MIUIv4 für Sony Ericson Xperia X10 Mini
  • 0 Antworten
Aram95
MIUI.us v4 ICS
This Build is for Xperia and it's from me ideosdev@MIUI.USV4 on MiniCM9 4.04
This is an pre-alpha build(Testing) and don't complain thing don't work
I don't this little device to do testing or more
Like the Xperia X8 Miuiv4 as i build is depending on skill and not tested
You can help me by Donating me to buy me a Xperia X10 Mini
Any donation or can be made to me or over forum at miui.us (IdeosDev) /Twitter: @IdeosDevZack
Working ::Latest Xperia X10 MINI
  • Boot
  • Touchscreen
  • MIUI Apps and Launcher
  • Sd-Card
  • Wifi
  • Sms and Call -2g/3g
  • Bluetooth
  • Accelerometer
  • Audio
  • headphone
  • Superuser root updated and works
  • Installing Apps
  • GPS
  • Virtual Keys
  • Led
  • Brightness
  • Sensors
  • Charger
  • Camera
  • USB Connection
  • Browser
  • Other's
Requirements:
  • Latest 2.1.1.A.0.6/2.1.1.C.0.0 SE firmware / Baseband: M76XX-TSNCJOLYM-53404015
  • Unlocked bootloader
  • Latest version of the ICS nAa kernel
Installation
  • Download the update-MIUI-xxx.zip from the release link that follows
  • Backup your /data contents: contacts, apps, sms, etc. or backup via recovery
  • Move the update-MIUI-xxx.zip to the root folder of your sdcard.
  • Make sure you are using the nAa-ics kernel
  • Enter CWM and:
  • - Select 'backup and restore -> Backup'
  • - Select 'wipe data/factory reset' (MUST DO)
  • - Flash the zip. To do this, Select 'install zip from sdcard -> choose zip from sdcard' and select the update-MIUI-xxx.zip
  • - Flash gapps if you want them!
  • Reboot (first boot will take ~2 mins)
Downloads: http://adf.ly/D39EU
ICS Kernel Link: [KERNEL] nAa-ics-04 [5/7/12] Custom ICS kernel + CWM Recovery - xda-developers
Z
zakorr
Z
Aaskereija
Aaskereija
Aaskereija
  • spinturnicium
spinturnicium
