießt..:thumbup:
hatte mal ne miui-rom drauf bei welcher 16:9 fotos möglich waren. sah echt super aus, auch in der gallery zum betrachten, das display war zu 100 % ausgefüllt.
doch leider lässt sich die miui-apk nicht auf der WB-Rom installieren...?
  • App&Widgetpack for Xrec [27.09]
  • [Photo Widget, OnOff Widget, Status Switch, ARC Clock, WeatherWidget, DataMonitor, Genie Widget, Calendar, AnalogClock, Timer, WorldClock, Powersave Mode, Favorite People, TrackID&PlayNow] [Flashable via Xrec]
Updated with new 2.3.4 Widgets from new Xperia Phones
Problem mit SMS Aplikation
Hallo Leute, die ROM ist ja ganz gut, aber leider hab ich das Problem
das die SMS app sich nicht starten lässt(die Anwendung wurde unerwarted beendet...) auch third Party apps (sms.at mobile) gehen nicht. Nicht mal
SMS Empfang ist möglich. Gibt da einen Trick oder sonstige Lösungsmögl.
Für Antworten währe ich dankbar
mfg Kon
mfg Kon
Permission Fix über xRec
Reaktionen: DonCorrado
Super, Danke!
Hat geklappt, jetzt würde mich noch interessieren wie sich in den EDT Tweaks
die Lock Screen Options(sind bei mir ausgegeraut) aktivieren lassen.
mfg Kon
Testversion V3 is here
  • Everything is working, alot tweaks changes, alot bugs fixed, apps fixed, FBiX2 fixed, 2.3.4 ARC S Apps fully working and alot more. Get it now its really stable and fast so its more then a testversion i think but its no official V7 release yet but still im very happy about this Version
Download Stock V7 Test
Download Custom V7 Test
Flash over V6 only, older versions are not supported. This is a update Testversion and no standalone ROM so you need V6 installed already.
FreeKernel and Gaming ROM test will follow, i mean you can flash custom over it without problems but it isnt 100% optimized for them but still very fast, Gaming ROM has normally alot more aggresive values and FreeKernel doesnt have interactiveX Governor i set default in custom but its no Problem.
Mikemr
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
  • Slowfinga
Aaskereija
Aaskereija
