Q
Quentin
UPDATE: theme fertig dank euch...
[Theme] Green Mod 1.0 - Green/Black Theme & Icons/"CRT animation" included [19/05/11] - xda-developers
I got it working with a theme right now and want to share with you...
Included:
1. Screen off animation (for demonstration use YouTube)
2. Statusbar icons
3. Battery icons
4. Menu backgrounds changed to black or green (you can choose)
5. Green iconset (mod of the prodigal sun iconpack / over 140 icons)
For black theme take the black-framework-res.apk and the black-SemcGenericUxpRes.apk. The SystemUI.apk is the same for black and green.
For green theme take the green-framework-res.apk and the green-SemcGenericUxpRes.apk. The SystemUI.apk is the same for black and green.
You will find everything in attachment...
So its time to have a look...
Download: siehe Originalthread
Included:
2. Statusbar icons
3. Battery icons
hält mich aber nicht davon ab...
