Themes für die 145er Firmware
  • 9 Antworten
Q
quercus
Gast
Quelle: XDA
Autor:punkmonkey1984
Link: [THEME] MattedBlues theme 1.5
attachment.php
- [THEME UPDATED 1.5A] MattedBlues Dark theme .145 with screen off & Batt % 13/06/11
Updated with the new .145 firmware ENJOY
Here iv done a first port of Matted Blues but made it Darker, its pretty much complete now with
Framework-res.apk.
SystemUI.apk done
Now with SemcGenericUxpRes.apk
As you can see it works great so far, im open to changes and help in theming other applications
Yes the icons change colour when you are connected to google services something i missed.
Dont forget to resign back in to your google account
And
As always this can put you into bootloop so apply with caution.
Was edited with .184 firmware not sure if that will matter
Original work does go to jabbawalkee and his thread here:
http://forum.xda-developers.com/showthread.php?t=768848
Change Log
1.3 Updated should have all tick boxes and other blue treats sorted out now also all status bar icons changed.
1.4 changed pull down status bar colour on request of jtc42, also added
Roaming signal icons to match the theme, have no seen if they are working to please report back on that.
1.4.1 Add option for battery percentage.
1.5 updated with the .145 firmware plus a few other little changes like the status bar etc should not be to much different just updated
1.5A added options for screen off animation and battery percentage for .145 framwork,
framework-res_screen_animation_batt_%.zip
Followed the guide by im_iceman, i have not tested this framework, and as always change permissions
Download siehe XDA Anhang
Reaktionen: Skyliner
welcher launcher ist das?
die menüleiste gefällt mir
Edit: Alles klar, lesen macht frei. ist der launcherpro
*push* Update
Hallo
Hier nun mein versprochenes Theme Black/Transparent.
Das ist der Orginal Stock-Launcher von SE.
Installation: Da wir kein Recovery benutzen können ist es mit Arbeit verbunden.
Mit dem Root-Explorer.
Alle Apps auf die SD-Karte kopieren.
Dann die Apps in den Ordner SYSTEM kopieren, dann für jede einzelne App die Rechte setzen wie gehabt.
Dann die App in den Ordner system/app kopieren.
NEUSTART
Wer mein Theme haben möchte kann noch die folgenden 4 Dateien austauschen:
1 System.ui in System/apps
2 Home in System/apps
3 SemcGenericuxpres in system/framework
4 Framework-res system/framework
NEUSTART
Mit dem ADBMagic geht die Installation einfacher.
Die Apps nacheinander oder alle miteinander mit dem PC über ADD/Replace /push austauschen.
Rechte nicht vergessen.
NEUSTART
Zur Erklärung: Das Telefon und Kontakt icon sind in der Phonebook und Phone apk.
Das SMS icon in der Conservations.apk
Das Email icon in der Email.apk.
NEUSTART
Der transparente Hintergrund mit der Transparent Home Dock for Arc [ Update 145 ] habe ich von XDA übernommen [MOD] Transparent Home Dock for Arc [ Update 145 ] - xda-developers.
und hier der Hintergrund [MOD] [Guide How To] SystemUI.apk for Transparent notifications background - xda-developers
Die Icons sind von hier http://forum.xda-developers.com/showthread.php?t=824656
DER HINTERGRUND IST TRANSPARENT , ihr könnt also jeden beliebigen Hintergrund wählen. Ich nahm schwarz das es besser zu den Icons passt.
Screenoff animation beigefügt.
Und ich hafte nicht wenn etwas nicht klappt , bei mir funktioniert es hervoragend mit der 145 er, habe nicht mit einer anderen getestet ,da ich die 145 er als sehr flüssig betrachte.:D
Download: http://www.mediafire.com/?bx62pqy896e4si2
Reaktionen: quercus und fips
Hallo
hier ein weiteres Theme: Iphone-Theme :D
Download:
Theme iphone.rar
Installation wie oben beschrieben.
Weitere Themes folgen.
Hier gibt es ein Update heute
http://forum.xda-developers.com/showthread.php?t=1082506
Reaktionen: quercus
Die Batterieanzeige mit den Prozentwerten führt bei der 145UK zum bootloop.
Diese sollte man also nicht unbedingt nutzen, es sei denn man hat Lust fastboot anzuwerfen :D
Update 13/06 [THEME UPDATED 1.5A] 13/06/2011 MattedBlues Dark theme .145
Changelog:
Hallo
Hier ein Theme für die Firmware 145 er und die 146 er von mir erstellt mit UOT im Zip-format um mit Recovery zu flashen.
Ich übernehme keine Verantwortung für ein Brick.... wurde getestet von mir und funktioniert.
Man muss ROOT haben....... und einen unlocked Bootlader haben.
Dann Arc ausschalten und mit Fastboot die recoveryARC.img starten.
ACHTUNG : nicht flashen.
Das geschieht dem Befehl "fastboot boot recovery.img" starten und dann den rechten knopf am Arc drücken bis die Leuchte blau leuchtet.
Kurz darauf erschein das Recovery -menu.
Dann mit laut/leise im Menu auf apply update from Sd-card scrollen.
Mit ausschalter bestätigen.
Dann das update.zip auswählen und mit Ausschalter bestätigen.
Bootanimation wird auch geändert. Wer das nicht will mit 7zip die Bootanimation löschen.
Das Theme wird installiert.
Neustart.
Download:http://www.multiupload.com/MNYO8JIMRO Credits für Recoveryimage an Bin4ry und das ganze Team von XDA :rolleyes2:
Download Theme:update.zip
Super :thumbsup:
Ein paar Bilder von der Theme wären noch informativ.
  • 24559
snoopy-1
snoopy-1
lkrys
lkrys
